Results 1,531 to 1,540 of 2348
- Sep 2006
- 1,335
December 27th, 2011 11:05 PM #1531
- Jan 2003
- 15
- Sep 2006
- 1,335
December 29th, 2011 10:21 AM #1533
December 29th, 2011 11:17 AM #1534
good day again sir DD,
just recently, my 4d56 turbodiesel cuts out when accelerated suddenly or when revved constantly at high rpm.....ang nangyari is below empty na yung gage, kinargahan ko 2T (about 50 ml) then drive 10 km to the gas station. tried to overtake then engine suddenly cuts out. suspected it was air in the lines (due to low fuel level), but after filling up the tank still cuts out at sudden acceleration and constant high rpms about 3-5 times on our trip dito sa province. been a user of 2T months before fyi.
changed my fuel filter last october at napansin ko days after the filter change e nagjejerk ang engine when throttle is released suddenly from a high rpm but doesn't jerk if throttle is released relatively slow.
observed too that the engine feels a little sluggish.
is this a simple air entering the fuel system problem? i hope that the injection pump won't give up the ghost yet,
would a soft hose connecting the tank to the water separator-filter assembly contribute to the problem?
thanks in advance dude!!!!
- Nov 2011
- 86
December 29th, 2011 01:30 PM #1535ok po sir.. na-check ko na.. no visible problem on the clamps and hoses.. pero meron po talaga hangin..
and pahabol po.. sorry..
irratic idling po.
3ct po ang makina ko.. nag 900-1300pm although off ang AC. naglalaro ang idle ko ng 1000-1300RPM baba-taas po. malamig man or mainit ang makina.. pag nagsumpong all through-out ng byahe is 1100RPM and above and di sya bababa dun. Pag minsan naman sir. nasa 800 RPM lang or nasa tamang idling. ano po kaya ang problema.
thanks po sa help. ^_^
- Sep 2006
- 1,335
December 29th, 2011 04:58 PM #1536
- Sep 2006
- 1,335
December 29th, 2011 05:03 PM #1537
- Sep 2006
- 1,335
December 29th, 2011 07:03 PM #1538
- Nov 2011
- 86
December 30th, 2011 10:18 PM #1539
December 31st, 2011 04:31 PM #1540
Good day sir DD,
as per your instructions, i revved the engine several times and engine cuts off i.e. shut down (twice) after releasing the throttle quickly. but if i release the throttle slowly, no jerking of the engine. at idle speed, i can see an "air pocket" that is not moving in the clear hose. but when i rev it at high rpms, stream of bubbles (air) start to flow. what's the problem then? should i replace the priming pump as well as the filter? even with numerous pumping of the priming pump, no fuel flows at the air bleed screw. yet it starts easily as long as i preheat the cylinder on cold mornings. just this engine cutting off at high rpms.
plus there's this leak (for more than 2 years now) at the fuel adjustment screw (if i'm not mistaken). the "screw" or "whatever that part is" which is below the boost compensator. the injection pump is i think VE41 as per numerous search on the internet. i know it's not the only one but it says diesel kiki on the side. would this leak problem get me stranded at the side of the road in the near future? i hope not.
thanks in advance.
Couldn't have explained it better myself. This was the point I was making. They (either manually or...
SC (temporarily) stops NCAP
