Page 5 of 35 FirstFirst 12345678915 ... LastLast
Results 81 to 100 of 1387
    May 2017
    Okay sana pero no h7 led
    Sent from my SM-A720F using Tsikot Forums mobile app
    Oct 2015
    Quote Originally Posted by Cascat View Post
    I just noticed sa projector mo pala gagamitin. Plug and play LED bulbs are not meant to be used on projectors. Out of focus most of the time and walang hotspot. Better have it retrofitted with a proper hid projector.
    Aug 2012
    Official Philips model LED is only available in H4 and H11/H16 base types. It is their Ultinon series.
    Sent from my ASUS_Z010D using Tapatalk
    Oct 2015
    for fortuner 2016, can i just buy a bulb and replace the stock halogen projector bulbs? No alignment needed?
    Aug 2012
    Quote Originally Posted by apt2a View Post
    Maybe yes, maybe no. It will depend on the result after you replace the bulb.
    Oct 2015
    Yes you can. But the stock projector was designed for halogen bulbs, so it will scatter some light elsewhere instead of just below the cutoff. Having it retrofitted with a good brand 3" hid projector with clear lens and hid bulb will produce a better result, about 3x brighter, more intense, and more focused light on the road.
    Oct 2015
    Quote Originally Posted by aar0nix View Post
    ok would go on this. tiis tiis muna ngayon. Nahihinaan kasi ako sobra sa stock HL ng fortuner. i have a magic tint (dark outside, 90% clear inside) and medyo nahihirapan ako mag drive sa gabi.
    Apr 2014
    It worked for my mux. Most likely no prob rin yan sayo
    May 2017
    Anung hotspot? Im looking for led. No plans on switching to hid.
    Sent from my SM-A720F using Tapatalk
    Oct 2015
    I suggest you go to youtube and explore more about automotive headlights, hotspots, hid retrofits.
    Skip the led bulb on halogen projector part and get a proper hid retrofit. You will thank me for suggesting it. Besides, this is an HID retrofit thread, not an LED bulb thread. 😉
    May 2017
    Nice thank u
    Oct 2014
    For Xenon Concepts ito install nila sakin for my Innova
    Imgur: The most awesome images on the Internet
    Malinis ang gawa. Home Service rin. next project ko sakanila e gawing LED yung Angel eyes. Pagka-alam ko is halogen pa ung ring nyan. so pag ON mo di pa ganun ka linaw. medyo after 2 to 3 minutes pa bago siya lilinaw.
    Concern ko lang since our place ginawa medyo hirap sila sa alignment. so ako nalang nag align pag dating ng gabi. madali lang naman at tinuro sakin ang process.
    Mar 2012
    I was reading this thread since im planning to replace the stock projector of my 2016 mitsubishi strada GT.
    Tama si sir walter dun sa comment nya na medyo overated si garyq.
    Nag pm ako sa kanila dati na upgrade ko headlight ko and they keep on insisting na walang d5s na bulb. Sabi ko kaya nga upgrade ko headlight ko dahil sa d5s ang bulb ko and bitin ako sa output and 25w lang available na oem ngayun. Ang sagot sa akin is wala daw d5s na bulb baka marketing strategy lang daw. I know na hindi siguro so gary q yung sumagot sa akin dahil ilang taon na sa HIDplanet forum dinidiscuss ang d5s. Kaya scratch ko sa list c garyq.
    Redline nag retrofit sa previous gen strada ko dati and ok naman ang 3" fxr 3.0 + philips 85122. Medyo disappointed lang ako nung makita ko ang ballast ma gamit dahil sa stage 3 ko na retrofit i was expecting a morimoto xb35. So parang scratch ko na rin redline sa list ko. Also 2x busted ang passeger side ballast kahit under warranty pa nag pm ako kay tots walang dumating sa akin.
    Oh, taga mindanao po pala ako kaya tinatanggal ko headlight ko para ipa lbc sa manila para ma retrofit.
    Next option ko is xenon concept for their competetive price and firedrake.
    Sent from my SM-J710GN using Tapatalk
    Oct 2009
    Can you guys share your actual experience with HID retrofits? I keep seeing bad feedback about HIDs (ballasts going bad in a few months, warning coming from the ECU from time to time, moisture getting in, etc..)
    Has anything bad happened to your retrofits? How long do the bulbs and ballasts usually last?
    I have contacted the retrofit shops mentioned here. Xenon concepts is the least expensive-- 10k for an OEM looking retrofit using NHK projectors and bulbs, additional 4k for OEM bulbs. HIDretrofit told me 19k but I am not sure if the bulbs are OEM at this price.
    Anyway, I am just worried that I have problems if i push through with the retrofit so please share your experiences. thanks!
    Quote Originally Posted by mousemouse View Post
    Anyway, I am just worried that I have problems so I want to hear your actual experiences.
    My HID retrofits from Redline are almost 2 years old and are still doing fine. Paid 20k before. NHK ballasts and bulbs.
    Mar 2015
    yun sa ES, 3yrs na. FD, 2yrs.
    both from xenon
    Oct 2009
    *jut703, ads13- thanks! I think redline quoted me 17k for the stage 2 retrofit. By the way, were you present when they did the retrofit? I see photos from Xenon concepts showing opened headlights while still mounted on the car while I've also seen photos from other shops showing disassembled bumpers, etc.. Or is bumper removal dependent on the car?
    Mar 2015
    I'm not present, my brother arranged it for me
    i think they need to disassemble the bumper for easy access.
    with stage 2 they will cut the housing to fit the projector
    Oct 2009
    okay got it, thanks for the photos!
    Quote Originally Posted by ads13 View Post
    Jun 2005
    I watched as xenon concepts installed projectors on my vios.
    They had to undo the bumper because one of the bolts is under the bumper.
    When they got the headlight housing, they used a couple of screw drivers and removed a few screws and a heatgun to melt the sealant. When the sealant is soft, they used screw drivers to pry the assembly open.
    When opened, they removed the clips that hold the h4 bulbs and then slid the projectors in the reflector bowl and bolted it to the headlight assembly.
    The pic of the headlght attached with no cover was done to aim the headlight to the wall.
    Once aligned, they add more butyl sealant, heated the remaining sealant and force fitted the cover then locked the latches and finally put on the screw.
    3 hours to do.
Planning on getting an HID retrofit
