sir DD,
still on the process of consuming the previous diesel fuel. about 3/4 fuel left as of this writing as the vehicle is not usually used. on the average, about once a week. could this frequency of use contribute to the problem as the injection pump is not usually "exercised and lubricated" by diesel? Rapid pump failure can happen if water is present in your fuel. Quality of clean diesel fuel deteriorates over time due to bacterial growth and accumulation of moisture. As a safe rule, diesel fuel should be disposed of if stored for more than 8 months. Try this: put fresh diesel fuel in a small container, connect your fuel suction and return lines to this container, and run your engine. If performance improves, then you know that your problem is due to a fuel quality issue.
to add up some info. with the truck not running (engine on), blipping the throttle produces a combination of severely white and not so severe black smoke with the engine running roughly. Check pump timing, valve clearances, and air intake system for restriction. You can also bring your van to a qualified diesel workshop.
thank you sir.
