Napalitan na ang thermostat valve. But then ang sabi ng mekaniko sobrang negligible lang ang pagkawarp at hindi yan maging dahilan ng pagkaoverheat. So far water pump at aux fan nalang ang di napapaltan. Tingin mo ba may katok yun? I don't see any leaks by the way.
Never ko pinatay agad ang makina kapag umiinit. I merely turn of A/C and delay shifts para mas mabilis umikot ang fan.
Sent from my GT-I9100 using Tapatalk 2
mga sir pa O.T ng konti nagJOin ako sa yahoo groups naten ... sana po maaccept ako ... i own toyota revo SR 2005 gas variant.. thanks ...
mga sir pede ba DIY para bumaba ung harap ng revo naten .. revo SR gsto ko sana ilowered ng onti ung harap.. sabi kasi nung kakilala ko na mekaniko kelangan daw palitan un shock para bumaba pero ngbasa basa ako ung revo naten tension bar ... pede ba DIY nalang yun .. thanks
pwede DIY according to this:
"The torsion bar key is part of the torsion bar, which allows the vehicle ride height to be adjusted at the factory when the vehicle is built and as needed afterward. It's easily adjusted with a small hand wrench at home."
5 Ways to Lower a Car - wikiHow
Mga bossing, alam nyo ba kung nasan yung reverse light relay ng revo? Di kasi gumagana yung reverse light ko. I cheched the fuses also the reverse switch located at the transmission pero parehas naman ok. Suspect baka sa relay na. Salamat po sa magre reply o share.
Thanks for your reply dr. d. I actually thought about going thru the wires, but since its encased in a flexible tube then wrapped with an electrical tape, I backed out. Malaking trabaho, plus it went also inside (underneath) the dash which is also covered with tube. I guess its better to bring it to a professional (electrical shop) already, its much safer and simpler that way, though another cost involved again
Thanks!
you don't have to physically trace the cables. just take note of the color of the wiring insulation as it leaves the switch. look for the same color combination at the end of the... whatever it is.
Yes you're right dr. d, wires are indeed color coded. We'll try next time. Thanks!
Guys, kelan usually ang palitan ng t-belt, how many kms? 7k-E engine here...TIA
