Page 38 of 73 FirstFirst ... 2834353637383940414248 ... LastLast
Results 741 to 760 of 1447
    #741
    Quote Originally Posted by red_one View Post
    Yup, basta may ECU ang sasakyan eh meron diagnostic port yan. OBD II protocol ang gamit ng Revo. OBD II protocol is for 1996 and newer cars. OBD I protocol is for 1995 and older cars.
    Defective sensors will usually trigger the Check Engine Light but not all the time. If you suspect that a sensor is malfunctioning, pwede mo pa-scan ang ECU. Based on trouble codes, malalaman kung anong sensor ang defective.
    thanks red_one!
    #742
    Quote Originally Posted by tidge View Post
    for info lang po mga sir
    owner of VX 200 2004 model
    7K-E engine
    gear km/h (mph)
    1 34 21
    2 58 36
    3 93 58
    4 133 83
    1RZ-E engine
    1 35 22
    2 65 40
    3 99 61
    4 139 86
    2L engine
    1 34 21
    2 57 36
    3 92 57
    4 124 77
    Thanks for sharing Sir tidge
    #743
    for info lang po ulit
    Fuel
    Selecting the proper fuel is essential for satisfactory engine performance.
    Engine damage caused by use of improper fuels is not covered under Toyota's new vehicle waranty.
    Fuel Type
    Gasoline Engine
    You may use either of leaded or un leadead gasoline
    Diesel Engine
    Use only diesel fuel.
    Octane/ Cetane Number
    7K-E engine: Select premium leaded or unleaded gasoline with a reseach octane number of 95 or higher.
    1RZ-E engine: Select premium leaded or unleaded gasoline with a reseach octane number of 90 or higher
    Diesel Engine: Select cetane number 50 (cetane index 45) or higher
    Use of fuel with an octane or cetane number lower than stated will cause persistent heavy knocking. if severe, this will lead to engine damage.
    if your engine knocks...
    If you detect heacy knocking even when using the recommended fuel, or if you hear steady knocking while holding steady speed on level roads, consult your toyota dealer or mechanic.
    However, now and then, you may notice light knocking for a short time whle accelerating or driving up hills. This is no need of concern.
    Fuel Tank Capacity
    55 L (14.5 gal, 12.1 Imp. gal)
    Thanks for sharing, Sir tidge
    Feb 2009
    #744
    ^Based on Revo owner's manual..
    M/T Gear Oil: SAE 75W-90, API GL-4 or GL-5
    Differential Gear Oil: SAE 90, API GL-5
    Pwede kang bumili sa casa. Toyota Differential Gear Oil is P285 per 1L bottle.
    I don't know the price for M/T Gear Oil dahil A/T yung VX200 so ATF ang gamit ko.
    Thanks for the info :D Did my research also and SAE 80W-90 is ok for our revo (gear oil and differential oil).
    Oct 2014
    #745
    Guys, sa inyo ko po ito itatanong kasi kayo po mismo mga naka-revo, praktikal pa po ba kung kukuha po ako ng 2nd hand revo? marami po talaga nagdidiscourage sakin sakit lng daw po sa ulo. Gusto ko po sana makarinig ng mga comments and suggestions mula sa inyo. Maraming salamat po and more power to revo owners...
    Apr 2010
    #746
    Quote Originally Posted by toyotaae86 View Post
    Bakit raw nila nasabi na sakit ng ulo ang Revo?
    May pinahiram sa amin and I drove it for a few months (its a gas A/T), maintenance is cheap, space is OK, malakas nga lang uminom ng gas. If you can find a diesel na hindi laspag, then get it.
    Oct 2014
    #747
    Lagi na daw po ipapagawa? Totoo po ba un? Ung lakas sa gas naiintindihan ko naman po un kasi old design npo engine pero marami na daw po magiging sira? totoo po ba yun?
    Apr 2010
    #748
    Unless brand new kunin mo may ipapagawa ka talaga, its a 15-ish year old vehicle - it applies also to other vehicles. Mas ok kung kakilala mo yung bibilhan mo, or if hindi naman eh magdala ka na lang ng trusted mechanic.
    Oct 2014
    #749
    Maraming salamat po sa reply particleX. May idea poba kayo kung san makakakuha ng service manual po ng revo?
    Aug 2012
    #750
    Same question with ParticleX, bakit nila nasabi na sakit sa ulo?
    We have Revo VX200 Gas A/T. Reliable, easy maintenance, decent fuel consumption.
    Pure City: 6.52 to 7.17 km/L
    Mixed City & Hi-way: 8.09 to 9.39 km/L
    Full tank method.
    The key to owning a vehicle is proper maintenance. Take care of your ride and it will serve you well.
    Full tank method.
    #751
    i think that because the revo was designed to be a workhorse vehicle, it is common for these vehicles to be "driven to the ground". hence the "sakit ng ulo" reputation, true or otherwise.
    but if the vehicle was not abused by its owner, it should be a good buy. i know of revos that have served their owners well thru the years.. matibay siya.
    Apr 2008
    #752
    Yes, but that's because it's old. You may have to replace quite a lot of things, but the same goes for any similar vehicle of the same vintage, with the same amount of usage. Our Revo has had quite a lot of repairs in the last two years or so, almost all of which you'd find in this thread. The latest fix done was a leaking alternator hose (750) a frayed power steering belt (400), and a faulty power window switch (ordered from Toyota casa for 4100! )all done during an oil change at 117tkms.
    The Revo is a very practical workhorse vehicle. I find having a good balance of the good qualities of the Adventure and Crosswind. It is by no means a headache vehicle, at least not any more than most cars out there.
    Nov 2011
    #753
    This happened to me sa corolla car ko. Nagpalit din ako cluct master ko pero umuulit yung problema pag umiinit na yung engine. So ako na ang nagdecide para palitan sa shop yung secondary clutch (original repair kit ang binili ko sa Cruiser Sucat), After mapalitan yung secondary, parang nagdahilan lang yung car.
    Nov 2011
    #754
    I bought my revo SRJ A/T 2001 model in June 2011. Since second owner na ako, pinalitan ko lahat ng fluids and performed minor adjustments like wheel balancing and wheel allignment. After that, puro regular mainenance na lang like change oil, filters, and spark plugs.
    Very easy to maintain ang revo and mura ang basic parts nya kaya cheap ang maintenance.
    #755
    All 2nd hand vehicles has the probability of breaking down, reasons are as stated above by our experts. Even on brand new vehicles, sometimes you're still not spared. I bought a 2nd hand Revo a year ago, yes I did cash out on some repairs but after I fixed all of them, parang brand new na din. Drive, gas up, and maintain na lang. Good news about the Revo is that is seems it is the best as compared to other AUV's of its age
    Aug 2012
    #756
    Quote Originally Posted by jvnj View Post
    Agreed. Do remember that the Revo what the top seller AUV of its time.
    Nov 2011
    #757
    QUOTE=red_one;2515785]Agreed. Do remember that the Revo what the top seller AUV of its time.
    [COLOR="silver"]- - - - - - - - - - - - - - - - - - - - - -[
    Agreed. Do remember that the Revo what the top seller AUV of its time.[/QUOTE]
    Yes, Revo was the top selling vehicle (all category) from 1999 to 2004). When it was eventually replaced by the Innova, Revo was still the number one selling vehicle. Maybe there's a reason why during its time, Revo was the number one selling car.
    Jul 2011
    #758
    hi, anyone tried load plus for lift spring in their revo?
    #759
    I haven't tried it with my Revo. But my brother who owns a Sportivo says it improved the loading capability of his ride. In terms of ride comfort, it did not affect much as there were only very little amount of stiffness felt as compared to without the usage of Load plus. Plus, "hindi na bumabagsak yung suspension pagkinargahan ng madami".
    Jul 2011
    #760
    sir thanks for the feedback...
    kaya im thinking magpalagay ng load plus dahil bagsak ang likod.
    check bnew lift spring cost only 2,200 per side. ano mas advisable?
Toyota Revo Owner's Club Details
