Page 15 of 70 FirstFirst ... 51112131415161718192565 ... LastLast
Results 281 to 300 of 1387
    Mar 2012
    #281
    Quote Originally Posted by kkreuk18 View Post
    Iba pa din kasi ang hid projectors, malapad at mas intense ang output. Maganda sana kung may makapagtry ng brightest led available sa hid projector
    Sent from my R7plusf using Tapatalk
    I have always been vocal against projector system na basta na lang kakabitan ng led bulb that is not specifically designed for a projector or halogen housing just because the base/mounting fits. Sorry but it will always have a shitty output if compare mo sa properly retrofitted hid.
    The led projectors na nasa top tier as of now is still not available sa pinas and is so expensive for most people that are not into headlight hobby/enthusiast. Yung i-led is also good option in price, cut-off and beam pattern, but not as good as proper retrofit when it comes to performance. Redline has led projectors not sure if it is i-led.
    The M-leds by morimoto can stand its ground if compare siya sa mini d2s 4.0. May thorough test na ginawa si Sam Colt at nasa headlight junkies fb group ang post. Wall shots (lock exposure setting), and actual video of both system at real world test. M-led has same if not better distance than mini d2s 4.0 pero the mini d2s excels in light width over the M-led. But then wala pa sa atin ito and mahal pa as of now. kahit yung ginamit ni sam colt sa test niya ay prototype version pa yun and I'm not sure if modded pa. Ang mga seller sa US presale pa as of now ang Mleds.
    Also isa sa mga advantage ng leds over hid is during flashing or start up time. Instant ang led if compare sa hid.
    Jan 2008
    #282
    Quote Originally Posted by D3nb3r View Post
    Agree ako sir sa inyo, as of now nagpplano na nga ko na magparetrofit. Nun 2months old pa lang auto ko parang di pa kaya ng kalooban ko ipabiyak un HL ko, pero di ko kayang magdrive sa tagaytay na nakahalogen, nanggaling na din kasi sa hid. Kaya nilagyan ko ng hid un stock hL, meron namang improvement pero bitin talaga.
    Oct 2003
    #283
    I have until next week to decide kung kukuha ako ng G5-R kay paolo (xenon concepts). Sana nga ganun ka-noticeable difference from Q5-R.
    Jan 2008
    #284
    Quote Originally Posted by zechs View Post
    Mukhang dun na lang ako sa q5 sinabi nya kasi na maliit lang difference. Tsaka madami naman akong nakausap na very satisfied naman sila sa output ng q5 ni paolo
    Oct 2003
    #285
    Hmm..pagisipan ko pa rin siguro. Upgrade itch.
    Here's my osram cbi:
    Question is, should I stick with the Q5 muna and the osram cbi? So pa-open ung bagong headlights para ilipat doon ung Q5 then osram then pag nakulangan bago mag order nung G5? Truth is with the new headlight assemblies, gusto ko sana one-time lang i-open eh.
    Mar 2012
    #286
    Nice. congrats. looking forward sa mga output shots. If gusto mong isahang trabaho lang and less hassle i suggest diretso ka na g5.
    Oct 2003
    #287
    Kainis ang upgrade itch.
    Mar 2012
    #288
    I feel you. Dati kontento na ako sa philips 85122 ngayun philips xv c1 na binili ko. Sa car mods there is no such thing as "tama na"
    Dec 2014
    #289
    i am using NB on Q5 (35w ballast). I find it more than appropriate. I don't even use my all weather xenon H1 fogs when traversing mountain roads at 110kph. Except when there's heavy fog. Be it city, highway my Q5 + NB are more than enough for my lighting needs.
    #290
    traversing mountain roads at 110 kph...
    hmmm...
    Oct 2003
    #291
    *hypnos,
    NB..nightbreakers?
    Dec 2014
    #292
    *hypnos,
    NB..nightbreakers?
    yes sir. huper c30 tint on the windshield and vkool oem05 at the windows
    Jan 2008
    #293
    Next month magpapalagay na din ako ng q5 projectors at philips 85122+ 4300K.
    Mar 2012
    #294
    hmmm...
    When we went to bukidnon before, I tried to drive fast on rough unpaved roads with loose gravel going to dahilayan just to try how a 4x2 vs 4x4h setting feels. And also wanna experience rally style driving hahaha. I like how dirt flies behind you and the cloud of dust view on my rear view mirror. Sa 4x2 sumasayaw sa corners ang pwet ng vehicle ko but nung nag 4x4h na ang sarap mag corner. di ko namalayan pag tingin ko sa dash ko mga 98kph na pala takbo ko. I did that na walang ibang sasakyan or tao dahil mostly pineapple plantation dinaanan ko.
    But if night driving I won't drive that fast kahit naka fxr 3.0 with philips 85122 ako that time.
    #295
    Comparison of stock halogens (top), plug and play LEDs (middle), and HID retrofit (bottom):
    Out of curiosity, if anyone with plug and play LEDs wants to prove that their LED is brighter than an HID retrofit, I'll be willing to meet up and compare side by side with my HID retrofitted car and/or my other car with OEM LED. Para naman mapatunayan talaga ng mga plug and play LED fanatics na mas superior ilaw nila. 😉
    Oct 2009
    #296
    iba talaga buga ng naka HID projector..magkano po ba ang set hid,projector + H4 connector harness .ako nalang mag install.
    Mar 2012
    #297
    hmmm, familiar ta a. Parang kay ceasar rowinski of lightwerz na pics to.
    eto pa, this one is from el stig pics. medyo off ang rotational alignment ng cut-off but you get the point
    Aug 2004
    #298
    Based on those pics parang mas ok pa tuloy ang OEM halogens compared to plug and play LEDs.
    Mar 2012
    #299
    Meron naman malalakas na led bulbs pero pag sinalpak sa projector which is not designed for that led bulb ay sira ang optics.
    Yup a stock halogen HL is better if walang proper alignment or output ang PnP, not just sa led but also hid system.
    #300
    Yes bro just saw it reposted by Tots on FB from another source.
    Kaya nga gusto kong makakita ng side by side ng stock halogen/HID/LED vs PnP LED para makita talaga which has better road lighting (not just sheer silaw).
    Quoting our high school hymn - "In pursuit of the untarnished truth." 😄
Planning on getting an HID retrofit
