Page 55 of 73 FirstFirst ... 54551525354555657585965 ... LastLast
Results 1,081 to 1,100 of 1447
    Jul 2016
    #1081
    Mga master patulong po. Sino po may manual ng 2004 vx200? Puede po pasend naman s email. mjcanilang*gmail.com tapus tanung ko lng kung may gumagamit po ba ng castrol magnatec sa mga revo gas engine? Kmusta po ang performance ng oil na to? At anung model number ng oil filter ng vx200 2004 model sa Bosch?
    Aug 2012
    #1082
    Quote Originally Posted by mjcanilang View Post
    Owners manual or service manual ang need mo? I have copy of owners manual only.
    Sent from my D5833 using Tapatalk
    Jul 2016
    #1083
    Quote Originally Posted by red_one View Post
    Yes po. Malaking tulong po. Pkisend na lng po sa email ko. Salamat po.
    Aug 2012
    #1084
    Email sent.
    Jul 2016
    #1085
    Salamat po sa manual. I have a big question. What would be the speed of a revo per thousand of rpm. At sa gear nya. Example mine is at 3000 rpm tumatakbo lng siya ng 95 kph. Alam ko may ibibigay pa kaya lng gas conscious ako kaya di ko na pinapaakyat pa beyond 3000 rpm.
    Sent from my D5833 using Tapatalk[/QUOTE]
    Aug 2011
    #1086
    Guys. Wanting to know ano ba ung output ng stock alternator ng mga revo natin. Diesel variant po. Tnx
    Sent from my SM-J200GU using Tsikot Forums mobile app
    Aug 2012
    #1087
    Quote Originally Posted by jncp9886 View Post
    According to owners manual, ALT fuse is rated 100A, AM 1 fuse is rated 80A. So my guess would be between these two values.
    Aug 2011
    #1088
    Meron ba conversion to wattage? I mean ilang watts kaya output ng alt.
    Aug 2012
    #1089
    Just multiply by 12.
    80A x 12 = 960W
    100A x 12 = 1200W
    So between these two values.
    Aug 2012
    #1090
    When not sure, always use the lower value.
    May 2009
    #1091
    tignan mo na lang sa data plate or sticker ng alternator..nakasulat naman don yung rated output.
    40, 60 or 70 amps ang usual oem alternator
    Aug 2011
    #1092
    Ok guys. Will check later tnx
    Mar 2003
    #1093
    maingay na release bearing ng GSX ko. mga magkano po kaya magagastos? ano papalitan?
    Sent from my Redmi Note 3 using Tapatalk
    Dec 2016
    #1094
    Good evening po mga sir! I am looking for service manual ng Revo GLX 1.8 Gasolinr M/T. Baka po may copy po kayo. Thanks in advance po! Godbless!
    Sent from my SM-J710GN using Tsikot Forums mobile app
    Sep 2005
    #1095
    Quote Originally Posted by Daryljake View Post
    I was looking for a service manual also, but unfortunately wala pang available dito sa tsikot.
    Dec 2016
    #1096
    Quote Originally Posted by dynamo1131 View Post
    Okay sir, if ever po na magkaroon kayo, this is my email add po, daryljake_soriano*yahoo.com
    Thank u sir!
    Jan 2017
    #1097
    Hi mga sir/mam, bago lang po dito sa forum, hingi lang ako ng opinion on this (post ko from other forum)
    Napansin ko kasi kapag slow ang acceleration ko coming from full stop yung feeling ng gulong sa harap is parang dumadaan sa bumpy road, though di naman ganun kalakas pero kapag medyo mabilis ang accel wala naman. Also kapag na reach ng speedometer ang 100kph nag wiggle na yung manibela pero tolerable hindi malakas ramdam mo lang na may movement yung manibela.
    May kailangan ba ko ipacheck?
    check kung oblong ang gulong, wheel alignment and balance. steering components pa-check na rin.
    Mga sir need your opinion on this:
    Pinacheck ko yung sasakyan sa isang shop, inexplain ko sa kanila yung same sa post ko sa taas, upon checking nung mekaniko sabi nya maluwag daw bearing ng gulong sa right side, tinangal nila yung gulong then chineck yung bearing, sabi OK pa naman daw yung bearing, yung isang mekaniko naman ng check sa ilalaim ng sasakyan ang sabi nya may tama daw yung upper (bearing ba to o bushing/busing (ano ba tama). So yung isa binalik na yung gulong with proper greasing sa bearing, after nun ng check din sya sa ilalim dun nya tinuro sakin yung sinabi nung isang mekaniko at the same time sabi nya may alog na daw yung rack end sa right side ng sasakyan, tinanong ko kung kailangan na palitan, ang sabi nya itakbo ko daw muna at iobserve kung meron kabig sa kanan kasi daw baka maluwag lang yung bearing. Di na nila ginamitan ng computerized wheel alignment sabi kasi pantay naman daw ang upod ng gulong sa harap at diretcho naman ang manibela. Pinacheck ko din yung gulong sa likod to find out na may bukol na yung parehong gulong.
    Regarding sa Upper at Rack end na sinabi nung mekaniko nag tanong ako ng qoutation binigay sa is umabot around 8.2k (4k labor & 4k part include ung 4 na upper at 2 rack end di sinabi kung branded/oem/surplus) nag advice din na pwede ako bumili ng parts at pakabit lang daw sa kanila. Ng tanong din ako na Ok lang ba na upper lang yung palitan, ang sabi nung mekaniko since may alog na daw yung rack end once daw na binaklas eh mahihirapan/baka di na daw maialign yung gulong (totoo ba yun?)
    Eto ngayon ang concern ko (since medyo expensive at the same time base on findings sa back tires eh kailangan na din palitan):
    1. If ever na pagawa ko yung upper and rack end reasonable price ba yung binigay nila? And kailangan ko na ba talaga mag palit ng rack end?
    2. Kailangan ko ba magtry sa ibang shop for 2nd opinion?
    BTW: yung auto is Revo SR, and dun sa mga check na ginawa nila ay wala silang siningil.
    Salamat sa sasagot.. ^_^
    Sep 2009
    #1098
    Quote Originally Posted by jvnj View Post
    You can use 195/70/R15 or 205/70/R15, me and my brother tried both, no scrapping issues so far.
    Mine is 206/65. Same ng stock tires of Toyota Innovas
    Sep 2009
    #1099
    Hello Sirs,
    Just want to ask kung
    anong brand and type of Power Steering Fluid ang ginagamit nyo with your Toyota Revos? Thank you in advance mga sirs!
    Aug 2013
    #1100
    Quote Originally Posted by slickfreak View Post
    Hello Sirs,
    currently using Mag1 for almost 2 yrs, ok naman.
    wag ka lang pipili ng malabnaw, kapag na reach na operating temp, matigas iliko.
Toyota Revo Owner's Club Details
