ito bro. daming matututunan...
Water Pump > Aisin Aftermarket
salamat bro! watching vids online, i think kailangan ko pagawa sa mechanic muna; para makita ko paano pasukin LOL
pero mukhang kaya DIY after ko makita pano baklasin hehehe
btw found this thread in vcp .. not exactly the same issue but close
Login
author=jcboy link=topic=40695.msg927223#msg927223 date=1414676153
Go with the cheapest route ALWAYS. (well as much as possible)
1) replace with original Radiator CAP --often neglected.
2) replace thermoswitch --original as what has been mentioned, since aftermarket thermoswitches are not calibrated with OEM specs (degrees Celsius when opening), let alone racing thermoswitches have a lower "open" temp.
3) replace thermostat --or just check it. rarely do thermostats break down. siguro 10-15 years is the average lifespan sa mga nasisiraan nito, pero of course 7-10 years pwede mo na siguro palitan.
4) check/replace rad fan --minsan kahit umiikot hindi na pala ganun kabilis/kalakas, kaya you need to have 2nd opinions kung kumusta ba pagikot ng rad fan mo.
5) replace radiator --minsan barado na pala sa ilalim kaya hindi umiikot tubig. yung kalawang kasi ng radiator sa ilalim nagaaccumulate. kaya minsan kahit malinaw pag sinilip sa butas yung water/bakal na fins nya, nagooverheat ka pa din. yun pala hindi nakakadaan yung coolant/water.
6) head gasket --ayan tinamad na ako, so pag the 5 steps do not seem to work, paconsult mo na sa trusted shops.
HTH.
author=deathscythell link=topic=40695.msg927408#msg927408 date=1414994054
Maraming salamat mga sirs. Lahat nung mga suggestion nyo chneck namin - ok nman. Ni-trace din namin ung mga dinadaanan ng tubig baka may leak pero wala naman. Before kami dumiretso sa head gasket (kasi mahal daw kapag kinalas un) chneck muna nmin water pump and ayun, water pump daw yung sira. Nung ni-replace nmin nag-ok na. Dagdag kaalaman.
Thank you ulit mga sirs.
