Results 971 to 980 of 2348
- Sep 2006
- 1,335
June 6th, 2010 06:43 PM #971I recently posted about the glowplug having stucked (broken) in another thread and the only way to remove it is to lift the cylinder head, Im planning to have it done because I'm having a hard time starting from cold start (in the morning) and after parking for an hour or more. I should start easy with 3 glow plugs. Check fuse and glow plug relay.
What should a trusted mechanic do aside from removing the broken glow plug and optional parts or a must parts to be replaced so as to make the procedure worth it? Replace head gasket, and timing belt if due.
I don't have any problem with the engine aside from its hard starting when its cold, a bit shaky when it starts, probably because it lacks the heating requirement. This could also be due to a faulty injection pump.
My engine is 4d56, adventure. Can you give me an idea how much will it cost. Thanks in advance.
June 11th, 2010 06:14 PM #972
[quote=Dieseldude;1333472]Malaki and posibilidad na may kahinaan na ang compression dahil mataas na siguro ang mileage mo. Normal wear yan. Nababawasan ang white smoke pag uminit ang engine dahil sa thermal expansion ng pistons.....nag iimprove ang compression.
Compression test ang kailangan.
After they found out kung loose compressed ang adventure 98' ko, what could be the next steps para maging pasado ang emission ng drive ko. may mga parts kaya na papalitan? dieseldude, after sometime, thanks in advance uli.
- Sep 2006
- 1,335
June 12th, 2010 06:22 AM #973
June 13th, 2010 10:28 AM #974
Good day sir dieseldude !!!
Whenever i start up my hilander 97 model for the first time, i notice a pool of diesel forms under the engine. Spill size is about a small coffee cup. The engine also shakes violently at times during the first start. What could be the cause of these?
TIA
- Sep 2006
- 1,335
June 13th, 2010 02:17 PM #975
- May 2008
- 11
June 15th, 2010 12:22 AM #976go central diesel! that injector retime did just the thing! solved my hard start and white smoke problem :0 all i have to do i check the mileage i do now
- May 2010
- 17
June 15th, 2010 10:54 AM #977kagaya po ng regular VE type injection pump. papaano po inaadvance at dinedelay ang CRDi?
- Jul 2009
- 26
June 15th, 2010 02:42 PM #978ang timing control ng CRDi pumps ay hindi na mechanical tulad ng mga traditional VE pumps. Nag d-drive lang ng high pressure fuel ang supply pump to the rail to the injectors.
Ngayon, depende sa camshaft and crankshaft sensor with respect to load, iniiba ng ECU ang triggering ng injection ng injectors; Hindi na pump ang nagcocontrol nyan kundi ang Engine ECU and Transmission ECU sabay-sabay.
- Apr 2009
- 544
June 16th, 2010 06:11 PM #979hi dieseldude ..
thank you for sharing your knowledge and experience, I learned so much from this forum.
I have a question. I read from an article that mixing diesel and auto transmission fluid is good for the injection pump. is this true? and mixing
it with motor oil on oil change?
- Sep 2006
- 1,335
June 16th, 2010 07:10 PM #980
