Page 33 of 35 FirstFirst ... 2329303132333435 LastLast
Results 641 to 660 of 1447
    Feb 2019
    Hmm. Diesel po ng shell po.. may knocking sound po kasi. Any advice po..
    Sent from my ASUS_X017DA using Tapatalk
    Apr 2008
    Quote Originally Posted by techno08 View Post
    If you are referring to the characteristic tak tak tak sound of the diesel Revo, then unfortunately yes it is normal... Ours had it too.
    Feb 2019
    Quote Originally Posted by GTi View Post
    Yes im Reffering to it. Haay salamat naman kala ko may probs ung makina.. maraming salamat po..
    Apr 2008
    Yan ang pangit sa diesel Revo. Hindi makakalabas pasok ng bahay ng di alam ng buong kanto. Hehehe~
    Otherwise, ok naman siya. Matipid sa krudo, hindi naman sobrang kulelat tumakbo, at hindi naman mausok kapag well maintained.
    Feb 2019
    Tama ka po dyan sir. [emoji23] alam ng kapit bahay mo naka uwi ka na o hindi pa.. [emoji23] anyways ask lang po may Groupchat ba or group sa fb about revo owners?
    Apr 2008
    Just saw this from an ad in FB Marketplace. Revo VX200 with a 1KZ engine swap! Must be a hoot to drive!
    Aug 2014
    Nung February pa nakapost yan hindi mabili.
    Sent from my SM-G965U using Tapatalk
    Apr 2019
    Quote Originally Posted by timming_gear View Post
    Mga boss patulong naman. My dad just gave me his glx 1.8 manual, pinagawa ko aircon and after nun I noticed na nag iiba yung takbo whenever I turn on the AC and somehow it gives vibration and namamatay din minsan whenever car is on idle
    My tito said I can look for the the separate idle adjustment for AC, so that idling won't be too low kung naka on ung ac. Meron po bang ganun? And if ever san mahahanap un para mai adjust? Thank you.
    Apr 2008
    Quote Originally Posted by Xaris View Post
    Have your AC mechanic check out the idle up. I'd replaced that in our diesel Revo before. In my case though, the compressor merely stays on all the time, so rpm (slightly higher than usual) does not change at all.
    No other symptoms ba? Overheating perhaps?
    Apr 2019
    Compressor is automatically turning off/on and I hear clicks from my compressor often.
    Other symptoms pala sir ee pag naka on yung AC there's a time na may disturbing sound akung naririnig pero di ko maidescribe yung tunog. Kaya pag ganun I am switching off the AC tas mawawala .
    Yun din ung problem ko pag tinaasan ung idling para sumakto pag naka on yung AC. Pag nagloko na and here comes the disturbing sound and AC needs to be turned off, super lakas naman ng idling.
    Thanks for the response btw sir.
    Apr 2019
    Btw sir, do you know where can I download/get user manual for toyota revo glx 1.8?
    Apr 2008
    Yun nga eh. Pero recently ko lang nakita tong picture ng engine bay.
    Bakit kaya hindi naeenganyo mga tao bumili no? Problems with documentation perhaps? O dahil lang talaga na swapped na siya? Original diesel Revo's fetch very good prices and are supposed to be very easy to sell.
    things that come to mind.
    1. outlandish price.
    2. it's a conversion. usually a caveat, especially if the convert-er does not have an ironclad reputation.
    3. plain old age.
    4. mas tumakaw sa gas?
    5. and yes. documentation.
    Apr 2008
    3. plain old age.
    Seems like a really good project car though. If swap is properly done with matching tranny and proper documentation. I love the 1KZ. Pulls our 2 ton Granvia really well. Can only imagine how it does in a vehicle that is lighter by half a ton. Very reliable engine even in old age. 4-5km/L city nga lang. [emoji28] But then the 2.0 gas probably does even worse, in gasoline currency.
    Apr 2019
    Apr 2008
    Perhaps you can try Keycards in Robinsons Magnolia top floor outside of True Value and see if they can make a duplicate remote. They couldn't do my 2007 Santa Fe, but perhaps Toyotas will have better luck.
    Sent from my SM-G965N using Tapatalk
    Apr 2014
    Quote Originally Posted by chronicle View Post
    I didn't see this. I always thought our diesel revo was a 2.0 diesel. Haha.
    Reason for this misinformation, when we checked the or/cr later in life of the car, we found the LTO incorrectly put in the fuel type as gas... We have to go to lto east to have it corrected... What i didnt know was even the displacement was wrong in the lto records.
    Edit : no longer own the car. Ü
    Sep 2019
    Baka mali nkalagay sa OR ko sir sa displacement. Big thanks sa info. Marami pa ako questions soon mga sir ha.
    Nov 2017
    Quote Originally Posted by Ceann Niño View Post
    You can also use the model codes listed in the chart and the model plate to verify what model trim your revo is/was
    e.g LF80L-GRMNSM 1998-2002 GLX MT
    LF82L-GRMNSM 2003-2005 GLX MT
Toyota Revo Owner's Club Details
