Page 53 of 145 FirstFirst ... 34349505152535455565763103 ... LastLast
Results 521 to 530 of 1447
    Apr 2008
    #521
    Quote Originally Posted by Yodelehiyo View Post
    sabi nga nya try q daw muna pachange gear oil, pag ayaw padin bka daw synchronizer, ibababa transmission, pag binaba ung transmission dun daw masisilip na lahat pati ung sa mga clutch, kpag po ba ng palit ng clutch disc kailangan ibaba ung transmission?
    AFAIK Hindi naman kailangan ibaba ang transmission para makita kung ubos na ang clutch. Yung mekaniko ko sumisilip lang sa ilalim ng dash. Ilan ba talaga ang mileage mo? Parang ang tindi naman kapag ibababa pa ang transmission.
    Sent from my GT-I9100 using Tapatalk 2
    Apr 2008
    #522
    ask ko lng din mga sir (2002 revo GLX)
    ung headlight at front grill ko gusto ko kasi palitan,
    ang gus2 ko sana ilagay e ung headlight at front grill na pang 2003 revo SR, pwede kaya? mas pogi kasi tgnan yun
    may nakapagtry na po ba nun,.. thanks in advance
    Pwede naman. I've seen 1st gen Revo's made to look like 3rd gen. Lahat naman kumakasya eh. Walang problema basta makahanap ka ng pyesa.
    #523
    i like the first gen's headlights. glass. not scratchable and/or cataractic plastic.
    Apr 2008
    #524
    Not very bright though. I'm actually considering replacing them with aftermarket Depo multireflector units. Any way I can make them brighter without changing the headlamp assembly? AFAIK, bluish white xenons are not very effective with frosted headlamps.
    Jan 2014
    #525
    Quote Originally Posted by GTi View Post
    373897 yan po ung nkasulat na reading sa odometer ko, di q kasi alam magbasa nun :P humihirap kc talaga sya ipasok sa 1st at 2nd kpag na warm up na ung revo, ginagawa q minsan para pumasok sa 1st gear, pinapasok ko muna sa 2nd tapos pasok sa 1st, pero pag ka pasok ko sa 1st parang my ng cacrank sound nadin pero konti lng
    Jan 2014
    #526
    ung ilaw ko po kasi hindi pantay, kita q kasi kapag gabi. ung left headlight ko mas malayo ung tama nung ilaw nya kya parang sabog na ung ilaw, hirap tuloy aq makakita kpag gabi na.heavily tinted pa kc ung revo, planning to buy a HID light para luminaw, may mga klase kasi 4k, 6k, 8k version anu ba pinagkaiba nila, mas malakas?
    nagtanung din aq kung magkanu ung pang revo. sabi P3,500 daw un ung may hi and low sabi nila
    #527
    e, 'di adjust mo ang asinta! madali namang gawin yan, e..
    at bossing naman... tanggalin mo na lang ang heavily tinted mo, bago mo paglaruan ang headlight intensity mo..
    maawa ka naman samen!
    Jan 2014
    #528
    un na kasi ung tint nya dati pa, tska okay din kasi ndi masyado pumapasok ung init sa loob, pano po ba iadjust ung asinta?
    badtrip din kasi ung mga kasalubong ko sa daan puro nka hid yata, ang sakit sa mata, walang palag ung ilaw ko kahit naka bright, kaya balak ko palagyan ng hid pag nakaipon ako para headlight war kami :D
    Apr 2008
    #529
    Grabe bro! 373tkms?! How much did you buy the Revo for? In comparison, our Revo has only ran 106tkms, and it is a daily driver. At this mileage I wouldn't be too surprised if the engine needed an overhaul already. Basta patingnan mo. Malay natin, baka simple lang pala ang problema. Dun sa headlight, change to lighter tint muna if you are having difficulty. Kung hirap parin, you can have the headlights adjusted, or replaced with that of the newer model if you want. Does your unit have foglights? You can probably work on those as well.
    Jan 2014
    #530
    yan po picture ng odometer ko, wow ang laki ng difference ah, baka naging X taxi ung revo namin di ko alam. kaya sobrabg taas ng reading (
    280k namin nabili 2002 GLX all power.diesel, tsssk, sayang wala pa kasi ako alam masyado sa pagtingin ng sasakyan bago bumili, di rin nmn kasi aq bumili si papa
    pano po ba malalaman kung kailangan na ng overhaul ng engine? pero sabi ng mechanic namin dati wala pa nmn daw blow by?
    my foglights pero maliit
Toyota Revo Owner's Club Details
