get some idea how to solve my problem with my Mazda B2200..... I just got it top overhauled..... change all the valves and other parts, the oil and oil filter and put new baterry. The engine runs OK but with some problems.
1) Hard Starting - already replace new batterry, fuel filter, air filter and clean the fuel tank. What I notice is that after I keep the car in the parking for few hours, always there is air in the fuel filter. i have to bleed to remove the air, then it becomes easy to start.
Copper gaskets on the pump's suction fitting could be damaged. Filter base may be leaking. Fuel suction line could be restricted due to a sharp bend or internal blockage. Leak is quite difficult to detect as plumbing from tank to pump is on a vacuum. You will have to do a complete trace on this line.
2) Another problem is can not overtake, losing power when accelerating especially at 60 to 80 kph. Mechanic says, sliding clutch which I believe is not the problem, however, in short we change all the complete clutch ass'y, still the same problem losing power when accelerating.
Injection pump is probably pulling in air. Temporarily replace the rubber hose from the fuel filter to pump with a transparent hose. No air bubbles should be seen on this line with engine running.
Now I checked with calibration shop, they told me they need to overhaul the fuel injector which I know I have done it before. Now I have a doubt whether to go for the fuel injector or check other part of the engine. Calibration is not cheap they were charging me 5,500 PHP.
Injector/s may need to be checked if the engine knocks or runs rough. Correct the air suction leak before considering injector service.
Clucth ass'y was replaced but nothing change in the engine performance, during idling the engine works fine
(your injectors are probably ok) but when accelerating it looks like the firing is delayed and there is fuel restriction, even though it can not run, it consumes a lot of diesel.
Check injection pump timing. Does engine smoke? Black or white?
Any advise is well appreciated.
Tnx. Alex
You're welcome,
Dieseedude
