Page 18 of 195 FirstFirst ... 81415161718192021222868118 ... LastLast
Results 341 to 360 of 3899
    #341
    Hi Doc,
    Contacted W&L for Fleetguard and they only had the oil filter (LF3313) but said that they never, ever had the fuel filter (FF5159). Bummer. Then I contacted Volmax for Baldwin and they had both oil (B2) and fuel (BF7535) in stock! This being the case, I guess it's best to go one stop shop and just get the Baldwins (the filters, not the "actors")? I checked out the filters in their website and their appearance looked about right compared to the factory filters.
    So using the Baldwin filters, I can still follow your recommended change intervals for oil and fuel filter while running mineral oil, yes?
    It's surprising to see that these filters with superior filtration are so much cheaper than their factory equivalents.
    I was back reading this thread yet again and I found something. edtf spent P940.00 for his Baldwin B2 oil filter from Volmax and yet when I called a few minutes ago, they were going for P215.00! I was starting to doubt it but when compared to Fleetguard (LF3313) from W&L which costs P225.00, it's not really far off so I reckon that prices have gone down?
    #342
    Quote Originally Posted by HardCharger View Post
    Might be because the ones you got are old inventory, and the retailer got them for cheap way back. Some of the ones I got were made in 2007. Could also be fakes.
    #343
    Hi Doc,
    HEY HEY HEY HEY!!!! what!! B2 is now 215!! I think they made a mistake - that is DAMN cheap!!! Those are really good filters. Those can be used on Toyotas, Rovers and I believe some tractors Better double check because I just got a filter (I can't remember the model right now) and it was 900+ too - I'm sure the B2 isn't far off. Did you talk to Jun (not sure if that is his name - the tall guy - he is a pretty helpful guy) He still remembered me even if I stopped buying from them for almost a year.
    Apr 2011
    #344
    Thanks, this is the onesI have bought and it will arrive soon. Will change my filter once it arrives. P560 for it. Hope to see significant reduction in oil particles flowing in the engine. Ace hardware.
    Ry,ok din kayang gaimitin ang purolator sa 4jx1? susubukan ko nga rin yung purolator oil filter classic at saka yung fuel filter... kakabili ko lang kanina sa ace hardware yung fuel filter 470.... sa labas naman ako bumili ng oil filter L45722r primary is 280 lang at yung secondary is 120.. wala kasing stock sa acehardware mag order pa... mas mahal ng kunti sa ace....
    Jun 2007
    #345
    Quote Originally Posted by edtf View Post
    yup same guy..... I hope that is a good thing
    Absolutely! your a Certified Rover nut! haha!
    #346
    hahahaha!!!! That I have to admit. My old disco was the reason why I got to find all these filters. I used baldwin B2 oil filter, Baldwin PA-1667-FN - air filter, Baldwin BF587-D - fuel filter. It was way cheaper than those bought from the usual Rover stores and was of industrial quality
    #347
    I just phoned them for now as I absolutely hate going to the Binondo area and that's what they told me. Like I said, based on the Fleetguard price, it wasn't far off so I reckoned it was accurate but then I re-read your post so...
    #348
    Hmmm.... time to visit again
    Jun 2007
    #349
    ^pakyawin mo na sir kung binagsak talaga yung price....
    #350
    Gising pa din pala si Boss BG ah.
    Pero puwede na rin yung pang-4d56 sa 4m40 diba. So ok na rin. If not Purolator next na mura at ok. medy pricey baldwin pero same performance with fleetguard naman eh.
    Marami namang nag po-post ng sagot kaya kurker na lang ako... hehehe
    available ba sa volmax yung BD28 or BD7028?
    #351
    could it be that they are selling copy filters na din kaya ganun yung price?
    Last time tumawag ako meron pareho.
    #353
    hahahaha wala na ako ngayon 300Tdi BUT I called my friends na and told them must buy ito
    #354
    I hope not - they get their stuff direct from Baldwin - in fact they are the distributors for the Philippines
    Jan 2003
    #355
    saw Purolator oil and fuel filter being sold at DIY Shop in greenhills, mga PHP150 yung pang innova... sayang di ko alam kung ano yung model number for my vitara
    Dec 2007
    #356
    The innova filter will work with the Vitara. As will a number of filters. But the Purolator L14477 or L10241, or Baldwin BT223 will work for you.
    Remember real purolators are easy to spot, Always check for country of origin on filter then Real
    Purolator filter have 8 medium-sized holes for the oil inlet or 7 oval holes and nothing but a black (or orange for the Pure One) diaphragm to be seen through them. There are 6 large crimps holding the gasket in place. Through the center outlet hole, you can see the spring for the bypass valve.
    Part Number: L14477
    Specifications: Anti-Drain Back Valve Yes Height 3.52 O.D. 2.69 Relief Valve P.S.I. 14-18 Thread Pitch UNF-2B Threads 3/4-16 Type of Filter Spin-on
    Specifications: Anti-Drain Back Valve Yes Height 3.36 O.D. 2.98 Relief Valve P.S.I. 12-15 Thread Pitch UNF-2B Threads 3/4-16 Type of Filter Spin-on
    Feb 2003
    #357
    sir, What about for gas engine filters?....Am also an extended oil change practioner and would like to improve also the filter quality to use...Specifically for Honda CRV gen2 and Civic ES model.
    ooppss...found it via google na...it's L14610 for Purolator and B1402 for Baldwin for both engines....Now the query will be saann kaya eto available locally and yung guaranteed genuine?
    Jun 2005
    #358
    is there a bigger dimension (taller but with the same thread) purolator filter that can be used instead of the L14476? i plan to use this since this should have a larger surface area for filtration. this will be used for a vios. i used to use OEM toyota.
    also anyone knows where to get real purolator filters for retail? I think i got a fake L14476 (bought at my suking auto supply. Incidentally, a toyota dealership gets their parts here as well). It doesnt have the country of origin and i cant see the crimping on the gasket. got it for 150 pesos only
    Jun 2005
    #359
    by the way, i also checked the purolators at ace hardware. they dont have the crimping on the gasket and no country of origin. maybe its a fake
    May 2004
    #360
    bro baka pwede pabile para sa 4jg2 natin?
Remote bypass oil filtration
