Page 705 of 775 FirstFirst ... 605655695701702703704705706707708709715755 ... LastLast
Results 14,081 to 14,100 of 15487
    Sep 2019
    #14081
    Quote Originally Posted by johann123 View Post
    Kahit yung walang kulay na bulb. Since red cover naman yan.
    Sent from my Redmi Note 5 using Tapatalk
    ok sir sige salamat
    Oct 2018
    #14082
    Just want to suggest to fellow AN140 Innova owners here. Try out these one-side T10 LED bulbs which I got from LED Lights PH (their page can be found in Facebook). It is useful for our luggage compartment light which houses a halogen W5W.
    The lighting performance of these are a stark contrast. You will get exceptionally more usable light since the LED has all the LEDs facing out the housing instead of the halogen which is less bright and is situated in a non-reflective housing.
    They sell it for 600 PhP a pair, or a piece for (you've guessed it) 300PhP. You'll only need 1 piece for our Innova since it is of much usage only for the luggage compartment light. I suggest using 360 degree style LEDs or axial-facing LEDs for replacing other W5W bulbs.20191111_180053.jpg20191111_180059.jpgfb_img_1573274866005.jpg
    Jun 2005
    #14083
    I attached the photos of the bulb it is approximately 1.3cm in length.
    Yung diameter ng base dapat.. Try to pull the bulb out. If you can pull the bulb out that is T4.2. pwede T5 madami sa autosupply.
    Sent from my MI MAX 2 using Tapatalk
    Feb 2019
    #14084
    Quote Originally Posted by sirkosero View Post
    Okay. I thought the bulb is fix with the base socket. I will try if I can pull it out and will post another photo.
    Sep 2008
    #14085
    Hi Sir,
    What is the size of sd card for 2019 innova car stereo gps slot?
    Sep 2008
    #14086
    Quote Originally Posted by ParticleX View Post
    Sa may mga stock head units of the Innova first gen with the AVT head unit, if you want to replace the stock GPS software, I created a guide here: Installing GPS software/maps in an SD Card
    Hi sir,
    Jun 2015
    #14087
    Quote Originally Posted by Mr. Goodshot View Post
    Meron po ba sila para sa lahat ng interior lighting? salamat!
    Jun 2015
    #14088
    Good afternoon!
    Gusto ko sana mag upgrade ng headlight bulbs to LED. Kailangan ko po mas maliwanag na ilaw para sa biyahe. lalo na pag umuulan. ano po ba socket ng innova 2008?
    Ok po ba yun LED?
    Slamat po!
    #14089
    Quote Originally Posted by aqgvjr View Post
    Good afternoon!
    Ok po ba yun LED?
    Slamat po!
    if your front windshield is tinted,
    removing the tint may just remove your need to brighten your headlight.
    it will also diminish the chances of your blinding oncoming motoristas with your brighter headlight.
    May 2015
    #14090
    Good afternoon!
    Ok po ba yun LED?
    Slamat po!
    H4 socket sir. If LED po gusto nyo. Look for a good brand of LED Headlights, mas maganda if may driver siya. I tried LED H4 na binili ko sa shopee (Hi/lo white/yellow) ayun 4 months lang tinagal. At very present yung noise sa FM in any stations. Novsight magandang brand din yan syempre Philips ultinon maganda rin.
    Apr 2010
    #14091
    Quote Originally Posted by mumuy View Post
    Hi sir,
    Not sure, either full size SD or Micro SD ang common for the GPS slot
    Sep 2008
    #14092
    Hi again sir,
    Can you post a picture of the type of card used? Do you use any adapter?
    Oct 2018
    #14093
    Good afternoon!
    Ok po ba yun LED?
    Slamat po!
    Be careful of buying cheap LEDs as they can cause problems with your wiring or can even be less bright than your stock halogens.
    I recommend Philips Ultinon Essential for an entry-level, budget-friendly LED. Though if you have the budget, you can go get Philips X-treme Ultinon or PIAA LEDs. These all actually use only a fraction of the wattage of the bulbs they replace and have drivers included so your wirings should be safe (so long as they are genuine). Your Innova model should use an H4 bulb. Though these emit white light at 6000K, so your mileage will vary when used in the rain.
    Don't even think about getting LEDs that use Cree chips, be it an XHP50, XHP70, or whatever they call it. These produce a lot of glare even in lowbeam if used in a reflector bowl headlight which is dangerous to oncoming traffic. You don't want to be the cause of an accident.
    Oct 2018
    #14094
    Meron naman. Though yung one-side LED lang kinuha ko sa kanila. The rest ng gamit ko sa interior Philips and Osram brand.
    They have good reviews sa mga products nila kaya safe gamitin and durable naman. Not to mention maliwanag na maliwanag.
    Apr 2010
    #14095
    Hi again sir,
    Ours is a 2016 pero it is the first gen with the 2.5 2KD engine, so most likely different ang head units natin. I am using a full size SD card in the stock AVT head unit.
    Dec 2011
    #14096
    Good afternoon!
    Ok po ba yun LED?
    Slamat po!
    For LED headlight:
    1. Make sure po projector lalagyan nyo, at may good cutoff. If reflector housing, you will cause glare sa kasalubong nyo, masakit po LED sa mata.
    2. Don’t go with 6000K or higher sa lowbeams . Sa akin di maganda 6000K LED sa asphalt, fogs, and heavy rain (byaheng buda, davao with 35% medium tint) - kahit may yellowish foglamps pa. Go with a 4300K or all-weather color temperature.
    3. Lumen values ay overrated karamihan, go with Lux values pero sadly “not advertised” po ito.
    4. As applicable, make sure canbus-ready po ang LED headlight (or know if your car is using canbus) or you will get error pag start car. We have a Ford Ranger Wildtrak and I’m very careful dahil sensitive po sa electronics and etc. Buti nalang our Innova is not. [emoji28]
    Since nakabili na po ako (impulse buy) ng 6000K LED, I paired it with an Osram Night Breaker Unlimited sa left and yung LED sa right lowbeam. [emoji74][emoji594]
    Jun 2005
    #14097
    Quote Originally Posted by tuks View Post
    For LED headlight:
    Anong year innova mo? Yung current model innov tinotoyo kapag nagpapalit ng brake lights eh. Dont know about headlights though
    #14098
    kindly explain, po.
    Jan 2009
    #14099
    kindly explain, po.
    CAN Bus error malamang.
    There might be some sort of warning displayed on the dashboard if the bulb is busted, missing, or replaced with non-CAN Bus friendly LED bulb.
    Oct 2018
    #14100
    I experienced this too with our Touring Sport. Palitan ko sana ng Osram red LED para sa rear combination lights (W21/5W). Nung nilagay ko it's either yung taillight lang ang gusto sumindi or yung brake light, but not both. Kahit pagbali-baliktarin pa ang pagkalagay hindi mapapaandar ng maayos. Akala ko ako lang may problema.
Toyota Innova Owners & Discussions [continued 3]
