Do you see black smoke when you are attempting to breach 3k rpm? If so, then perhaps you can visit a diesel calibration shop to have the fuel system checked.
What's the mileage of your vehicle anyway?
Sent from my GT-I9100 using Tapatalk 2
^inquire ka sa Malabon Diesel kung pwede sa kanila..
Malabon Diesel
hi mga ka TROCs - baka may for sale kayong lumang stock mags ng revo. interested buyer here...TIA
Hello po sa TROC, recently acquired GSX Gas M/T 2003 model. Low batt po yung remote key lock, pinapalitan ko po ng battery pero hindi pa rin nagrerespond yung mechanism sa kahit anong button. Napansin ko po sa dashboard na hindi nakailaw yung led ng "security" kailangan po ba ng fuse palitan? or ano po pwede i-DIY para mapagana ko ang remote?
Maraming salamat po
Nakapagpalit na rin ng fuel filter ng VX200. Gusto ko sanang i-DIY kaya lang masyado naging busy nitong holiday break. Pinasabay ko na lang sa change oil service sa probinsya. Additional P150 ang hiningi sa akin sa pagkabit ng fuel filter.
Fuel filter was purchased in PARTSTAR in Pasay. Walking distance lang from MRT Taft station. Price was P2,130.00. Part # 23300-79515. This needs to be replaced every 40,000 km or 48 months. So amortized cost is P2,130.00 / 4 years = P532.50 per year.
Fuel filter of VX200 is located under the Intake Manifold (with the "EFI" marking).
Old fuel filter:
New fuel filter:
malakas ba talaga sa gas iyong vx 200 a/t na gas? parati kasi complain kaibigan ko eh
ito iyong totl nuong generation iya di ba?
Yes, VX200 is the TOTL ng Revo.
It depends sa route mo and traffic conditions. Pati na rin sa maintanance ng sasakyan.
Twice kami lumuwas from Bataan to Makati and back last December. Acceptable naman para sa amin ang FC nya. This is for VX200 Gas A/T.
Route: Bataan National Road> Pampanga National Road > NLEX > EDSA > Makati
Trip 1
Distance = 251.63 km, Bataan-Makati-Bataan
Gas = 26.77 L (Full Tank method), Petron XCS
FC = 9.39 km/L
Trip 2
Distance = 285.29 km, Bataan-Makati-Bataan
Gas = 33.86 L (Full Tank method), Petron XCS
FC = 8.43 km/L
Pero kung gagamitin mo siya for daily driving sa city, tapos 1-2 passengers lang (including the driver) eh you better get a compact car na lang. Or switch to M/T or Diesel variant. But of course may Pros and Cons rin ang mga yan.
Deym I miss our GLX gas revo. Learned driving there.
Kahit na mas matulin at mas modern Grand Starex namin na mmiss ko yung Revo namin. Iba pa rin ang first love![]()
Hi guys,
Has anybody used Bardahl Maxtran 5000 80W-90 (API GL-5) on their transmission and differentials?
Went to a car shop and that's what they are using for other mpvs (advie, crosswind, etc).
Is this oil ok? Or anybody can recommend one?
Btw, my revo is the diesel 2L.
Thanks!
^Based on Revo owner's manual..
M/T Gear Oil: SAE 75W-90, API GL-4 or GL-5
Differential Gear Oil: SAE 90, API GL-5
Pwede kang bumili sa casa. Toyota Differential Gear Oil is P285 per 1L bottle.
I don't know the price for M/T Gear Oil dahil A/T yung VX200 so ATF ang gamit ko.
mga sir, balak ko bumili ng vx200 na matic..tanung ko lang kung may obd ba ito for diagnosis kase nakita ko parang andaming sensors eh.panu nyo mo malalaman kung anung sensor ang papalitan? TIA
Yup, basta may ECU ang sasakyan eh meron diagnostic port yan. OBD II protocol ang gamit ng Revo. OBD II protocol is for 1996 and newer cars. OBD I protocol is for 1995 and older cars.
Defective sensors will usually trigger the Check Engine Light but not all the time. If you suspect that a sensor is malfunctioning, pwede mo pa-scan ang ECU. Based on trouble codes, malalaman kung anong sensor ang defective.
for info lang po mga sir
owner of VX 200 2004 model
7K-E engine
gear km/h (mph)
1 34 21
2 58 36
3 93 58
4 133 83
1RZ-E engine
1 35 22
2 65 40
3 99 61
4 139 86
2L engine
1 34 21
2 57 36
3 92 57
4 124 77
for info lang po ulit
Fuel
Selecting the proper fuel is essential for satisfactory engine performance.
Engine damage caused by use of improper fuels is not covered under Toyota's new vehicle waranty.
Fuel Type
Gasoline Engine
You may use either of leaded or un leadead gasoline
Diesel Engine
Use only diesel fuel.
Octane/ Cetane Number
7K-E engine: Select premium leaded or unleaded gasoline with a reseach octane number of 95 or higher.
1RZ-E engine: Select premium leaded or unleaded gasoline with a reseach octane number of 90 or higher
Diesel Engine: Select cetane number 50 (cetane index 45) or higher
Use of fuel with an octane or cetane number lower than stated will cause persistent heavy knocking. if severe, this will lead to engine damage.
if your engine knocks...
If you detect heacy knocking even when using the recommended fuel, or if you hear steady knocking while holding steady speed on level roads, consult your toyota dealer or mechanic.
However, now and then, you may notice light knocking for a short time whle accelerating or driving up hills. This is no need of concern.
Fuel Tank Capacity
55 L (14.5 gal, 12.1 Imp. gal)
