Results 1,001 to 1,010 of 2348
- May 2006
- 913
July 21st, 2010 11:16 PM #1001sir just out of the blue question..
how dirty is our diesel fuel compared to other asian countries.. specally thailand? i think u already know where im goin with this question.
- Jun 2008
- 41
July 22nd, 2010 02:10 AM #1002Sir Dieseldude,
Update on my problem, sir my engine is a pajero 4m40 and may lumalabas na usok sa breather ng eninge which is connected sa air filter (when I removed it). When I opened the dip stick oil. May lumalabas din na usok pero minsan wala naman. I have no problem with power. Mahatak naman sha and Hindi hard starting pag umaga. Last february pina-"dukot" ko sha. I changed my piston rings and pinaover sized ko.
Does my engine need an overhaul or kaya mawala ung black smoke if i will calibrate my injection pump?
- Sep 2006
- 1,335
July 22nd, 2010 08:31 AM #1003
- Sep 2006
- 1,335
July 22nd, 2010 08:46 AM #1004sir just out of the blue question..
how dirty is our diesel fuel compared to other asian countries.. specally thailand? I really don't know....., but I'm very happy with our local diesel fuel.
i think u already know where im goin with this question. Yes, I have an idea.
- Sep 2006
- 1,335
July 22nd, 2010 09:14 AM #1005Sir Dieseldude,
Update on my problem, sir my engine is a pajero 4m40 and may lumalabas na usok sa breather ng eninge which is connected sa air filter (when I removed it). When I opened the dip stick oil. May lumalabas din na usok pero minsan wala naman. This is engine blowby (combustion gasses which leak past the piston rings). Blowby is normal, low on new engines and steadily increasing as the engine ages due to normal wear on the rings.
I have no problem with power. Mahatak naman sha and Hindi hard starting pag umaga. Good.. Last february pina-"dukot" ko sha. I changed my piston rings and pinaover sized ko. Nag rebore ka ba ng cylinders?
Does my engine need an overhaul or kaya mawala ung black smoke if i will calibrate my injection pump? Check/replace air filter muna. Then compare smoke levels with and without the blowby hose connected to the air intake system.
- Nov 2008
- 210
- Dec 2009
- 47
- Sep 2006
- 1,335
July 24th, 2010 12:21 AM #1008
- Sep 2006
- 1,335
July 24th, 2010 12:28 AM #1009Pleck,
Normal ang konting usok/oil sa filler cap at dipstick sa mga high mileage engines.
80kph maximum speed is not normal. Baka barado lang ang air/fuel filters.... or pwede rin na calibration ang kelangan mo.
- Nov 2005
- 255
July 24th, 2010 08:09 AM #1010for those asking on idle up adjustment for 4d56 engine, ito po siya. these are the same ones provided before on this thread.
HTH
Daming issue ng SU7:grin:
Xiaomi E-Car
