Page 1 of 117 123451151101 ... LastLast
Results 1 to 10 of 1166
    [quote] Originally Posted by dvldoc
    A good add on to this thread if people can post the aftermarket filters they see on the shelf there so we can tell you which are the good and the not so good.
    So far we know this.
    Fleetguard - Fleet service heavy duty filter
    Baldwin- Fleet service heavy duty filter
    Bosch- good over the counter filter
    Mann- decent filter not the best specs for efficiency but well built
    Fram- Orange can of death, one of the worst on the market.
    OEM-Toyota black can not made by Mann, Low quality filter
    OEM-Honda low quality filter paper end caps, cheaply made
    OEM-Madaz decent filter good for 5000k oil changes
    OEM-Nissan white can, total garbage, foam filter media thin cardboard
    Nissan- made by Mann, decent over the counter filter 5000k use.
    Mobil1-good over the counter filter
    K&N - good over the counter filter
    WIX- above average oil filter heavy duty construction.
    OEM-Ford (Motorcraft filter) Good over the counter filter
    ACDelco-None Ultraguard and Duraguard are of very low quality
    OEM-Hyundai-good OEM filter
    VIC- Very cheaply made, restrictive bypass valve, poor filter media
    Union-Decent over the counter filter, basic paper media 5000k Change out
    JHF- Decent Koren made over the counter filter 5000k use
    Fil- lable says (for) Toyota, red and white box, Yellow lettering on filer, undersized filter media, bad bypass valve cause filter to recirculate unfilterd oil.
    Fil-Fram Koren version. same issues. Steel on steel relief valve fails to seal, leaves dirty oil circulating.
    Toyota (Denso) Japan, has on average fewer pleats for fitering vs other filters. Example MANN has 60 pleats vs Densos 29, vs Frams 59 in the same size filter. Very short life filter.
    Fellow Tsikot member await your input [quote/]
    Purolator makes good oil filters as well!
    Read more: http://tsikot.com/forums/engine-fuel...#ixzz1Or1EcsGl
    Oct 2011
    Very cheaply made pala ang VIC? I was considering this in my next oil change. Surprisingly, okay pala ang Purolator and it cost cheaper than VIC.
    Feb 2012
    Sayang, kakabili ko lang ng OEM Toyota filter. Sino kaya may gawa ng Altis filters dito? Sa ngayon, I am on Purolator filters from Speedyfix.
    oil filter denso ung made in japan
    fuel filter kyosan ung made in japan
    Oct 2011
    mag ingat lang sa mga fake filters.
    marami ngang fake na purolator and vic filters.
    Oct 2011
    fake rin ba ung vic na binebenta sa ace?
    Nope but overpriced!!!!
    Oct 2011
    nasa Php270 ung VIC. overpriced nga compared sa Bosch na Php150 lang.
    Jan 2004
    sir Retz san available yun Bosch oil filter due na rin for change oil kotse ko
Best Oil/Fuel Filters
