Results 1 to 20 of 2351
    Aug 2008
    Hi, bro, I was reading the forum regarding diesel fuel injector and I find it interesting and might get some idea how to solve my problem with my Mazda B2200 pickup with RF01 engine. I just got it top overhauled / machine shops, due to cut timing belt, after the top overhaul, change all the valves and other parts, the oil and oil filter and put new baterry. The engine runs OK but with some problems.
    FYI I was not using the car for 2 years.
    1) Hard Starting - already replace new batterry, fuel filter, air filter and clean the fuel tank. What I notice is that after I keep the car in the parking for few hours, always there is air in the fuel filter. i have to bleed to remove the air, then it becomes easy to start.
    2) Another problem is can not overtake, losing power when accelerating especially at 60 to 80 kph. Mechanic says, sliding clutch which I believe is not the problem, however, in short we change all the complete clutch ass'y, still the same problem losing power when accelerating.
    Now I checked with calibration shop, they told me they need to overhaul the fuel injector which I know I have done it before. Now I have a doubt whether to go for the fuel injector or check other part of the engine. Calibration is not cheap they were charging me 5,500 PHP.
    Clucth ass'y was replaced but nothing change in the engine performance, during idling the engine works fine but when accelerating it looks like the firing is delayed and ther is fuel restriction, even though it can not run, it consumes a lot of diesel.
    Any advise is well appreciated.
    Tnx. Alex
    Aug 2008
    hi everybody,
    can someone give me an idea about my 2c engine, townace.. i,m having a problem with idling,, at first, idling is ok, but after a couple of minutes, the engine shakes at idle, much more if a/c is on.. water temp is normal.
    i hope u can help me guys.. thanks
    Sep 2006
    Quote Originally Posted by avi42174 View Post
    hi everybody,
    Your problem may be similar to Soundman's. Replace fuel filter, then check your fuel suction circuit for air bubbles or restriction.
    Sep 2006
    get some idea how to solve my problem with my Mazda B2200..... I just got it top overhauled..... change all the valves and other parts, the oil and oil filter and put new baterry. The engine runs OK but with some problems.
    1) Hard Starting - already replace new batterry, fuel filter, air filter and clean the fuel tank. What I notice is that after I keep the car in the parking for few hours, always there is air in the fuel filter. i have to bleed to remove the air, then it becomes easy to start. Copper gaskets on the pump's suction fitting could be damaged. Filter base may be leaking. Fuel suction line could be restricted due to a sharp bend or internal blockage. Leak is quite difficult to detect as plumbing from tank to pump is on a vacuum. You will have to do a complete trace on this line.
    2) Another problem is can not overtake, losing power when accelerating especially at 60 to 80 kph. Mechanic says, sliding clutch which I believe is not the problem, however, in short we change all the complete clutch ass'y, still the same problem losing power when accelerating. Injection pump is probably pulling in air. Temporarily replace the rubber hose from the fuel filter to pump with a transparent hose. No air bubbles should be seen on this line with engine running.
    Now I checked with calibration shop, they told me they need to overhaul the fuel injector which I know I have done it before. Now I have a doubt whether to go for the fuel injector or check other part of the engine. Calibration is not cheap they were charging me 5,500 PHP. Injector/s may need to be checked if the engine knocks or runs rough. Correct the air suction leak before considering injector service.
    Clucth ass'y was replaced but nothing change in the engine performance, during idling the engine works fine (your injectors are probably ok) but when accelerating it looks like the firing is delayed and ther is fuel restriction, even though it can not run, it consumes a lot of diesel. Check injection pump timing. Does engine smoke? Black or white?
    Tnx. Alex
    You're welcome,
    Dieseedude
    Aug 2008
    Quote Originally Posted by Dieseldude View Post
    Clucth ass'y was replaced but nothing change in the engine performance, during idling the engine works fine (your injectors are probably ok) but when accelerating it looks like the firing is delayed and there is fuel restriction, even though it can not run, it consumes a lot of diesel. Check injection pump timing. Does engine smoke? Black or white?
    Tnx. Alex
    You're welcome,
    Dieseedude
    Hi,
    I noticed that there are bubbles in the intake hose, but after bleeding the air out it's gone, then when I parked the car for few hours again there is air. I already replace it before, I will replace again with a better transparent hose and will put 4 clamps in each hose.
    I'll check the copper gasket, maybe it's sucking more air instead of fuel.
    I will correct the air suction before doing the injector calibration.
    ( I told the mechanic to adjust the timing and try to advance a little bit but he dont want to, for what reaon I do not know, I will rotate the injector and make it advance firing a little bit
    Engine does smoke but not so dark, it's more like grayish but not white.
    Tnx alex
    Sep 2006
    I noticed that there are bubbles in the intake hose, but after bleeding the air out it's gone, then when I parked the car for few hours again there is air. I already replace it before, I will replace again with a better transparent hose and will put 4 clamps in each hose. Dami naman clamp yan. One good clamp on each end should be okay.
    I'll check the copper gasket, maybe it's sucking more air instead of fuel. Also, check the flat sealing surface of the banjo fitting.
    I will correct the air suction before doing the injector calibration. Good.
    ( I told the mechanic to adjust the timing and try to advance a little bit but he dont want to, for what reaon I do not know. He probably doesn't know how to properly time the injection pump, and/or he doesn't have the necessary tool/s.
    I will rotate the injector and make it advance firing a little bit. The correct procedure is to time the pump according to specs, as this will assure you of optimal power and fuel economy. Mahal na diesel, di bah?
    Engine does smoke but not so dark, it's more like grayish but not white. Does engine smoke at low idle, or during acceleration only?
    Aug 2008
    I noticed that there are bubbles in the intake hose, but after bleeding the air out it's gone, then when I parked the car for few hours again there is air. I already replace it before, I will replace again with a better transparent hose and will put 4 clamps in each hose. Dami naman clamp yan. One good clamp on each end should be okay. (OK, I will use only One good clamp both sides)
    ( I told the mechanic to adjust the timing and try to advance a little bit but he dont want to, for what reason I do not know. He probably doesn't know how to properly time the injection pump, and/or he doesn't have the necessary tool/s. (maybe)
    I will rotate the injector and make it advance firing a little bit. The correct procedure is to time the pump according to specs, as this will assure you of optimal power and fuel economy. Mahal na diesel, di bah? (yes your right, let me have it adjusted by a reliable mechanic)
    During idle very small/less smoke, if I accelerate then starts to smoke dark gray but after a while in continuos high acceleration the smoke becomes less.
    TNXS
    Sep 2006
    Diesels don't normally smoke at low idle. Check timimg.
    Keep us posted.
    Bye
    Sir Dieseldude and 4JGtootsie,
    Maraming salamat po... Ok na hatak ng bighorn ko na lessen na din ang smoke, pasensya na at ngyn lang ako nakapag post nag ka problema kasi pc ko.
    Sir ot na, share ko lang naging problema ko sa bighorn ko. Lately kasi naging mahina ang acceleration at masyadong maitim ang usok especially sa sudden acceleration. Ang problem lang pala is air filter buti na lang dito ko nag pa check up sa mga kaibigan natin sa tsikot, baka kung sa iba ko nag pa check e recomend nila agad for calibration at perahan lang ako.
    Sa mga balak mag pa calibrate dyan dito na kayo sa experto at hind manloloko.., Just look for Jake or Budoy hehe.
    Maraming salamat po ulit!!!
    Dec 2004
    ask ko lang,out of warranty na innova ko,i think my unit needs replacement on fuel pump (kaso out of warranty nga) experince choking na,where ba any recommedation for my pump to be check?thanks
    Kung D4D yan sir just bring at Central Diesel sa Quezon Ave beside Capitol Medical, we have serviced Innova and Hi lux with similar problems. Look for Jake or Ramon 4113711 to 13
Diesel Fuel Injection System Help Desk
