The innova filter will work with the Vitara. As will a number of filters. But the Purolator L14477 or L10241, or Baldwin BT223 will work for you.
Remember real purolators are easy to spot, Always check for country of origin on filter then Real
Purolator filter have 8 medium-sized holes for the oil inlet or 7 oval holes and nothing but a black (or orange for the Pure One) diaphragm to be seen through them. There are 6 large crimps holding the gasket in place. Through the center outlet hole, you can see the spring for the bypass valve.
Part Number: L14477
Specifications: Anti-Drain Back Valve Yes Height 3.52 O.D. 2.69 Relief Valve P.S.I. 14-18 Thread Pitch UNF-2B Threads 3/4-16 Type of Filter Spin-on
Specifications: Anti-Drain Back Valve Yes Height 3.36 O.D. 2.98 Relief Valve P.S.I. 12-15 Thread Pitch UNF-2B Threads 3/4-16 Type of Filter Spin-on
