Page 74 of 235 FirstFirst ... 246470717273747576777884124174 ... LastLast
Results 731 to 740 of 2348
    Sep 2006
    #731
    From what I have seen, Denso seemingly has a design defect on the suction control valves of their first generation supply pumps. This has caused a lot of problems for engine manufacturers which use the same system.
    I assume that it is for this reason that Denso has come up with a redesigned supply pump with an improved suction control valve.
    I believe that local car distributors, with the aid of government should compel Denso to replace these problematic pumps with their upgraded pumps free of charge, and whether the vehicle is in or out of warranty. This is how consumer protection works in other countries.
    Jun 2006
    #732
    Hi Dieseldude,
    Would you know what Common-Rail system Nissan Navara has in its motor? Have you encountered a unit in your shop(s) that belches smoke? Is it completely rectifiable? What could be causing it?
    Thanks.
    Apr 2009
    #733
    hi dieseldude,
    In the company that I work for we have an Isuzu IPV 4ja1 engine. mileage is 80k. emission is normal. just past emission test lately.
    Driver said the only problem is whenever he's going on an upward slope engine
    shuts down and also whenever he steers fully ( todo kabig when maneuvering). if he starts again he has to turn the idle knob up so engine will run continuosly.
    what do you think is the problem?
    thank you dd.
    #734
    Quote Originally Posted by Dieseldude View Post
    Hi sir Jake,
    Diba TOYOTA and MITSUBISHI are the one equip with this Pump?
    Ask ko na din how would you know if mdyo sakal (under fuel delivery) ang pag calibrate ng isang pump? Mdetect po ba ito kahit hindi i pull out ang Pump?
    Thanks,
    Jun
    Sep 2006
    #735
    Hi Dieseldude,
    Navarra uses Denso.
    Have you encountered a unit in your shop(s) that belches smoke? No.
    Is it completely rectifiable? What could be causing it? I don't know as we havent worked on a Navara yet. Being quite new in the market, most of these would still be under warranty.
    Thanks. You're welcome....
    Sep 2006
    #736
    Quote Originally Posted by anthon05 View Post
    hi dieseldude,
    Driver said the only problem is whenever he's going on an upward slope engine shuts down and also whenever he steers fully ( todo kabig when maneuvering). if he starts again he has to turn the idle knob up so engine will run continuosly.
    thank you dd.
    Blocked fuel filter or faulty injection pump. Check fuel filter first.
    Sep 2006
    #737
    Hi sir Jake,
    Diba TOYOTA and MITSUBISHI are the one equip with this Pump? Depende kung anong model ng sasakyan at makina ang tinutukoy mo.
    Ask ko na din how would you know if mdyo sakal (under fuel delivery) ang pag calibrate ng isang pump? Kung walang bara ang fuel filter, tank, and lines, ang mga palatandaan ng sakal ay low power, slow acceleration, at walang kausok usok. Kelangan din natin yung konting smoke sa acceleration dahil ito ang extra fuel na nagbibigay ng power.
    Mdetect po ba ito kahit hindi i pull out ang Pump? Pwede madetect ito kung old style rotary pump. Hindi it madetect kung common rail ang system.
    Thanks, You're welcome.
    Jun
    #738
    Hi sir Jake,
    Diba TOYOTA and MITSUBISHI are the one equip with this Pump? Depende kung anong model ng sasakyan at makina ang tinutukoy mo. Toyotas D4D and MITSUBISHI DiD
    Ask ko na din how would you know if mdyo sakal (under fuel delivery) ang pag calibrate ng isang pump? Kung walang bara ang fuel filter, tank, and lines, ang mga palatandaan ng sakal ay low power, slow acceleration, at walang kausok usok. Kelangan din natin yung konting smoke sa acceleration dahil ito ang extra fuel na nagbibigay ng power. Sir meron naman konti usok pero parang mabagal pa din ang acceleration
    Mdetect po ba ito kahit hindi i pull out ang Pump? Pwede madetect ito kung old style rotary pump. Hindi it madetect kung common rail ang system. Pano po ma detect un rotary type naman po pump ko.
    Jun
    Sep 2006
    #739
    Hi sir Jake,
    Diba TOYOTA and MITSUBISHI are the one equip with this Pump? Depende kung anong model ng sasakyan at makina ang tinutukoy mo. Toyotas D4D and MITSUBISHI DiD. Denso ang system ng D4D and DiD.
    [SIZE=2]Kunin mo yung part number ng pump tapos ipost mo. Ano ba ang car mo?
    [/SIZE]
    Jun
    Apr 2009
    #740
    Thanks dieseldude. . i told the driver to replace fuel filter.
    by the way for 4ja1 engines whats the brand of the injection pump used?
    Does your shop specialized on 4ja1 injection pump also? aside from bosch
Diesel Fuel Injection System Help Desk
