Page 72 of 118 FirstFirst ... 226268697071727374757682 ... LastLast
Results 1,421 to 1,440 of 2351
  1. #1421
    Quote Originally Posted by Dieseldude View Post
    This is very unusual. Injection pumps don't normally rattle. Noise could be coming from some part of the engine, near the pump.
    The rattle sound is more of like the sound a bicycle sprocket makes when you free-wheel it but is very audible. I tried moving the throttle by hand and the pulses of the rattle sound can be felt on the pump assembly.
    Makes me wonder....
    Sep 2006
    #1422
    Quote Originally Posted by kompressor View Post
    Makes me wonder....
    Injection pump mounting may have come loose. Also check injection pump drive mechanism.
    #1423
    Hi Dieseldude. I got my mutant green rover with the leaking injection pump yesterday and used it today. Good as new! Practically zero smoke and I will check out my mileage by next week. really happy with it. Makes me want to have my 4d56 done too.
    Sep 2006
    #1424
    Quote Originally Posted by edtf View Post
    I am glad that we were able to help! Enjoy your ride
    #1425
    sir dieseldude, good day po! i'm from leyte province and i have a 2004 crosswind xuv 4ja1 engine , patulong po sana ako regarding with my engine problem, napalinis and na pa check ko na po yung mga injectors, aircon system and alternator ok naman po. ang problema po kasi naka andar na po ang makina at na ka on ang aircon and nasa normal level na ang temperature kahit nasa normal rpm ang idling nag wild ang makina. pero kung naka off ang aircon, ok naman ang andar ng makina. may problema na po ba ang injection pump ko? may idea po ba kayo kung magkano ang gastos sa magpa calibrate? saan po ang recommended nyo na shop na maka pag papabalik sa original setting ng injection pump? i've heard na magaling daw po ang malabon diesel shop, ok po ba? sana po matulongan nyo ako. thanks in advance and God bless.
    May 2009
    #1426
    Good day Sir DD,
    Problem here: Isuzu Elf truck 4GG1 NA engine. No hard starts. Practically no smoking on idle but smokes a little "off white" on highway runs especially on acceleration. Sluggish power on acceleration producing that kind of smoke.
    One specialist quoted P20k on calibration. A good price? I really don't know for now.
    Thanks in advance for any comment and suggestion.
    Sep 2006
    #1427
    Good day Sir DD,
    Problem here: Isuzu Elf truck 4GG1 NA engine. This is the first time I hear about an Isuzu 4GG1. Could it be a 4JG1? Is this an electronic engine?
    No hard starts. Practically no smoking on idle but smokes a little "off white" on highway runs especially on acceleration. Sluggish power on acceleration producing that kind of smoke. Was any previous work done on this engine that may have caused this problem?
    One specialist quoted P20k on calibration. A good price? I really don't know as I've never heard of this engine type.
    Thanks in advance for any comment and suggestion. Check pump to engine timing.
    Sep 2006
    #1428
    sir dieseldude, good day po! i'm from leyte province and i have a 2004 crosswind xuv 4ja1 engine , patulong po sana ako regarding with my engine problem, napalinis and na pa check ko na po yung mga injectors, aircon system and alternator ok naman po. ang problema po kasi naka andar na po ang makina at na ka on ang aircon and nasa normal level na ang temperature kahit nasa normal rpm ang idling nag wild ang makina. pero kung naka off ang aircon, ok naman ang andar ng makina. may problema na po ba ang injection pump ko? Baka mali lang ang adjustment ng idle-up device. Itinataas nito ang idle rpm pag on ng aircon compressor para hindi bumagsak ang idle rpm, at para rin hindi patayin ang engine. Malakas ang engine shake kung masyado mababa ang rpm.
    may idea po ba kayo kung magkano ang gastos sa magpa calibrate? 8 - 12K
    saan po ang recommended nyo na shop na maka pag papabalik sa original setting ng injection pump? I will PM you.
    i've heard na magaling daw po ang malabon diesel shop, ok po ba? Malabon is ok.
    May 2009
    #1429
    Good day Sir DD,
    Oops. Sorry sir. 4HG1. had a talk with the driver-operator recently. the unusual smoking and sluggish power occured after filling-up with diesel. drained the fuel filter-separator. still there is white smoke. I suspect a water contamination problem with the fuel station. will fill up again another batch of diesel and see what happens.
    no previous work done on the vehicle except the regular oil and filters(oil, air, fuel) replacement. it was a surplus unit and running for 2 years now. the problem occured last week.
    thank you sir
    #1430
    sir dieseldude, kung inilalagay yung rpm 750 na may load na aircon which is ito naman ang naka lagay na normal idling, yun na nag wawala na ang engine. pero kung ibinababa naman sa 650 na may load na aircon hindi na nagwa wild. pero pag walang load na aircon ok at ang ganda ng andar ng makina patri ang hatak ok.. salamat po sa reply nyo kanina. sana po matulungan nyo ako.
    Sep 2006
    #1431
    sir dieseldude, kung inilalagay yung rpm 750 na may load na aircon which is ito naman ang naka lagay na normal idling, yun na nag wawala na ang engine. Paano nag wawala ang engine kung nailalagay mo ang rpm sa 750?
    pero kung ibinababa naman sa 650 na may load na aircon hindi na nagwa wild. pero pag walang load na aircon ok at ang ganda ng andar ng makina patri ang hatak ok.. salamat po sa reply nyo kanina. sana po matulungan nyo ako. Gusto kita tulungan pero do ko maintindihan ang post mo.
    Sep 2006
    #1432
    Oops. Sorry sir. 4HG1. had a talk with the driver-operator recently. the unusual smoking and sluggish power occured after filling-up with diesel. drained the fuel filter-separator. still there is white smoke. I suspect a water contamination problem with the fuel station. will fill up again another batch of diesel and see what happens. This is a correct next step before considering any repairs.
    no previous work done on the vehicle except the regular oil and filters(oil, air, fuel) replacement. it was a surplus unit and running for 2 years now. the problem occured last week. Your problem seems to be fuel related. Keep us posted as your experience may help other Tsikoters.
    thank you sir You're welcome.
    #1433
    Sir dieseldude,
    good day po!
    4ja1 engine po, pag bagong, start palang ang makina na medyo malamig pa at naka on ang aircon, ok naman ang idling,
    pero, pag mainit na ang engine , bumababa na ang rpm at lumalakas ang vibration.
    Pero kung hindi naka on ang aircon ok naman ang idling, at hatak ng makina.
    Ano po kaya ang problema ng makina ko? May kinalaman po kaya ito sa injection pump?
    Kung malapit lang sana ako dyan sa shop nyo, punta ka agad ako dyan. Alam ko naman po na matutulungan nyo ako. Kaya lang po dito ako sa leyte province region 8.
    Thanks in advance and god bless.
    Junver
    Sep 2006
    #1434
    Sir dieseldude,
    good day po!
    4ja1 engine po, pag bagong, start palang ang makina na medyo malamig pa at naka on ang aircon, ok naman ang idling. Pero, pag mainit na ang engine , bumababa na ang rpm at lumalakas ang vibration. Pero kung hindi naka on ang aircon ok naman ang idling, at hatak ng makina.
    Meron bang ginalaw sa engine mo bago lumabas itong problem?
    Ano po kaya ang problema ng makina ko? May kinalaman po kaya ito sa injection pump? Mukhang ok ang injection pump.
    1) Recheck idle adjustment and idle-up device.
    2) Check amount of refrigerant loaded on aircon; baka sobra. Check low and high side pressure of aircon.
    3) Verify any previous work performed on the engine.
    Thanks in advance and god bless. You are welcome.
    Junver
    May 2009
    #1435
    sir DD,
    still on the process of consuming the previous diesel fuel. about 3/4 fuel left as of this writing as the vehicle is not usually used. on the average, about once a week. could this frequency of use contribute to the problem as the injection pump is not usually "exercised and lubricated" by diesel?
    to add up some info. with the truck not running (engine on), blipping the throttle produces a combination of severely white and not so severe black smoke with the engine running roughly.
    thank you sir.
    Sep 2006
    #1436
    sir DD,
    still on the process of consuming the previous diesel fuel. about 3/4 fuel left as of this writing as the vehicle is not usually used. on the average, about once a week. could this frequency of use contribute to the problem as the injection pump is not usually "exercised and lubricated" by diesel? Rapid pump failure can happen if water is present in your fuel. Quality of clean diesel fuel deteriorates over time due to bacterial growth and accumulation of moisture. As a safe rule, diesel fuel should be disposed of if stored for more than 8 months. Try this: put fresh diesel fuel in a small container, connect your fuel suction and return lines to this container, and run your engine. If performance improves, then you know that your problem is due to a fuel quality issue.
    to add up some info. with the truck not running (engine on), blipping the throttle produces a combination of severely white and not so severe black smoke with the engine running roughly. Check pump timing, valve clearances, and air intake system for restriction. You can also bring your van to a qualified diesel workshop.
    thank you sir.
    May 2009
    #1437
    sir DD,
    thank you sir.
    thank you sir. i'll do your suggestion of using a container with fresh diesel. will update soon.
    May 2009
    #1438
    sir DD, i have to conclude that it was water contamination. truck runs normally as of now. it was used daily this week. the water at the bottom of the tank maybe consumed already. thanks
    Sep 2006
    #1439
    Quote Originally Posted by miked View Post
    You are welcome......
    By the way, your unit probably has a WIF sensor below the fuel filter/sedimentor and an indicator lamp on the dash. Check/repair this to prevent costly fuel injection repairs.
    May 2011
    #1440
    just had my gu patrol serviced at central diesel,replaced all 4 injectors,air and fuel filters.
Diesel Fuel Injection System Help Desk
