Page 19 of 62 FirstFirst ... 915161718192021222329 ... LastLast
Results 361 to 380 of 1227
    May 2019
    #361
    I usually use Mobil and Fram, both of their extended performance; and sometimes Purolator One. OCI on our cars is 1x a year.
    Jul 2014
    #362
    Quote Originally Posted by gabzprime View Post
    Any recommended seller?
    Just search the part number in Lazada or Shopee. Pwde rin you chat the seller.
    Sent from my SM-G7102 using Tapatalk
    Apr 2012
    #363
    Get a wix sa Lazada. Much cheapet and almost par with Baldwin
    Sent from my SM-J730G using Tapatalk
    Jun 2019
    #364
    Quote Originally Posted by Mask Rider Blac View Post
    Lagi kong nakikita sa post yung lazada or shopee. May okay ba dito mamili kesa sa banawe?
    Jul 2014
    #365
    Quote Originally Posted by Rivera's Auto View Post
    Pwde mong i-check muna ung ratings/reviews ng seller bago ka mag-place ng order. If big factor sa'yo ang convenience, buying online is a much better option. Just plan ahead of time.. say planning for an oil change, place your order/s two weeks before or a month before para may leeway ka. Everything else, alam mo na un [emoji5]
    #366
    fake kaya ito mga bros?
    nakapag drain na kasi ako kanina ng oil, napabili tuloy ako sa tabing auto supply.
    nagulat ako iba itsura dun sa salpakan nya, tapos made in japan. usually thailand nakikita ko. nilagay ko yun dating gamit (90915- yzze1) ko rin for reference. di ko kasi nabitbit.
    nakabit ko na pero medyo paranoid ako baka sablay ..
    #367
    ^ Mahirap malaman ang japake ngayon, matinidi gumaya yung chinamen kaya nga banned ni trump iLang products nila.
    Best way to check is by opening the can and compare side-by-side the internals. Dapat nag aftermarket BT223 ka nalang kung hindi sigurado .
    Jul 2014
    #368
    Kamukha ng P502015, tingnan ko kung saan gawa ung nabili ko, either Indonesia or Saudi Arabia. We've seen a filter na gawa from two different countries, magkaiba itsura.
    You can try the B33 na kasing laki ng filter ninyo or longer/larger filters like the B37, BT223, P550335.
    Looks legit naman, changed the engine oil on the Innova last Saturday and almost same din packaging and made in Thailand din yung nabili ko.
    #370
    nagduda kasi ako agad nun nakita ko made in japan. after 12nn na so sarado si katabing auto supply, kinabit ko nalang. may nabasa naman ako na yun taiwan daw yun fake and japan yun orig [emoji848][emoji848]
    pero yun japan hindi paper media ang gamit, parang porous fibre bro.
    Genuine Toyota Oil Filter - Japanese vs Thailand made - Mechanical/Electrical - PakWheels Forums
    #371
    di pa kasi kami sure ni CB nun bumili ako oil sa kanya. baka next oil change ko pakuha nalang ako kay cb ng double core vic or baldwin.
    thanks mga bros
    btw bros 90915 yzze1 from toyorama (old filter)
    90915 10003 from tabi auto supply (new)
    Dec 2013
    #372
    Mas okay ba wix kaysa sa Original na Hyundai Filters?
    Actually the parent company of WIX USA which is Mann+Hummel Germany is the one supplying 99% of Hyundai's filters since Mann+Hummel has plants in S. Korea that directly supplies Hyundai, Kia and other S. Korean car manufacturers.
    #373
    Been using Mann for the longest time.[emoji106]
    Dec 2013
    #374
    Mann+Hummel is the owner of WIX brand of filters, both the WIX and Mann filter brands are under the Mann+Hummel group.
    #375
    Quote Originally Posted by JapanABC View Post
    Yup.
    #376
    original hyundai filters from M&H are the heaviest 🤔
    Jul 2019
    #378
    Very cheaply made pala ang VIC? I was considering this in my next oil change. Surprisingly, okay pala ang Purolator and it cost cheaper than VIC.
    Note : i cant seem to reply in this thread without quotting a post. hehehehe
    My opinion. I never had a problem with Vic filters ive used em for years and my cars seem to be ok considering i have a 30year old car and a 20 year old pickup.
    i tried using the cheaper WIN filters and that was pure ****. na notice ko na sobra taas temp ko and parang iba tunog sa makina after an old change i was really confused since galing oil change i figured na it has to be the filter i immediately change that and viola na back to normal. I think barado sya . Will never use WIN again.
    May 2017
    #379
    Quote Originally Posted by Iron Maik View Post
    Ngayon ko lang narinig ang WIN filter na yan, baka na man you mean WIX filter???
    WIN filters baka LOSE. cheap filters will be cheap.
    Im guessing you also use Pertua?
Best Oil/Fuel Filters
