Page 32 of 35 FirstFirst ... 222829303132333435 LastLast
Results 621 to 640 of 1447
    Aug 2017
    good day mga ka-TROC, ask ko lng po kung may nkapgpalit npo sa inyo ng radiator? how much po brand new?
    Sent from my F5321 using Tsikot Forums mobile app
    Apr 2008
    ^Meron bro. Since rear wheel drive ang sasakyan natin, meron syang differential. Check your manual for the oil specifications.
    Sent from my SM-G900I using Tapatalk
    Jan 2017
    Salamat sa info, pa check ko next PMS ko.
    Jul 2012
    just sharing. i inquired with toyota bicutan re atf for our toyota revo glx 2000. they recommend the type 4. but as per owners manual, we should be using the dexron III. but according to them, they don't have that one anymore. so they're using the type 4. the attached photo was sent to us a day ago.
    Aug 2016
    Quote Originally Posted by mmv12 View Post
    there are still dexron III available in the market. I got mine at Petron.
    Jul 2012
    Quote Originally Posted by gorz_j View Post
    Yeap, thats what i think also. So do i nees to use that or the type 4?
    Sent from my SM-N910U using Tsikot Forums mobile app
    Dec 2009
    just sharing. i inquired with toyota bicutan re atf for our toyota revo glx 2000. they recommend the typeIV. but as per owners manual, we should be using the dexron III. but according to them, they don't have that one anymore. so they're using the typeIV. the attached photo was sent to us a day ago.
    DexronIII is the minimum requirement..typeIV is the better replacement because dexronIII is an old formulation
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Apr 2018
    Good day mga ka TROC
    I own a 99 Revo GL diesel binigay sa’kin ng father ko when they move to a different country. Napansin ko kasi medyo matigas yung gas pedal nya kaya hirap humatak, so I’ve search on google and youtube for some possible cause and DIY repair. Most ng nakita ko is about dirty throttle body and also suggestion to lube the throttle cable.
    Naalala ko nung magpalit ako ng compressor nabanggit ko yun sa mekaniko and he did the same thing he lubed the throttle cable pero after almost a year eto bumalik ulit pero hindi kasing lala gaya ng dati. So ngayon nung bumalik ni-lube ko ulit yung cable and also check the air intake nakita ko may dalawang malaking punit yung intake hose(tinakpan ko muna ng duct tape for temp solution) I’m planning to buy a rtv sealant today to fix it kung wala akonh mahanap na replacement part.
    Then tinignan ko din yung kabilang dulo(sorry hindi ako ganun karunong sa engine parts and terms hahaha) ang kapal nung dumi (boxed on 2nd pic) it’s all grimed up.
    So long story short po, any suggestion about my concern, how to clean that part, what to use when cleaning it(materials and solvent cleaners), and do i have to take that metal part out when i clean it? Thank you po in advance.
    Dec 2018
    Up
    Jan 2017
    Mga sir,
    ano po ba ang preventive maintenance or meron ba maintenance na ginagawa sa mga pang ilalim ng Revo? i.e. shocks and others
    ano-ano rin po ba ang mga dapat na pinapacheck?
    salamat po.
    Dec 2018
    Kabibili ko lang revo ko. Glx 1.8 year 2000. So far, engine oil, coolant ang pinalitan na. And next papalit is transmission and differential fluid. Papa undercoat ko rin next week. 200+km na pala revo ko nung nabili.
    Jan 2019
    Sir red_one kung pwede sana pa-send din ng owner's manual ng 2004 Toyota Revo VX200 Gas, 1RZ-E engine. My email address is sonyattan*gmail.com. Maraming salamat.
    Dec 2018
    Quote Originally Posted by sony attan View Post
    Sent na sir. Copy from sir red.
    Jan 2019
    Hi Sirs, bago lang ako dito.
    ask kolang sana if ano issue ng Revo namin pag nagpepreno may sound yung parang sa tricycle kapag nag preno kaagad. Ano ho kayang issue non? Also, ano pong alternative para mapakintab ule yung headlights?
    TIA!
    Quote Originally Posted by Joejonas View Post
    TIA!
    brake squeal is a brake indicator that means your brake pads need changing. or the caliper guide pins are already partially seized. caliper guide pins need to be greased. you can go to any motech nearby. they have fb so you can also check if they are nearby.
    watch this for how the brakes are serviced.
    headlights can be buffed but it needs to be protected from oxydation. some shops offer this service...
    Feb 2019
    Hi, bago lang po ako dito, i just bought toyota revo 2000 diesel.. may owners manual po kayo nito? Salamat po.
    Sent from my ASUS_X017DA using Tapatalk
    Dec 2018
    Quote Originally Posted by techno08 View Post
    anu email add mo sir? dun ko i send file
    Feb 2019
    Quote Originally Posted by wufei_54 View Post
    fortunelim2007*gmail.com po sir. Maraming salamat po.. [emoji4]
    Feb 2019
    Thanks po sir, received na po.. [emoji4] additional question lang po, normal lang po ba ung knocking sound sa revo?
    Dec 2018
    syempre hindi. anung gas gamit mo?
Toyota Revo Owner's Club Details
