Results 331 to 340 of 1447
- Apr 2008
- 6,235
December 7th, 2011 09:38 PM #331Haha! Ako 86000kms di pa nagpapalit... :rofl: I have replaced my clutch not so long ago noong nasa around 80000kms, oil filter and injector nozzles noong around 84000kms, timing belt and tensioner bearings at around 85000kms. Yun lang alam kong napalitan.
So sasabihin ko lang sa mekaniko magpapalubricate ako ng accelerator cable alam na niya kaagad kung anong gagawin noh?
December 7th, 2011 10:40 PM #332
Naku ang tagal na pala bro
, sa haba na ng mileage hindi mo pala napapalitan kaya nawawala na talent ng revo mo
, yun muna gawin mong first step magpalit ng fuel filter then next is lubricate and adjust without free play yung pedal cable, minsan kase yung ibang kasama ko sa rental gingamit din nila yung revo, comment nila iba daw yung response ng RPM compare sa kanila, sabi ko yun lang din ginawa ko, alam na ng mechanic mo yun.
Schedule mo na din bro change oil ng tranny at differential, huwag mo na antayin matulad sa differential ko, lumaki ang clearance sa yolk at hindi na kaya habulin ng adjustment, kaya need to put spacer, but not ordinary kind of spacer, galing sa shop ng father ko kase kung ordinary spacer kayang durugin ng friction sa loob, or either magpalit ka differential
- Apr 2008
- 6,235
December 7th, 2011 10:51 PM #333
December 7th, 2011 11:02 PM #334
- Apr 2008
- 6,235
December 7th, 2011 11:18 PM #335
December 8th, 2011 12:09 AM #336
- Apr 2008
- 6,235
December 8th, 2011 12:25 AM #337OK, I will see what can be done by Friday. Update you again by then. Thanks a lot!
- Apr 2008
- 6,235
December 9th, 2011 01:04 PM #338Just got the Revo fixed today. I had the differential oil changed, it was it was starting to solidify and was black as pitch! Then I replaced the air filter and accelerator cable. There was tremendous improvement in terms of the noise, there was no more ugong at lower rpms and the rpm shoots up quickly without having to floor the pedal a lot. Changing all these also resulted to better acceleration. I paid just 1800 petot for this. Thanks guys!
- Nov 2008
- 21
December 9th, 2011 03:10 PM #339Good Day!
Am newbie in this thread. I have a Revo VX200 purchased brand new 2004. My problem is regarding its rack and pinion. May play ang one side the rack. I had it checked at sabi baka may tama ang rubber bushing sa loob ng metal tube ng rack. (i already changed shock, ball joints, rack end... all orig). Ang suggestion nila was... since wala pang leak gamitin ko lang muna until such time na mag leak. My apprehension ngayon is baka kumalat ang problema at matamaan ang steering wheel column. Naaayos ba talaga ang rack and pinion or dapat bumili ng bago? 85k ang price ng Toyota Davao ng rack and pinion assembly (this includes the rack end na napalitan ko rin just last year). anong magandang gawin nito?
suggestions please. thanks.
December 9th, 2011 06:21 PM #340
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
