Results 1,161 to 1,170 of 2348
- Sep 2006
- 1,335
November 13th, 2010 12:54 AM #1161
- Oct 2009
- 4
November 13th, 2010 02:13 AM #1162Sir DieselDude,
Thank you for fixing my Fuego problem, nag iistart na siya at umaandar...although after 2 days nabitin ako climbing a steep road after shifting to second gear....ayaw tumuloy ng krudo hangang sa nag stall na....i just did a manual pump of the fuel filter and then umandar na....sometimes then the idling would go down so kailangan ko bombahin...i guess that's the drawback for using surplus parts...no guarantee on when it will fail....the staff of Central Diesel were very accomodating and as written in the post they would not jump into telling you to replace this and that without testing....regards to Karen, Antonio, Jayson and Miss Inday for making my puyat worthwhile.
- Jul 2009
- 26
November 15th, 2010 03:33 PM #1163Good Afternoon Tsikoteers and Diesel Junkies.
Below are pictures from Dieseldude's workshop, this is one set of Ford Ranger 2.5L TDiC injectors with blown nozzle tips. The extreme damage on the nozzles are not because of normal wear and tear but due to modifications in engine management electronics.
Regards,
ISO4113
November 15th, 2010 06:14 PM #1164
awww! so talaga palang mas maagang masisira ang injectors pag nag lagay ka nung mga chip chip nayun...(assuming chip mod yung ginawa dun sa ranger)
how bout the alcohol injection something? will it also do harm like this? or can it help prevent this?
anothe question. yan ba yung piezo-electric injectors na tinatawag?
- Jul 2009
- 26
November 16th, 2010 08:29 PM #1166
November 16th, 2010 09:36 PM #1167
- Sep 2006
- 1,335
November 18th, 2010 09:35 AM #1168
- Sep 2006
- 1,335
November 21st, 2010 10:48 PM #1169
November 22nd, 2010 08:42 AM #1170
Bro I think mas accurate to say mas maagang masira ang injectors pag overadjusted ang chips. Also depending on what make of vehicle and brand of chip. Some makes are already carrying heavy fuel loads in stock form kasi. And yun din siguro, smaller injectors can only take so much.
Traffic!
