Results 111 to 120 of 2348
- Jan 2007
- 354
November 20th, 2007 02:44 AM #111
- Sep 2006
- 1,335
November 20th, 2007 02:49 AM #112
- Sep 2006
- 1,335
November 20th, 2007 03:05 AM #113It depends on what turbo timer you're referring to. Most turbo timers supply oil to the turbo for a short duration after engine shut-down.
Fuel consumption will be most economical, and the engine will deliver ample power if the fuel system is calibrated (conforming to manufacturer's specs), and if properly timed to the engine. Air and fuel filters also have to be clean. There is no other way.
Of course, excessive low idle speeds will add up to your fuel bills.
Bye,
Dieseldude
- Sep 2006
- 1,335
November 20th, 2007 03:09 AM #114
- Sep 2006
- 1,335
November 20th, 2007 03:18 AM #115Open your engine hood. You will see where the leak /smell is coming from.
I don't know about the busted bushing.
Intercooler fan should not hit any part of the engine. Your intercooler may have some missing brackets and/or mounting hardware. All of these are easy to locate. Did you use an original intercooler fan last 2005?
Bye
Dieseldude
- Nov 2007
- 12
November 21st, 2007 07:10 PM #116sir dieseldue,
Big tnx for the reply... curious lang po, is there any difference with the denso and zexel noozle tips? for example my original is zexel 121 and i'll change it to denso 121... is it just the same or there is still slight difference even though they have the same number? tnx a lot and God bless.
- Jul 2007
- 345
November 22nd, 2007 12:53 AM #117sir pa OT lang , may synthetic po ba na oil for diesel engines? anu-ano po ba ito, and where are they available TIA sir
- May 2005
- 28
November 22nd, 2007 09:48 AM #118Sir DieselDude,
Good day po sa inyo! I have several questions and I hope you can help me. My ride is Gen II Pajero 4d56 TDIC, my problem now is once i start the engine sa umaga may na notice ako na parang kalabog sa engine. Pinalitan ko na rin po yun engine support ganoon pa rin. Hindi lang po sa pag start, the same problem pag pinatay ko un engine parang may bumara at kalabog bago po ito mag engine off. Ang lakas din po sa krudo everyday gamit ko ito at P300/day only 54KM balikan. Less than 7km/l consumption nya. Every two weeks k naman pinapa linis sa shell station ng air pressure yun Air Filter. Every 6months pinapalitan din yun Air Filter.
I hope you can help me my queries.
Gob Bless.
STOrtaliz888
- Sep 2006
- 1,335
November 24th, 2007 06:24 PM #119Engine shake on start-up and shut-down of older diesel engines is normal. This is due to high compression pressures of diesels. "Kalabog" is abnormal. You can remove the kalabog, but not the shake at these low rpms. Some loose part on the engine (exhaust pipe, etc.) may be hitting body parts. Newer engine models have done away with this "shake" by adding a butterfly valve on the intake manifold. This shuts down the air passage to the engine while cranking and shutting down, with an end result that the engine is not compressing any air. No compression = no shake.
High fuel consumption may be due to a restricted air filter, pump out of calibration, and/or wrong injection pump to engine timing. Try using an original Mitsubishi Pajero air filter. Not all filters conform to factory scpecs.
I hope this answers your questions. Bye and Godbless too.
Dieseldude
- Sep 2006
- 1,335
November 24th, 2007 06:30 PM #120
considering a Ferrari has an average price range of 20-25M. multiply that with 666 units sold then...
Car Sales Data (2024)
