Page 53 of 73 FirstFirst ... 34349505152535455565763 ... LastLast
Results 1,041 to 1,060 of 1447
    Apr 2008
    #1041
    Quote Originally Posted by jvnj View Post
    Wow, ang lakas pala talaga sa gas. Anyway I think yung 4-6km/li is sa Auto Transmission, yung Manual is parang 5-7 in city (malakas pa din talaga). Kung ganun, mas matipid pa pala yung 2.4li na Previa?
    Siguro more or less the same. The Previa has a much more modern engine and so makes much more power.
    Sent from my SM-G900I using Tapatalk
    Sep 2010
    #1042
    I have a revo DLX 2002 model. It's my first car bought brand new. Ok pa ang kaha, pero mausok tambutso. Sabi ng mechanic iPa compression test ko. Suspects a Nya need top over haul. Saan Pwede mag pa compression test dito Sa cavite/ las pinas area. Saan in Pwede mag pa top overhaul na reliable shop. How much ang magagastos? Thanks po Sa mga sasagot
    Aug 2011
    #1043
    Good pm tsikoteers. Anyone here have owners manual ng toyota revo diesel?
    Sent from my SM-J200GU using Tsikot Forums mobile app
    May 2009
    #1044
    Quote Originally Posted by Buging_King View Post
    BTW, where to service especially yung pag correct ng mixture ng air gas via ECU?
    bahala na po si kompyuter na magadjust....
    as per advise ng iba forumers, yung diesel revo (2L engine) ang mas maganda siguro na makuha....around P300k siguro maganda ganda pa manakbo at mahusay pa ang kaha. depende sa alaga nung previous owner.
    Apr 2011
    #1045
    during my journey napansin ko mataas ang level ng preno ko pero kumakagat naman.hydrovac na po kaya ito.may remedy pa po kaya? bago ako magpalit ng hyrovac.ano pong magandang brand at nasa magkano.
    sa clutch ko naman.nag iba ang setting sa normal mataas na naman.e ka aadjust ko lang sa may ilalim ng driver side.kung adjust ko ulit baka mahugot na ung rod.pa comment po
    Maraming pong salamat
    #1046
    Quote Originally Posted by greg2 View Post
    When you say mataas and level, matigas ba syang apakan? If not, baka naman kelangan lang ng adjustments. Kung tumitigas na apakan, yun malamang ang Hydrovac. Check nyo din yung connecting hoses baka may leak na.
    Yung sa clutch, pwede nyo naman masilip kung malapit na sya mahugot, kung may clearance pa (exposed thread pa), then pwede mo pa i adjust. Kung paiba-iba na yung level nya, maaring may malapit nang bumigay, either yung master or secondary ang kelangan nyo nang palitan. Just in case, don't go for those repair kits, experience ko di din gaano tumatagal, mas maganda yung assembly na, kahit yung japan made OK na.
    Apr 2011
    #1047
    opo matigas apakan ung preno,napansin ko sa express way,pero pag city lang okay naman.malambot.sa clutch un nga po pag sa expressway mataas siya.pero pag city driving na bumabalik ung dati kong setting na malambot
    Nov 2016
    #1048
    hello, mga sir ask ko lang anong ngyari sa aircon ko bihira ko lang kasi gamitin sasakyan ko revo minsan sa 1 weeks isang beses lang or dalawang beses 2001 GAS so ngayon nawala ung aircon niya hindi na siya malamig dinala ko sa aircon repair sabe compressor daw pwede pa kaya maayos un?
    ANY TIPS: salamat...
    #1049
    Quote Originally Posted by Aastig01 View Post
    yes and no.
    a while back, a popular compressor brand was advertising that they can fix their leaking compressors. but they added that the fix may not last "long". sabi ko sa sarili, "just long enough to sell the car. heh heh."
    aside from the compressor, other sources of leak include the tubings and everything else. these can be fixed thru replacement. others say they can be welded, but it needs special welding materiel and skill.
    when replacing, the replacement parts can be either oem (expensive!) or replacement cheapies. "it's up to you."
    good luck, po.
    Aug 2011
    #1050
    Guys. Sino po meron owners manual ng revo diesel. Tia.
    Aug 2012
    #1051
    Quote Originally Posted by jncp9886 View Post
    Owners manual ba? PM me your email address, I will send you a copy.
    Sent from my D5833 using Tapatalk
    Aug 2011
    #1052
    Quote Originally Posted by red_one View Post
    jncp9886*yahoo.com
    Tia
    Nov 2016
    #1053
    hi guys sinong my owners manual jan ng revo SR 2001 model pa send naman ako.as ko lang din mga sir anong magandang spark plug kasi balak ko palitan ng iridium spark plug tama lang ba un hindi ba lalaki ang consume ng gas anong epikto nito.?any tips salamat.
    Nov 2016
    #1054
    hi guys sinong my owners manual jan ng revo SR 2001 my email add.ansary.solaiman*yahoo.com model pa send naman ako.!as ko lang din mga sir anong magandang spark plug kasi balak ko palitan ng iridium spark plug tama lang ba un hindi ba lalaki ang consume ng gas anong epikto nito.?any tips salamat.
    Aug 2012
    #1055
    jncp9886*yahoo.com
    Tia
    Manual sent
    Aug 2012
    #1056
    Manual sent.
    Aug 2011
    #1057
    Good am guys. Anyone here installed car voltmeter on revo? And also a dashcam? May nakita ako sa lazada but interested in getting inputs muna sa mga naka bili na. Tnx
    #1058
    i don't have a voltmeter in my car now, but we practically grew up on' 'em way back in the 60s.
    the problem, as i see it, is where to mount the meter. hassle kung sa ilalim ng dash, at ayaw kong butasin ang dash.
    Aug 2011
    #1059
    Sorry my message wasnt clear. The voltmeter i meant ung nilalagay sa cig plug na may usb port. Tapos budget for dashcam around 2-3k pesos. Plano ko kasi bumili sa lazada but getting advices first.
    #1060
    the cigarette lighter plug-in? i used to have one. ok siya to monitor charging system integrity.
Toyota Revo Owner's Club Details
