Not sure with innova, pero sa 2017 fortuner, parang electronic na yung control sa clutch fan.. wala na yung temp sensing spring. May bilog na sensor sa gitna yan tapos may wire connection na
No need naman mag add kung walang leak
Kung transverse-mounted ang engine, it's probably using an electric motor-driven cooling fan. My 16-yr old Vios is using one and I was able to replace the electric motor myself.
With the Innova's clutch fan, big endeavor for a DIY project, at least for me. my cousin who is a mechanic had to do it for me, assist lng ako
What i mean is hindi na "mechanical" yung pag engage and disengage ng clutch fan sa 2GD engine ng fortuner.. yes umiikot yung fan pero nadulas lang yan..
Pag mainit na titigas yung kapit ng clutch fan then madidinig mo medyo maugong yan..
Dun sa dati kasi may metal spring na pag mainit mag expand to engage the clutch fan.. sa newer models, electronic na yan
I have the 2017 1GD with a viscous fan clutch, baka iba talaga design ng Fortuner compared sa Innova. I like the electric fans better kasi mas madali i-DIY, and not as noisy sa mga engine-driven fans. Not sure which one is more efficient though :D
one sign din yan of overfilled silicon oilovertime mawawala rin pero currently it's adding unnecessary stress to the engine starting at that rpm kasi dapat disengaged na yan at that speed.
actually on mine, 1st try was done by a reputable shop, a big one actually. However, ang magaling na mekaniko, 4 18ml tubes ang inilagay, so ayon, parang nka welding si clutch kaya it spins as fast as my engine rpm all the time. so, a big yes to your question. meron pa ring mekanikong walang alam, or probably feeling may alam
ended up researching from all over and learned how the correct measurement is done, then asked help from my cousin removing/disassembling the fan clucth and filled a measured amount into its reservoir myself. now i'm happy with how the clutch performs.no more reserve thrusters sound when revving high lol
mas tama po ba na 2 18ml lang po ang dapat na ilagay sa clutch fan, pano po kaya sir ginawa niyo na procedure po? parang tatanggalin po ang laman tapos add na lang po ba ng bago silicon oil
from observation halos lahat if not all modern i'm not sure what "n"th generation diesel engines from the Japanese brands still use a viscous fan driven by the crank. ang nakikita ko na diesel using an electric fan for the radiator ay from europe brands and hyundai. popular diy lately nga na i convert yung viscous fan to electric to free the engine from some parasitic losses.
as for electronically controlled actuation ng viscous fan i'm still not sure. yung wire plug na nakikita malapit sa clutch fan maybe just a simple fan speed sensor.
Really depends on the size of the fan clutch. The correct level is when no oil is visible on the shear plates, there should only be oil in the reservoir, which is the same scenario when engine doesn't need cooling or when you rev the engine high. All oil is contained in the reservoir thus disengaging the clutch.
yong iba kasing mekaniko kahit mga aircon technicians I've talked to, they will tell you your fan is not engaging. of course it should be the case if the temp around the engine is still low. they want the fan to engage para daw lumamig yong AC. given na man yon, but should be under the correct conditions. and that correct conditions ang wla sa utak ng mga incompetent mechs / AC techs.
i think so, too. self-contained and works on their own. hirap lng talaga sa pag service/repair compared to electric fans.
2.0L (NA) hybrid ba? Masyado naman mahina kung lower than that displacement unless turbocharged.
FWD, A/T only walang problem I think tatangkilikin pa din ang innova.
ang question for me would be the price. i sure this will be now cross shopped with diesel PPV based suvs. im not sure whether most of us would prefer the ruggedness of PPVs or the comfort of the new innova. wala ako masabi sa hybrid because i suspect the vast majority will consider the hybrid primarily because of tye fuel savings and only time can provide us that data. bonus na lang yung tahimik refinement. i also hope malakas humatak di nalalayo sa 2.8 1gd-ftv nung out going model
A few thoughts i had with the launch of the new Innova
I get that it is now fwd, 2.0gas or hybrid. But we are used to the Innova on the ladderframe IMV chassis shared with the Fortuner and Hilux. What I am curious about is about news/leaks about next generation Hilux and/or Fortuner. Surely they will still be ladderframe or will Toyota completely axe the IMV development?
Because for markets like the PH, theoretically, they could launch the new gen hybrid Innova as the Innova Hybrid or Innova Zenix while retaining a diesel Innova on the same IMV olatform or whatever the Hilux will be using because surely that will still have a diesel at least and won't be fwd.
So the Innova 'could' go the way of the Avanza and the Veloz. But the non hybrid Innova will be mainly for utility/practicality by my guess.
Just a thought.
i agree. not all would be willing to pony up for a top of the line hybrid all singing and all dancing innova. a good majority would gladly trade some features for a good chunk of savings.
just as an aside when my wife and i were looking to replace her daily drive na montero 2nd gen. shortlist namin ang innova. we bought a sedan instead because of comfort anf ease of driving but biggest take away was the suspension medyo a little too harsh pa din to our liking yung innova.
