salamat jvnj sa reply, yun nga lang po may nagsabi sakin na nasa malapit sa exhaust manifold daw po ung oxygen sensor. hehehe pasensya na po pero medyo naguluhan na po ako... help naman po...
for 1RZ-E engine
Sir red_one,
Saan po mahahanap yun fuel filter ng vx200 natin? TIA
Sir red_one,
maraming maraming salamat po. Tagal ko ng hinahanap to kasi more than 100k na yun vx200 ko at kailangan ng palitan yun fuel filter.
Hi guys,
Just got a 2004 revo glx diesel. Planning to upgrade the stock tires with the innova stock rims & tires (205/65r15). Will the rims fit correctly?
revo stock tire rim width is 5.5in, 27mm offset
innova stock tire rim width is 6.5in(?), 48mm offset
Thanks!
Hi guys,
Thanks!
Innova tires (with rim) will definitely fit in a Revo, FX, Adventure, etc. I myself has a Revo fitted with a VX mags which has the same dimensions as the Innovas. Thanks
mga sir, patulong naman..
yun revo namin na diesel, if apakan yun gas pedal sagad hangang flooring upto 3 lang rpm hindi na tataas.
what could be the problem?
That's odd... Never experienced that before. Ano nangyayari kapag tumatakbo ang kotse? Di parin ba lumalampas ng 3k rpm?
Ano ba ang pakiramdam? Wala bang hatak? O normal ang hatak at napuputol nalang at 3k rpm? Why don't you check out the accelerator cable first. You can also try cleaning the air filter and perhaps a full oil change.
Sent from my GT-I9100 using Tapatalk 2
