Quote Originally Posted by aris 4jg2 View Post
[SIZE=2]could you also help me with this pls?[/SIZE]
[SIZE=2]i have a 1994 isuzu trooper (4JG2 engine) and i had the engine rebuilt 5 mos. ago. i have a problem with OIL & FUEL consumption.[/SIZE]
[SIZE=2]With regards to the oil problem, i noticed that the turbo has a lot of oil in it. some mechanics told me that they'll redirect the breather hose to the dipstick so that it wouldnt waste oil.. but is this really goin' to solve the problem?[/SIZE]
[SIZE=2]also with the excessive fuel consumption, i just had it calibrated too, nozzle tips were also replaced but it still consumes around 3-5 kms/liter. what are the causes, and wht should i do? pls. help..tnx[/SIZE]
What did you replace when you did the engine rebuilt?
Original ba air filter mo?
Na break in mo ba ng mabuti?
Ako nag overhaul din ako last Sept at 77.4 liters I can do 829 kilometers. I have a 4JG2-TC non EFI manual transmission engine.
Ang injection pump ba ang ni calibrate or nozzles or both? Saan ka nag pa calibrate?
