Page 21 of 62 FirstFirst ... 1117181920212223242531 ... LastLast
Results 401 to 420 of 1227
    Feb 2010
    #401
    Quote Originally Posted by JapanABC View Post
    Legit JS Asakashi filters, WIX filters, Akebono brake pads, Mitsuba, Maruko, PIAA, Denso horns, Hope(Oigawa) bulbs, Osram bulbs, and etc... can be bought through this seller, mataas ratings and sure genuine item makukuha mo dito F2 - ZIC / Kixx Dealer - Home | Facebook plus side is that HAMP oil filter is available din sa kanila.
    Thanks bro JapanABC
    saw hamp for Hondas from this sellers fb. is that a better grade than the JS A? i wanna get something for the civic this next oil change
    Dec 2013
    #403
    The difference between Honda Genuine oil filter that is being supplied to the Philippines market is that it is coming from Thailand, HAMP filter is mainly for the American and Japanese domestic markets the HAMP brand oil filter is Made in Japan by the OEM supplier of filters to Honda so quality is superb and same as the Genuine Honda filter that is Made in Japan, you can find the filter from F2 ZIC dealer in FB F2 - ZIC / Kixx Dealer - Home | Facebook. Also forgot to mention that this F2 Autoparts also handles Nissin brake pads which are OEM to Honda vehicles.
    Meron nga before sa honda BGC made in Thailand na oil filter OEM pero super mura. Ewan ko kung available pa doon now.
    thanks bro👏
    Sep 2019
    #406
    I have been using VIC for a long time,
    so that is why it's one of the lowest types pala
    #407
    orig from casa vs orig (daw) from suki auto supply
    first pic is legit. 2nd pic is most likely jafake..
    #409
    yun 2nd pic bro ang binibenta din sa lazada, nun nag check ako ng sellers online
    tignan ko rin yun ontheway na shops. i need to get some wipers anyways.
    #411
    Bumili ako Bosch oil filter sa Lazada for the ASX. Mga 200+ ata bili ko. For the FXT, stock Subaru pa rin kuha ko from Fusion R.
    #412
    Pati mga engine oil sa lazada fake. Toyota fully synthetic daw pero may mga visible particles sa oil.
    Puro fake mga oil filter. I posted a question on one of lazada's seller saying "oil filter appears to be fake" and seller responded that he will check with his supplier daw. He didn't even bother defending his merchandise.. haha..
    Nov 2014
    #413
    Tiningnan ko yung VIC 932 kanina sa new shop malapit sa amin. Mukang kapareho naman nung sa Erti I got from casa. Siguro kung fake na ginamit lang yung name pero functions as the same eh medyo ok na hehe. Pero mantra sa work ko dati eh, when in doubt i decline mo..
    Sent from my LG-M700 using Tapatalk
    #414
    Quote Originally Posted by sp00nman View Post
    bro contact mo na crazy boy .. err on the safe side [emoji28]
    Nov 2014
    #415
    Hehe.. Thanks, Ninja!
    And no worries hindi ko binili yung vic, at katatapos ko lang magpalit with the oil filter and langis i bought from casa.
    Aug 2015
    #416
    Any feedback po sa dalawa, havoline formula 20w 50 at havoline sf 20w 40?
    Lagi kong gamit ung dilaw ng shell mineral oil, pero napansin ko ngayon may mahinang valve tick ung makina ko kaya gusto kong magpalit. Anu kaya mas maganda sa dalawa?
    Civic 2000. Tia.
    Quote Originally Posted by luffin View Post
    Civic 2000. Tia.
    20w50 and 20w40 arent standard multigrade viscosities. stick with the yellow bottles...
    valve ticks are probably from the upper part of the engine . you may have something going on with the camshaft rollers...
    Aug 2015
    #418
    Wala ako masyado alam sa mga multigrade sir, pero pasok naman yang dalawang viscosity base sa manual ko. May mairecommend ba kau bukod dun sa dilaw ng shell? Ung mineral ng castrol ok po ba?
    Aug 2015
    #419
    Yes sir sa upper part left side, hindi naman siya malakas, halos hindi nga rinig pag nakasara ung hood.
    Isingit ko na rin, bale more than 2 months na kong puro short drive gusto ko sana itry ung "italian tune up" na nabasa ko dito. Wala naman ako balak iredline, siguro mga 4k rpm lang. Balak ko itry pag nachange oil. Ok naman ung makina ko, no leaks, ok ang performance at fc. Mejo may ingay lang talaga ung valves. Makakasama ba kung itry ko ung italian tune up.
    Mga sir dito ko na naitanung since nagreply agad si sir stock. Salamat.
    #420
    Civic 2000. Tia.
    In my opinion, those viscosity are thicker than needed for a Civic EK. Fuel efficiency would suffer a bit. With my 2001 Accord before, I use either 5w40 (Shell HX7) or 10w40 (Valvoline) semi-synthetic. You can also use the 10w30 mineral oil from Honda. Another good suggestion is Zic 10w40.
Best Oil/Fuel Filters
