Results 951 to 960 of 2348
- May 2010
- 4
May 4th, 2010 03:18 AM #951Hi Dieseldude and other experts, I have an 04 D4D 2.5 Hilux in the UK, it starts and drives perfectly!, never misses a beat, but is now black smoking quite badly, even at idle, having read many posts about the D4D, the general advice would be to replace the high pressure pump, my previous experience with smoky diesels would be the pump timing, but obviously this is ecu controlled on cdri system, ....can you explain why the High pressure pump would cause black smoke? thanks for any advice
- Sep 2006
- 1,335
May 4th, 2010 08:35 AM #952
- May 2010
- 4
May 9th, 2010 06:56 AM #953Thanks for that, indeed, today I disconnected each injector in turn whilst engine running and noted rough running between each dissablement, the engine managment light came on each time as expected, then strangely enough on restarting the engine, it would appear to be running ok with no more clouds of black smoke, could i have somehow reset the ecu or something?, have driven 50 miles today and it now seems ok!!!, rgds
- May 2010
- 4
May 11th, 2010 03:03 AM #954
- Sep 2006
- 1,335
- May 2010
- 4
- May 2008
- 11
May 23rd, 2010 04:50 PM #957good day sir, i own a gen2 jdm pajero with a 4556 Turbo intercooler engine, and for the past months i noticed that my pajero has been hard starting during cold starts even if all the glowplugs are glowing good. and the bad thing is, after it cranks to start for 15 seconds, a big grey-ish smokescreen is emitted by the exhaust. and while it runs or is in idle, my exhaust still emits this grey ish smoke that smells very unpleasant. and to add to that, my pajero has very bad fuel mileage, let's say around 5.5km/L-6km/L on city and 7-8km/l on highway. what could be the problem and how much would fixing the problem cost?
- Sep 2006
- 1,335
May 23rd, 2010 10:38 PM #958good day sir, i own a gen2 jdm pajero with a 4556 Turbo intercooler engine, and for the past months i noticed that my pajero has been hard starting during cold starts even if all the glowplugs are glowing good. Plugs may be ok but they may not be glowing if your glow plug relay has failed.
and the bad thing is, after it cranks to start for 15 seconds, a big grey-ish smokescreen is emitted by the exhaust. This is often seen on engines which take a long time to start. This will most probably go away once your hard start problem is cured.
- May 2008
- 11
May 24th, 2010 02:48 PM #959sir, how about the bad mileage? would it mean i'd have to calibrate as well?
- Sep 2006
- 1,335
May 25th, 2010 12:23 AM #960
Though not on a people carrier like the Innova, I have Yokohama es32 equipped on my Sylphy since...
Finding the Best Tire for You
