Good day sir dieseldude !!!
Whenever i start up my hilander 97 model for the first time, i notice a pool of diesel forms under the engine. Spill size is about a small coffee cup. The engine also shakes violently at times during the first start. What could be the cause of these?
TIA
go central diesel! that injector retime did just the thing! solved my hard start and white smoke problem :0 all i have to do i check the mileage i do now![]()
kagaya po ng regular VE type injection pump. papaano po inaadvance at dinedelay ang CRDi?
ang timing control ng CRDi pumps ay hindi na mechanical tulad ng mga traditional VE pumps. Nag d-drive lang ng high pressure fuel ang supply pump to the rail to the injectors.
Ngayon, depende sa camshaft and crankshaft sensor with respect to load, iniiba ng ECU ang triggering ng injection ng injectors; Hindi na pump ang nagcocontrol nyan kundi ang Engine ECU and Transmission ECU sabay-sabay.
hi dieseldude ..
thank you for sharing your knowledge and experience, I learned so much from this forum.
I have a question. I read from an article that mixing diesel and auto transmission fluid is good for the injection pump. is this true? and mixing
it with motor oil on oil change?
