Page 6 of 118 FirstFirst ... 23456789101656106 ... LastLast
Results 101 to 120 of 2351
    Feb 2007
    #101
    sir ive noticed when i was in batangas that a smell of gas was emanating from the hood of our pajero and spotted traces of diesel on one of the injectors. Could this be a busted bushing? (are there?) And can I change the fan of the intercooler because the blade is hitting the injector? I think the intercooler fan was deliberately replaced last 2 years ago when the mechanic changed my cylinder head
    Jun 2006
    #102
    Uhm whats the use of turbo timer? And can we clean the turbo by ourselves?
    And is there any settings to get the fuel consumption me economically? 4D56t Thanks!
    Jun 2006
    #103
    And also that my Idle is high most likely at 900rpm "P mode" 800-850rpm in "N Mode" 800rpm in "D Mode" on the hood it only says normal is 750rpm. Do you think these cause my higher fuel consumption? mine is 6-8km per liter. 4-6 "city"
    8km on highway i think. light footed 1,500rpm to 1,900rm. Pajero Gen2 4D56t
    Thanks!
    Nov 2007
    #104
    Sir Diesel Dude,
    i have a ford trekker 2002 and i think i messed up with my noozle tips. may i ask what's the original noozle tip number of this pickup? my mechanic put a denso 121 i think and its acting weird, idle is rough, power is gone and its emitting black smoke too. some mechanic said that ranger uses zexel instead but they're not sure what number. plz help. tnx a lot.
    #105
    Quote Originally Posted by Dieseldude View Post
    Hi Cocoy,
    You should normally put in original ...130 nozzles as these are factory-recommended. I don't know if using ...112 nozzles has caused your problem as we haven't tried doing it this way.
    I suggest that you ask the workshop which calibrated your injectors to assist you on your complaint. Workshops normally give warranty on their jobs. Did you have your injection pump calibrated too?
    If they cannot help you, I would approach the problem this way:
    1. I would check the condition of my air filter.
    2. Recheck injection pump to engine timing
    3. Check turbocharger boost
    4. Check/calibrate injection pump
    5. Replace nozzles with original ones
    We can do all these but it will cost you. So I suggest that you first seek help from the workshop which originally repaired your fuel ijection system.
    Bye,
    Dieseldude
    thanks for the info sir... i finally replaced the injector nozzle tips to the 130 original number. i still feel its doesnt have the same power as it used to have.. by the way they calibrated the nozzle tips to 130psi.. is this the right pressure?as of now i dnt want to touch the injection pump.. with the 112 nozzle tip installed. would it have affected the injection pump? thnk you again sir for your help..
    Sep 2006
    #106
    hi dieseldude! heaven sent ka, i just hope maka reply ka sa problem ko. Ive just have problem with my 2003 trooper 4JX1, my problem is that it has rough idling at idling speed, abd it cant go beyond 2.5 rpm. what are the possible problems and parts that need to be replaced? and how much will it cost me? medyo down ako ngayon, kya i hope you can help me save a little on my problem. Godbless!
    #107
    Hello Dieseldude,
    I never bought a diesel powered vehicle before because of the rough idling and the black smoke emission unitil I drove a friends fortuner and he explained to me the new CRDi technology. I decided to buy 2, a fortuner and a starex this year. And I am happy, because they don't smoke and they have realtively smooth idling performance. Similar to my other gasoline powered vehicles.
    Recently I bought a 1992 Toyota LJ72 series 70 land cruiser with a 2LTE engine (2.4L turbo charge with electronic injection) primarily because I have always wanted the looks of the said vehicle. It has been my crush, since a long time ago. Since there are no brand new series 70 vehicles offered in the Philippines, I decided to take the plunge and bought a second hand vehicle for the first time in my life. The vehicle is fine, reliable, 1 click start but the it emits black smoke during hard acceleration, I am not use to this and I am very finicky with my vehicles, Do you offer a checkup or tuneup service in Central Diesel for this specific engine model ? How much do you think would it costs, what exactly do you do when you tune up a diesel engine and how long does it take to do a tuneup? Would you also check the turbo? and other things in the engine.
    The vehicle is currently doing repainting, and I will have ARB lockers installed next next week. It will be available by the first week of december. I intend to use the vehicle only very seldom but I want to ensure that it is very reliable as I have very little tolerance for unreliable vehicles. TIA
    Sep 2006
    #108
    Quote Originally Posted by monmendoza View Post
    Hello Dieseldude,
    Recently I bought a 1992 Toyota LJ72 series 70 land cruiser with a 2LTE engine (2.4L turbo charge with electronic injection) primarily because I have always wanted the looks of the said vehicle. It has been my crush, since a long time ago. Since there are no brand new series 70 vehicles offered in the Philippines, I decided to take the plunge and bought a second hand vehicle for the first time in my life. The vehicle is fine, reliable, 1 click start but the it emits black smoke during hard acceleration, I am not use to this and I am very finicky with my vehicles, Black smoke could be due to a restricted air filter, a bad turbo, or a bad injection pump and/or injectors. Your engine may not be getting sufficient air.
    Do you offer a checkup or tuneup service in Central Diesel for this specific engine model? How much do you think would it costs, We can check your Toyota but can't give you an estimate at the moment as we are not yet certain on the cause of your black smoke.
    what exactly do you do when you tune up a diesel engine and how long does it take to do a tuneup? Tune-up would basically mean checking valve clearance and injection pump timing.
    Would you also check the turbo? and other things in the engine. On-engine checking of your turbo is possible but this is another work scope. We can also perform on-engine electronic diagnostics. We cannot give you a time frame on this as we don't know the problem/s on your engine.
    The vehicle is currently doing repainting, and I will have ARB lockers installed next next week. It will be available by the first week of december. I intend to use the vehicle only very seldom but I want to ensure that it is very reliable as I have very little tolerance for unreliable vehicles. TIA I suggest that your have the basic problem checked and corrected before you improve vehicle appearance.
    See my reply as stated above.
    Bye,
    Dieseldude
    Sep 2006
    #109
    Quote Originally Posted by autofrost View Post
    We don't have test or diagnostic capability for this engine as we dont have the Tech2. This is Isuzu's engine fault scanner which is available only to Isuzu service dealers.
    From my experince with the 4JX1, the first thing you should do is to make sure that you are using the correct engine oil for your engine. Your air filter may also be blocked. Exhaust catalytic converter may also be blocked by soot / carbon build-up.
    Next possible problems are the injectors and/or the rail pressure control valve. This will not be cheap.
    I suggest that you bring your vehicle to an Isuzu service dealer. They can solve your problem.
    Bye,
    Dieseldude
    Sep 2006
    #110
    Quote Originally Posted by maedz View Post
    Sir Diesel Dude,
    I don't know the part number of original nozzles for your Trekker as we haven't seen a lot of Trekkers. These are relatively new vehicles, and your nozzles may still be fine. If you still have your original nozzles, send me the inscriptions on them, or send me your injection pump and injector parts numbers and I can trace the nozzles for you. This engine would most probably be using Zexel nozzles.
    Putting in the wrong nozzles will affect engine preformance but not the way you stated it. There may be other problems to be checked, like injection pump timing....... Did you have your injection pump service too?
    Bye,
    Dieseldude
    #111
    Bye,
    Dieseldude
    Thanks dieseldude, I will pay you a visit either next week or first week of december. I will call you up first and set an appointment. Thanks again.
    mon
    Sep 2006
    #112
    Quote Originally Posted by cocoy View Post
    130 psi is too low, 130 bar maybe? Have you replaced your fuel filter?
    The 112 nozzle will not damage your pump.
    We can solve your power problem. However, repair cost will depend on what we see.
    Bye,
    Dieseldude
    Sep 2006
    #113
    Quote Originally Posted by josephbrien View Post
    It depends on what turbo timer you're referring to. Most turbo timers supply oil to the turbo for a short duration after engine shut-down.
    Fuel consumption will be most economical, and the engine will deliver ample power if the fuel system is calibrated (conforming to manufacturer's specs), and if properly timed to the engine. Air and fuel filters also have to be clean. There is no other way.
    Of course, excessive low idle speeds will add up to your fuel bills.
    Bye,
    Dieseldude
    Sep 2006
    #114
    Quote Originally Posted by kaong View Post
    hi.to everybody,
    pasensya na po coz firts time na mag post..i have a 2000 starex and at 70/80kph speed mausok ang tambotso .automatic po .please help me naman
    Check / replace your air filter.
    If this does not work, we can halp.
    Bye,
    Dieseldude
    Sep 2006
    #115
    Quote Originally Posted by freeloader View Post
    Open your engine hood. You will see where the leak /smell is coming from.
    I don't know about the busted bushing.
    Intercooler fan should not hit any part of the engine. Your intercooler may have some missing brackets and/or mounting hardware. All of these are easy to locate. Did you use an original intercooler fan last 2005?
    Bye
    Dieseldude
    Nov 2007
    #116
    sir dieseldue,
    Big tnx for the reply... curious lang po, is there any difference with the denso and zexel noozle tips? for example my original is zexel 121 and i'll change it to denso 121... is it just the same or there is still slight difference even though they have the same number? tnx a lot and God bless.
    #117
    sir pa OT lang , may synthetic po ba na oil for diesel engines? anu-ano po ba ito, and where are they available TIA sir
    May 2005
    #118
    Sir DieselDude,
    Good day po sa inyo! I have several questions and I hope you can help me. My ride is Gen II Pajero 4d56 TDIC, my problem now is once i start the engine sa umaga may na notice ako na parang kalabog sa engine. Pinalitan ko na rin po yun engine support ganoon pa rin. Hindi lang po sa pag start, the same problem pag pinatay ko un engine parang may bumara at kalabog bago po ito mag engine off. Ang lakas din po sa krudo everyday gamit ko ito at P300/day only 54KM balikan. Less than 7km/l consumption nya. Every two weeks k naman pinapa linis sa shell station ng air pressure yun Air Filter. Every 6months pinapalitan din yun Air Filter.
    I hope you can help me my queries.
    Gob Bless.
    STOrtaliz888
    Sep 2006
    #119
    Quote Originally Posted by stortaliz888 View Post
    Sir DieselDude,
    Gob Bless.
    STOrtaliz888
    Engine shake on start-up and shut-down of older diesel engines is normal. This is due to high compression pressures of diesels. "Kalabog" is abnormal. You can remove the kalabog, but not the shake at these low rpms. Some loose part on the engine (exhaust pipe, etc.) may be hitting body parts. Newer engine models have done away with this "shake" by adding a butterfly valve on the intake manifold. This shuts down the air passage to the engine while cranking and shutting down, with an end result that the engine is not compressing any air. No compression = no shake.
    High fuel consumption may be due to a restricted air filter, pump out of calibration, and/or wrong injection pump to engine timing. Try using an original Mitsubishi Pajero air filter. Not all filters conform to factory scpecs.
    I hope this answers your questions. Bye and Godbless too.
    Dieseldude
    Sep 2006
    #120
    Quote Originally Posted by reilley View Post
    I'm sure synthetic oils for diesels are available. But I don't know where to get them.
    Check your owner's manual first, as you may not need synthetics. These are expensive oils. Always use what your vehicle manufacturer recommends.
    Bye,
    Dieseldude
Diesel Fuel Injection System Help Desk
