Page 57 of 73 FirstFirst ... 74753545556575859606167 ... LastLast
Results 1,121 to 1,140 of 1447
    Mar 2017
    #1121
    thanks mga sir sa advice, ill used na ung high octane gasoline pero ganun pa rin. Ill na rin ung oil na high viscosity and fully synthetic ganun pa rin. Ung sound nya ay tik tik tik. Pag mabilis ang rebolusyon mabilis din tik tik ng makina. sabi ng mekaniko nanggaling daw ung tunog sa hydrolic valve loose na daw ung spring kailangan palitan. Ung lagatik na yan last 5 years ago pa simula nung pinatop overhaul nmin.
    #1122
    Quote Originally Posted by Now i know View Post
    Try nyo Sir patingnan sa ibang shops kung talagang sa valve lifter nga o sa injectors (rail) ang ingay. Mas mabuti na din na ma pin-point kung saan eksakto nanggagaling yung tunog. Ive had an FX and Revo which shares the same engine, though EFI yung sa Revo. Overtime mas tahimik pa yung FX as compared sa Revo, dahil pag tumagal maingay na yung injector rail. Though as mentioned, if this is the case, no worries as normal lang daw yun sa naluluma. Di naman ititirik.
    Jul 2016
    #1123
    Patanong naman po about my AT GLX Revo: Malakas manginig while naka-on yung aircon, especially when on idle. And humihina yung batak ng makina if i turn on the aircon. Parang nahihirapan din sha magshift to higher gear. Any ideas on what could possibly be the issue? I plan to bring it to the auto-repair shop to have it checked but I I don't want to go there clueless.
    #1124
    Quote Originally Posted by Ashra View Post
    Looks like a malfunctioning idle-up / servo. Dalhin nyo Sir sa reputable shops and see if gumagana yung idle up / servo nyo, kung minsan nakukuha yun sa linis lang. Nababarahan kasi yun ng alikabok overtime. Make sure the technician uses contact cleaner or carb cleaner sa paglinis ng idle-up. Goodluck Sir!
    Jul 2016
    #1125
    Quote Originally Posted by jvnj View Post
    Thanks Sir! Pacheck ko na lang sa weekend.
    Jan 2017
    #1126
    Mga baka may idea kayo magkano alternator for revo SR, baka may recommended shop din kayo sa south area (muntinlupa, san pedro, las pinas, paranaque)
    #1127
    Quote Originally Posted by Chi-SR View Post
    if i were me, i'd have my alternator fixed, instead of buying a surplus unit.
    the surplus unit might be in need of fixin' after a short while.
    ^ korek ka jan doc.
    I'm from the south and some time ago i brought my busted alternator to the highly recommendesd yok's electrical in qc to have it repaired. Sulit ang biyahe because it's back to being its primo self til now 👍
    to be or not to be, that always confuses me!
    Jan 2017
    #1129
    Salamat sa input, actually that the first option "repair", if ever lang na di maayos chaka lang magpapalit.
    #1130
    [QUOTE=Chi-SR;2813759]Salamat.
    Alternators, especially the one's installed in Revo's are not that complicated as compared to newer ones. Electrical shops are very very capable of replacing every parts of those alternators. Yes, its much cheaper too as compared to buying the whole surplus unit.
    #1131
    if you need to buy one, ask the alternator repair shop if they have one for sale.
    i feel the unit tends to be "more reliable", coming from a repair shop and not a surplus shop.
    Jan 2017
    #1132
    Update lang mga sir,
    Naparepair na yung alternator kapatid ko yung nag paayos inaabot ng 2k yung repair may pinalitan na parts kasi yung isang parang copper ring di na dinadaluyan ng kuryente. Medyo namahalan ako sa repair kasi konti na lang may makukuha ng surplus kaya lang due to lack of time dahil kailangan yung sasakyan, may advice din yung gumawa bago ito irepair kasi maliban dun sa pinalitan na parts may tama na daw dun sa pinaka cover (medyo di ko gets kasi yun lang yung term na ginamit ng kapatid ko) sabi ng gumawa hanap na daw kami ng reserba na alternator.
    Inofferan din pala yung kapatid ko ng set na alternator 9k presyo (di ko alam kung brand new, branded or oem)
    Need advice lang sana for next step.
    Naiisip ko is maghanap ng alternator for replacement or pa 2nd opinion ko yung newly repaired na alternator?
    Apr 2008
    #1133
    Sayang naman yung 2k na pinangayos mo kung papalit ka lang naman ulit ng bago. Hindi ba maayos ang pagfunction ng alternator ngayon? Stopgap measure lang ba ang ginawa nila? Kung wala na syang inilalabas na problema IMHO gamitin mo na muna. Tsaka na ang bagong alternator kung nagkasira ulit, marami naman mahahanapan nyan.
    Sent from my SM-G900I using Tapatalk
    #1134
    use it na lang until it fails again.
    for all you know, the guy was sales-talking you or setting himself up as a fortrune-teller of sorts.
    kung MT si revo, madaling i-push-start yan kung medyo mainit pa ang engine. heh heh.
    #1135
    Hanap ka na lang ng ibang shop Sir. Sorry for the rude word, pero pineperahan ka lang nyan. The fact na wala syang parts dun sa sinasabi nyang supposed na kelangang palitan eh, incompetent yung shop nya. Sobrang luma at simple lang ng alternator ng Revo as compared to newer cars, madami yang surplus. As mentioned above by our guru's, gamitin mo na lang muna para masulit mo naman yung ginastos mo, tapos pag nasira uli dalhin mo na sa ibang shop. At least may time ka pa para makapag research ng ibang magagaling na electrical shop.
    Goodluck!
    Jan 2017
    #1136
    salamat sa sagot mga sir, nag ikot ako sa evangelista to check yung price ng alternator 4 na store yung natanungan ko lahat ng presyo 4.5k surplus/recon, ang warranty range ng 2-3mos.
    after ko magikot dun lang din ako napaisip na baka pwede pa maayos yung tinanggal na parts dun sa alternator kasi lahat nung 4 na shop nagrecommend na dalin muna dun dahil may chance pa daw na maayos yun. kung di lang talaga emergency ang ngyari baka humanap pa kami ng ibang option. sana lang maayos yung pagkagawa at di agad bumigay.
    salamat sa mga response mga sir.
    Apr 2008
    #1137
    Nagpagawa ako sa Barrera's sa may Abad Santos when I had alternator problems with our Revo. Ok kausap ang boss at maganda naman ang pagkakagawa. They installed a higher capacity refurbished alternator. So far so good.
    Jun 2012
    #1138
    Quote Originally Posted by GTi View Post
    Bad experience ako dyan sa barera. Sabi bagong piyesa nilagay, luma naman pala. Sinunagling. Sa red mas ok, along quiricada. Malapit lang dyan sa barera
    Sent from my SM-A9000 using Tapatalk
    Apr 2008
    #1139
    Quote Originally Posted by dct View Post
    Ganon? Electricals din yang Red?
    So far ok naman ako sa Barrera. Tatlong sasakyan na ang naidala ko diyan. Sinasabi naman nila sa akin na surplus ang piyesa if something needed replacing.
    Jun 2012
    #1140
    Yup. Red electrical something ang pangalan. Along quiricada kasi sya kaya di agad makita. Unlike barrera na corner talaga sa may abad santos
Toyota Revo Owner's Club Details
