Page 61 of 195 FirstFirst ... 115157585960616263646571111161 ... LastLast
Results 1,201 to 1,220 of 3899
    Dec 2009
    #1201
    where did you bought or come across it??
    May 2009
    #1202
    mula sa aking suking tindahan....he's also offering a fuel pump made by realston for P1.4k but will buy that next time. actually placed an order for an air filter Realston RAJ-354. all have UKAS marks
    May 2009
    #1203
    finally found the link and here it is:리얼스톤
    Dec 2007
    #1204
    Quote Originally Posted by miked View Post
    dvldoc,
    any info on this oil: EXG Gold Semi synth SAE 15W-40 API CF/SF Engine oil manufactured by DASCO Dong-A Special Company, 441-31 Banje-Ri,Wongokk-Myeon, Ansung-Si Gyeonggi-di, Korea
    plus i bought this oil filter a while ago for P350.00: Realston Engine Oil Filter Realston ROJ-306 Made in Korea (cross for Vic-306). It has a UKAS printed on it.
    PRODUCT > Oil Filter - Japanese Car 1
    Never heard of them, hopefully better than vic, You should email them and see if they will give out efficiency ratings of a particular filter.
    I think this is a good oil as well. http://www.auto-rx.ph/pdf/Caltex%20D...-40%20PDS.pdfI was just curious because Caltex seems to be depleting their last inventory and they are selling 5L jugs for just P1,050 or just about P210/ltr when their lower Delo Gold Multigrade Ultra 15w40 sells at P225/ltr.
    Also its weird that the 1 ltr is P347. Maybe they will have a new formulation with API CI plus 4 conformity soon that is why there is a sale going on.
    #1206
    * the Purolator oil filters. I was going through my calling cards and noticed All Inclusive Sales/Williams Parts carries them. I'll try checking their Pasig office when i have the time since they have been known to import original parts for quite some time already (Bendix, NGK, NWB, Peak, Federal Mogul, etc.) and they usually have a large display at the motorshows. It's different from the supplier of ACE Hardware.
    Dec 2009
    #1207
    i have been at their warehouse in pasig... its huge! i bought bendix metal king there.. they have lots of car parts... i think they distribute the bendix brake pads, cause they have all the part numbers for every vehicle... i remember when i got there they have a display of NGK and Splitfire and other stuffs.. only disadvantage is that they far away from me. they also have filters their, the purolators..
    #1208
    Quote Originally Posted by miko101130 View Post
    Do they give discounts at the warehouse? Kabaliktaran ko naman yan... si Volmax yung malayo sa akin since i come from the northern QC side which is closer to Pasig
    #1209
    Sir Miko, saan po warehouse nila sa pasig? Thanks!
    Dec 2009
    #1210
    if your coming from ortigas avenue from EDSA side... upon reaching C.Raymundo extension you turn right, meh barrier yun so you won't miss it.. then when you're already along c.raymundo i think its somewhere after stella maris, there's a shell at the right side and directly opposite the shell station is a small road going inside of what may seem a huge compound of warehouses, the warehouse of ALL INCLUSIVE is just after the warehouse of TOBY's sport house...
    its better if you already researched the part number you're looking for so it will be much quicker and smooth...
    #1211
    Thanks sir miko...At least this is near my place sa marikina!
    May 2009
    #1212
    as per discussion with my friend who happens to be my suking tindahan, Chevron will dispose their inventories on previous delos especially the monogrades to fully promote their new semi synth multi grades. the new 5 liter delo multigrade sells at P1,200 at my place. the P347 (P345 at my place iirc) is a buy 1 take 1 price.
    Guess my hunch is right. Nagpapalit na kasi sila ng package to give way to CI-4/plus ratings IMO. Hmmm... to buy or not to buy?
    It's very temting kasi for 1,000+ for a 5 ltr jug semi-syn delo sports.
    Dec 2011
    #1214
    I was just thinking, about putting a magnet on the oil filter, which kind of over thinking it, would the magnet pull out the molybdenum from the oil itself? I've read (from Wikipedia) that molybdenum is paramagnetic, unlike zinc which is diamagnetic. Any thoughts?
    Dec 2011
    #1215
    To answer my own question from "http://www.frenergy.com.au/pages/FAQs.html":
    Q: I use Molybdenum DiSulphide compound as a friction proofing in all my engines, Will Powermag Oil Filter Magnet units draw the Moly from the oil??I am not sure if Moly is magnetically attracted.
    A: Paramagnetic metals have a small and positive susceptibility to magnetic fields. These materials are slightly attracted by a magnetic field and the material does not retain the magnetic properties when the external field is removed. Paramagnetic properties are due to the presence of some unpaired electrons, and from the realignment of the electron orbits caused by the external magnetic field. Paramagnetic materials include magnesium, molybdenum, lithium, and tantalum. So answer, only slightly attracted
    Not much of answer, but it gets closer.
    Dec 2007
    #1216
    A magnet will not pull the moly out of your oil. Moly bonds to surface metals for one thing and it also will not be pulled out by a filter maganet of any kind.
    Dec 2011
    #1217
    Got some research about it, they had a little spatter about it in another forum: Brand of Oil Filter? - Page 5 - Mazda MX6 Forums: MX6 Forum
    Bottomline, the molybdenum compound they usually use in motor oils is molybdenum disulfide, which, in a way, is comparable to salt (NaCl, Na is Sodium, very volatile metal), it's very different from pure molybdenum.
    Dec 2007
    #1218
    Caltex Delo Multigrade
    Pretty solid oil
    Base Number, 12.2
    Phosphorus, 1360ppm
    Zinc 1480ppm
    It also has over 100 boron and close to 250ppm moly in it.
    The US Chevron version is just as good.
    Almost as beefy as redline, though it's not a synthetic oil perfect for 8000km to 1000km oil changes with that high TBN.
    http://nelsonpetroleum.com/images/delo400MG.pdf
    Dec 2007
    #1219
    Data sheet for all TOP 1 products.
    There regular engine treatment is just a viscosity modifier, not to impressed with it. It does not have any ZDDP in it at all. The green one has moly but the amount is unknown.
    Data sheets
    http://www.top1oil.com.pl/pliki/all.pdf
    Product sheets
    http://www.top1oil.com/pds/Product%20Catalog.pdf
    Jun 2004
    #1220
    Hi doc. How about Caltex Delo (Silver) Monograde 40. I use this oil from time to time on short OCI (3k kms max) - interchanged with the Caltex Delo 15w-40 oil.
    By the way the shipment has arrived in the post office in North Hollywood. My friend is picking it up today or tom. Can't wait to get the filters. I'm having it shipped here together 8-10 (5 quart) bottles of Mobil 1 TDT.
Remote bypass oil filtration
