Results 81 to 90 of 287
- 54,283
December 13th, 2017 01:53 AM #81if you mean, the hose has already been replaced since the car got out of the factory, these are some pointers, but are not absolute:
1. the hoses don't match.
2. the hose clamps need a screwdriver to tighten. original factory hose clamps are usually simple spring clips.
3. the hose looks very new.
4. someone confessed to having replaced the hose.
but if you mean for signs, that one needs to replace the hose:
1. there is an obvious leak in that hose.
2. there are cracks on the hose.
3. the hose feels soft. (this is subjective. one has to have had some experience on how soft it should not be.)
- Jan 2018
- 8
January 14th, 2018 12:38 AM #82Mga sir yung akin po corolla 1.3 na overheat pag nag aaircon ano kaya prob? pero di nman sya agad agad na overhea mga after 1 hour sa city driving.. pag rekta hindi nman na overheat.. why why?
- Nov 2017
- 242
January 14th, 2018 07:39 AM #83Check your auxiliary fan at baka hindi umiikot pag nag aircon ka.
Sent from my Redmi Note 4 using Tsikot Forums mobile app
- Nov 2017
- 1,748
January 14th, 2018 08:21 AM #84
January 15th, 2018 04:02 PM #85
Sometimes, the overheat condition is not caused by faulty cooling system but rather a result of an engine condition.
The source of the heat that needs to be regulated is the internal combustion engine. If the combustion conditions are not right, the engine will overheat.
Take the condition of too lean air/fuel ratio or engine vacuum leak, if the oxygen content in the combustion chamber is too high, the combustion temperatures go high too.
In comparison, an oxy/acetylene torch, to increase the temperature of the flame you add more oxygen to a point where the fire does not extinguish. At the tip of the nucleus of the flame exists the highest temperature.
- Jul 2017
- 16
February 15th, 2018 12:52 AM #86Hi Mga ka tsikot makikiride lng po kay TS... ask lng po ako regarding sa sasakyan ko. Muntik po ako mgoverheat dahil nabutas po ung lower hose ko sa radiator napalitan na po sya ng bago pero ang concern ko po ngaun eh pag inistart ko po ung sasakyan ko ng walang naka off ung aircon tuloy tuloy ang akyat ng temp. hindi na sya nababa pero kapag from cold start pinaandar ko ung sasakyan ng naka aircon ok naman ung temp. sa fan motor assembly na po kaya ang sira nun? bagong palit lang din po ang thermostat ko. tapos pansin ko rin po pag inistart sya ng walang aircon tska lang nag oon ung fan pag umabot na ng 100celsius ung temp may bluetooth obd po kasi ako kaya namomonitor ko po ung temp.
tska po kung sakali man na fan motor assembly na ang problem ok lang po ba na replacement na lang ang ipalit sobra po kasi mahal ng orig parts. Mazda 3 2004 model po sasakyan ko. Salamat po ng marami!!!
February 15th, 2018 01:38 AM #87
Ok naman replacement basta from OEM manufacturer preferably Japan company. Yung top rad hose mo dapat pinapalitan mo na din kasi kung bumigay yung sa baba mo, baka malapit na din sumunod yung isa. Just to be sure. Also hindi pa na barado radiator mo? Baka naman kasi marumi na din. Use coolant and distilled water preferably sa engine cooling system mo.
Sent from my LG-H990 using TapatalkFasten your seatbelt! Or else...Driven To Thrill!
- Nov 2016
- 29
March 28th, 2018 09:41 PM #88First of all, I apologize for hijacking this thread. I would create my own thread but Tsikot forum's anti-spam measure prevents me from doing so.
Bale meron po akong 1997 na Honda Civic. Nung nakuha ko po siya, naka rekta yung fan niya tapos wala siyang thermostat. May mga nabasa ako dito sa Tsikot forum at sa mga FB Car groups na hindi daw okay yung ganung setup kaya naisipan ko siya ipabalik sa normal. Kaya bumili ako ng original honda thermostat at thermoswitch.
Fast forward sa naikabit na yung thermostat and thermoswitch. Dun na lumabas ang problema. Nag ooverheat na yung kotse. Pina overhaul ko yung radiator ko kaso parang walang nagbago, overheat pa rin.
Kanina, tinanggal na lang nung mekaniko yung thermostat at binalik sa rekta yung fan. Ayun, di na nag overheat.
Sinisisi niya yung thermostat. Pagkauwi ko, pinakuluan ko agad yung thermostat at bumuka naman siya 100% so malamang hindi yun ang prob?
Btw, additional detail lang, pansin ko pala pag andun na siya sa point na nag ooverheat siya, napupuno ng mainit na tubig yung reservoir.
Any ideas or suggestions po kung ano kaya ang problema at kung ano pwede ko gawin? Water pump kaya or radiator cap? Di kaya baliktad lang pagkakakabit nung mekaniko sa thermostat?
April 8th, 2018 07:45 PM #89
- Dec 2017
- 1,018
April 8th, 2018 09:32 PM #90I recently had a radiator preventive maintenance check. I had a lavramon flush.
Mechanic told me to buy a brand new radiator because the head assembly is already cracked.
Brand new radiator is around P3,900 (civic). He also told me to buy a new thermostat and new radiator cap. I told him it never overheated for such a long time, why replace something not broken? He told me there is always a risk of overheating so it is best practice to change everything because it's a new radiator. Everything must be replaced as a set. He also told me never to flood the reservoir. There is a max level indicated on the reservoir. If I want to top up, it should be at that max line only.
I hope this helps you.
OT: Since you have a 97 civic, have you changed your timing belt already? You should be worried if you haven't as it can break anytime and destroy your valves. Timing belt change includes the water pump, tensioner and two oil seals. While at it, have your valves adjusted as well.
How about 97 LXi?
Civic horsepower
