Page 3 of 22 FirstFirst 123456713 ... LastLast
Results 41 to 60 of 424
    Feb 2005
    #41
    hi guys,
    more input please?
    Liteace GXL all power
    -white (all stock)
    -w/CD player
    -45th mileage
    -Owned by a family member.
    Is P250k a reasonable price??
    Thanks!
    Feb 2005
    #42
    what year model??
    Jun 2005
    #43
    local liteace 1989-90 uses rear leafspring, yung 91 up eh coil spring na..
  4. #44
    epals lang pwede?
    ko gusto ko sana trade ko delica ko for a jdm 4wd lite-ace FXV with 2c-t engine...ung kamukha ng last model dito sa atin.
    sa tingin ok kaya..anu say nyu n nakagamit na ng toyotas with 2c-t engine(particularly fx users,e..better kung JDM lite-ace diesel owners)
    ot: my other option is to get a JDM diesel AWD vanette/serena...(eto nalang kasi kaya ko,e...pangarap nalang ang RVR and spacegear)
    Feb 2005
    #45
    Quote Originally Posted by Innova_Boy
    what year model??
    sorry forgot to mention its a '98 model. all power. is this the 1.8li van? how do i know if its 1.8 or 1.6 or otherwise?
    thanks!
    Feb 2006
    #46
    Mga tsong ask ko lang po about problem ng lite ace ko wlang lamig pag naka 2nd switch ng aircon pero kung naka 1st swicth lang malamig nman. And also mabilis sya mag over heat pag mainit panahon lakas kumain ng tubig, pero pag tag ulan ska gabi d nman sya nag ooverheat aabot kya sa bicol to e punta p nman kami dun next month.... huhuhuhuh model ng van ko is 92 model.... tnx
    Sep 2005
    #47
    check the ff:
    1. aux fan ng aircon
    2. clutch fan the fan blade
    3. ignition timing
    4. clean the external radiator fins and condenser fins. go to a gas station and have it lifted, then spray with a pressure washer condenser and radiator fins
    5. if all fails, have your aircon checked at your favorite aircon shop
    btw, sakit ng lite ace ito. same with the vanette and L300
    Feb 2006
    #48
    hi sir, sabi nila gawin daw 3 rows ung radiator para mawla overheating, do u have any idea kung san po may gumagawa or nag momodified ng radiator?
    Sep 2005
    #49
    Quote Originally Posted by jetdbest
    no need. sa jeep lang ginagawa iyan.
    wala naman sa radiator ang problema. pag madalas linisin ang mga condenser at radiator fins, di ka mag overheat. kasi sucking motion ang auxillary fan ng condenser so logically, pati alikabok higop niyan. pati balahibo ng aso kuha iyan. linis lang. no need to change the radiator to 3rows...
    #50
    chong jetdbest, maaaring ot ito pero paalala lang: R12 ang freon ng liteace. napaaga ang palit ko sa compressor dahil R134A yata ang nailagay dati. re: overheating, sa experience ko sa '93 GXL e ok na ok halos palagi nasa 1/3 ang temp. alaga po ito (regular casa pms, synthetic oil) at 100,000 pa lang ang mileage.
    Feb 2006
    #51
    Quote Originally Posted by banaweonline
    Napupuna ko lang kasi sir parang ang bilis maubos ng tubig ng radiator pag naka on ang aircon ng almost 1-2hrs pero pag naka off ok nman sya kahit 4 hrs na dirediretso.pede po ba i pa relocate ung condenser ng aircon para hindi sya katabi ng radiator? san po b may gumagawa neto....
    #52
    tsong, punta ka na lang kay banaueonline feeling ko expert sila sa a/c systems
    Feb 2006
    #53
    mga Bro
    tanong k lng po ,me diesel po ba na Liteace yr 1994?ano po kaya makina nito?balak po kc nmin kumuha ng ganito na van panghatid tsaka pangpasyal lang naman!
    medyo tight budget kasi e! around 150k lang na van sana para for a small family of 4 !
    tska pagaganito po ba mga sir e ano mga pa mag necessary check ups after i bought the van?
    slamat pomga sir in advance!
    Feb 2005
    #54
    check the unit for rusts, overheating, engine, suspension, air-con. Goodluck sa paghahanap. Be wary, medyo malakas din sa gaso to, underpowered kasi sobra.
    Mar 2003
    #55
    we had a liteace before, locally assembled model '92. i remember when i was browsing through its owner's manual, i read that there is a diesel model; 2ct yata yung engine. local units assembled by toyota motor philippines only had gas engines, yung 1.5 liter 5k engine. sobrang hina ng engine na to tsaka takaw sa gas. i think the diesel liteaces are all converted units from subic
    #56
    Locally, only the 5K 1.5l engine is offered. It makes 64 horsepower. For comparison's sake, a Kia Picanto has about the same output.
    The engines are pretty simple to work on. Check the usual suspects like crash damage, rust, substandard repairs, etc. Check the papers, too.
    May base model din na Lite Ace nung araw. Square halogen headlamps na generic (not the rectangular flush-mounted ones), black bumpers, no alloy wheels, bench front seat, lots of bare metal inside, stamped steel wheels. Usually beige at blue ang kulay ng base models.
    Wala pa yatang top-line GXL model noong 1992.
    Feb 2006
    #57
    ay ganun po ba?
    sayang !hanggang ganitong mga type and budget pa naman target namin!
    tama lng kc maliit n pamilya nmin tsaka medyo mababa rin kc budget e!
    ano po kaya yung mga mini van na parang kagaya ng lite ace?
    salamat po mga sir sa reply!
    #58
    never heard of local lite-ace diesels, but maybe those import lite-ace utility (small isuzu elf look alike) vehicles are diesels.
    though I saw on the web, a Lite-Ace diesel
    http://www.kyrocar.fi/web/index.php?...te&kategoria=7
  19. #59
    mines a diesel, 2c-te mated to a 4 speed a/t , 1991 jdm year, 1997-1998 phdm year.. yes converted po akin...see the sig nalang....
    locally, yes, 5k lang makina nyan....wala nang iba...gxl lang ang pinaka top-of-the-line dito...
    Apr 2006
    #60
    wla din akong alam diesel na lite ace , pero kung mapilitan k kumuha ng gas 5k , subukan mo n lang kumuha ng fx kunin mo yung 7k malakas humatak kesa 5k maasar ka lang super kupad malakas din sa gas .
    cguro dagadag ka konti sa budget mga 150k - 170k
Toyota LiteAce Owners & Discussions Thread [Merged]
