Page 65 of 70 FirstFirst ... 1555616263646566676869 ... LastLast
Results 1,281 to 1,300 of 1387
    #1281
    Quote Originally Posted by ealdree View Post
    Just noticed that retrofitted projectors on my hi beams lean towards the center. Is this the normal setup?
    can't they be adjusted?
    are these assemblies unique as either for left-hand drive or right-hand drive vehicles?
    #1282
    U have to change the internal light shield.
    #1283
    Had dinner with a friend who had Keon Sondra LED bulbs in his Vios' stock halogen projector.
    KS sellers always claim superior output with 1 gazillion lumens (which isn't even the right measure). Compared low beam output with the stock LED headlamps of my Civic:
    Stock LED has more defined cutoff and farther throw, KS output is concentrated to foreground.
    To be fair, the KS LED on halogen projectors wasn't glaring when viewed head on or through your side mirrors.
    Dec 2019
    #1284
    Could it also be the quality of the projector lenses in the vios vs the lenses in the civic? Since the civic is more premium baka better quality din ung sa civic.
    Tbf the KS LEDs in my forty also light up the foreground (hotspot) but it throws really far still.
    #1285
    Quote Originally Posted by hdj80 View Post
    Variables, possible....the ideal comparison would be them on similar cars.
    #1286
    You can't retrofit KS LEDs on cars that come with factory LEDs because KS LEDs only work on halogen sockets. There are a few cars that come with LED projectors (as opposed to the jewel-type LEDs on the Hondas) so maybe you can fit KS there, but why would someone with OEM-spec LEDs replace theirs with KS.
    Dec 2019
    #1287
    Thats true. And of course iba pa rin ung buga ng oem LEDs. I was side by side with a new mazda 3 hatch last night and its oem led was brighter by a bit and had a clearer cutoff with no hotspots. While my KS leds were ok it had a farther throw and more yellow light cuz i got the 5000k color.
    #1288
    Jun 2016
    #1289
    Any feedback on Ailecar and Flying Eagle D2S projectors? How do they compare to NHK hella G5 projectors, performance wise?
    Oct 2003
    #1290
    Hella G5-R on Osram CBB D2S
    Low beam
    High beam
    Oct 2019
    #1291
    Because of 'hype'.. mema.. memasabing naka KS Led.
    Dec 2016
    #1292
    Hi Team,
    Hope all is well.
    Hingi lang sana feedback if worth it ba mag-upgrade to Projector HL from stock ng Mirage G4. A shop in fairview quoted me php7,500 all in for AES projector CCFL. mura na po ba since budget meal na upgrade lang hanap ko.
    Thanks Team!
    #1293
    Quote Originally Posted by kamotekid1968 View Post
    Hi Team,
    Hope all is well.
    Thanks Team!
    why? stock too dark? or, tint too dark?
    if the latter, remove it.
    Jan 2008
    #1294
    Mini h1? Not sure glass un lens ng aes projectors, un iba kasi plastic. Konti na lang nhk koito q5 na kay xenon concepts.
    Sent from my Redmi Note 8 Pro using Tapatalk
    Dec 2016
    #1295
    thanks doc! i have medium tint installed (wrapped) so i am thinking upgrading would be the best case. i am not familiar sa mga brands ng projector and upon sifting sa thread na to, i noticed AES is the cheapest with poorest performance based on feedback.
    Dec 2016
    #1296
    thanks sir * kkreuk18, i believe the shop will retrain my HL assembly and will just replace the bulb? so plastic padin...
    Jan 2008
    #1297
    What I mean ay un mismong projectors na ikakabit sa yo na aes ay baka plastic un lens. Basta maipapayo ko sa yo ay dagdagan mo un budget para dun ka na sa tried and tested kumbaga
    Dec 2016
    #1298
    thanks you sir kkreuk18! much appreciated!
    the above brand and shop is noted. will sift thru their profile online to check for feedback. di ba sila overpriced for the said item with install?
    Jan 2008
    #1299
    Actually sila na pinakamura na quality ang gawa
    Dec 2016
    #1300
    thanks sir! lastly, what "stage" would you recommend (e.g. stage 2 or 2.5)? i have been reading this thread the last few days since hindi ako familiar sa projector bulbs and brands. parang NHK is the runaway winner budget wise.
Planning on getting an HID retrofit
