Page 7 of 8 FirstFirst ... 345678 LastLast
Results 121 to 140 of 424
  1. #1
    2c-t or 3c-t un lang. hanap ka ng makina/manual tranny tandem.+ post transplant gremlins
    benta mo nalang and buy a besta/jdm na orig diesel na.
    Feb 2005
    Tanong ko lang anong year ng Liteace ang makina ay 7K, kasi yung samin 5K lang engine at malaks nga sa fuel....
    WBR,
  3. #3
    baka pinalitan....
    Hello Guys,
    Im having problems with our LiteAce... Paano po ba alisin ang kalampag and how will be the estimated damage for the work?
    Salamat po!
    iam3739.com
  5. #5
    drey anung kalampag? baka bushing lang yan....and/or shocks....
    sa akin may kalampag, yung stopper para sa pagliko ng gulong, wala nang goma,e....di ko alam saan palitan....
    Kalampag at may kasamang rattle sounds especially sa mga bumps. I believe it is coming from the front suspension.
    iam3739.com
  7. #7
    check mo muna mga bushing..or baka there is something loose lang din sa ilalim...
    Have it checked at a service shop and get second opinions here.
    Usually ball joints and bushes ang source of kalampag.
    Used to have one, it wasn't all that powerful, but it was a hoot to drive.
    The only thing I really didn't like about it was the placement for the cooling coil for the rear aircon, it prevented you from taking out all the seats and having a fully flat floor.
    Nov 2007
    sir,
    mga sir mag tatanong po sna ako..tungkol po ito sa lite ace nmn kasi po nag over heat po cya lst week nakalimtuan kasi ng brotehr ko na ibalik ung takip ng radiator after filling it water..ang mali ko alng po nung na byahe ko cya hini ko cya na check..tpos pina check ko sa mechanic ang sabi nya pinasok na daw ng tubig ung langis kasi nung nag over heat ako binuhusan ko ng tubis sa gasolin shop..
    mga sir tama po kaya ung sabi nung mechanic na gasket N change oila ng paraan para maayos ung van..natatakot din ako kasi sabi nila pag nag over heat daw ung van kakatok na ito at wala na un power nung machine..balai 2nd time na cya nag over heat at may difference na ung power ng engine from the first time na mag over heat ito...and takot ko lang bka lalo cyang humina at lagi nang masira..
    hopeing for your suggetsion and tips on how to handle this problem.
  10. #10
    have your cylinder head checked first... baka nagkatama nung nagka-overheat,e...
    Apr 2005
    Sir ,patanong naman regarding my liteace. hard starting kasi sya after i use it with aircon on. If i dont use the aircon, madali lang i-start. bago ang battery ko, last april lang sya pinalitam.
    can anyone help me to find a reputable shop that can convert my lite ace manual steering to power steering(assembly)? How much is the estimate cost?
    any other feedback after the conversion? Thanks in advance.
    Oct 2008
    goodday to all! i have an 92 liteace gusto ko sana lagya ng taillight katulad ng gxl saan kaya makakbili nun at magkano kaya gagastusin? yun skin din nagooverheat mmmmm hindi nalang ako masyado gumagamit ng aircon hehehe!!!
    meron po bang liteace na converted na sa fuel injected? thanks
    Quote Originally Posted by Cnetlasan View Post
    Bro if you want to use fuel injected you could try to install a 7k engine from a toyota revo or a 4a-ge engine.
    Apr 2008
    Good day tsikoteers!
    Ask ko lang kung saan ang fuel drain plug ng fuel tank of LiteAce 91. May nakita akong plug but not sure kasi wala siya sa lowest level ng fuel tank. I was not aware that yong gasoline with bioethanol eh nakakasira pala ng carburator. Tnx.
    Jan 2010
    yes sir,may epekto sa carb type enginne ang ethanol gas..yun nga ngayon ang karamihan problem ng old car owners and non compatible cars kasi marami pa sa pinas ang mga 5yrs -10yrs old na cars na ginagamit pa..magkaka moist daw ang tank na mag cacauuse ng clogged fuel lines and it will also damage the rubber seals ,valve seals etc.
    see toyota phil.info with regards to ethanol gas..and what models of cars are already compatible to it.
    Apr 2008
    sir mcrens86, do i need to drain the remaining fuel(with ethanol)? How about carburator baka masira din. Guys, anyone who knows where the fuel tank's drain plug? Or baka may access siya sa taas(at floor) para ma-siphoned ko na lang. Hindi ko muna siya gagamitin at baka lalong hirap sa pag-start. Pls help. I badly need it to be done hirap kasi magcommute.
    Jan 2010
    *boxanilin,
    nun nag drain ako nun fuel ko sa tank,,yun mismo malaki na rubber hose na nakaka clamp dun sa tank hinugot at niluwagan yun belt nun tank para ma drain at tilt ng konti papunta dun hinugutan ng rubber hose.malaki yun hose na yun..di pwede 1 tao lng gagawa kasi may mag aalalay para di tuluyan mahulog ng buo yun tangke,..ang gamit ko ngayon E10 pa kasi halo ko sa blaze para taas pa octane level at bumaba ang ethanol mixture.
    may nakapag sabi na ,may nag uup grade ng carburator ,,palit ata yun mga jets sa cooper at pati yun rubber hose nun fuel lines.di ko lng alam kung long term solution ito o bakasakali lang ng mga worried sa car nila na masira.
    flex fuel hose yata tawag dun sa e10 compatible rubber hose..if you have other news like this pls.post it ,to make us all aware about the issue of E10 fuel.
    Jan 2010
    *boxanilin
    kung hard starting yan lite ace mo,try mo pa check yun starter at battery baka di na ok yun starter mo..kasi ako nagpalit ako last october kasi inabot yata nun tubig baha yun starter ko ,3/4 nun gulong ko abot yun baha eh.
Toyota LiteAce Owners & Discussions Thread [Merged]
