Page 605 of 775 FirstFirst ... 505555595601602603604605606607608609615655705 ... LastLast
Results 12,081 to 12,100 of 15487
    #12081
    Quote Originally Posted by homhomnova View Post
    Hello mga ka innova.. magpapalit na ako bukas ng shocks sa likod. Ano mas maganda oem na gas type o kyb na gas type. Nag tanong ako mas mahal yung kyb kesa oem. Oem 1200 tapos 1500 daw kyb.
    thanks.
    when i had mine changed a few years back, i was asked to choose between a cheaper and a more expensive kyb. of course i chose the cheaper! less than 1500, if i remember.
    wala naman akong naramdamang pagbabago... even today.. matagtag pa rin.
    yung sa harap ang nagbago. i chose the cheaper one... matigas!!! it took some time for it to soften. mebbe next time, i'll choose the more expensive (heavy duty daw) one.
    Sep 2009
    #12082
    Just had 5k pms clocked at 7k at toyota pampanga. Mother told me that she paid P2100 but no receipt coz of faulty printer then after few hours eh they texted her na dapat P2,900 daw. Meron na ba naka experience sa inyo ng ganoon?
    Follow up question: kelangan ko pa ba i pa 10k since nasa 7k km na? Ano services pag 10k pms?
    #12083
    Quote Originally Posted by antonath View Post
    in my experience with other establishments, whenever the printer or whatever bogs down, i am given a written receipt.
    perhaps if you peruse the details, you can decide which amount is correct-er. either can be correct, depending on what was done to the car.
    i re-understood the question...
    it's your call, sir.
    but in order to preserve warranty, i would have the 10K, para wala nang tanung-tanung later on. but as i am kuripot, i would have mine done at 10.5K, then at 15K. illogical, but...
    Dec 2008
    #12084
    Anyone know the headlight bulb size of the innova? We lost the manual and the its hard to google the info. Year is 2006 btw. Thanks.
    Sent from my SM-G930F using Tapatalk
    Jan 2013
    #12085
    Just replaced the 2 rear shock absorber at Zafra motors, Bautista st. Makati.
    Excellent service and quality + 6 months warranty. I had also the 2 front wheels camber corrected and aligned.
    2 shocks = 3000
    Labor = 650
    Front Camber+align = 1000
    6 months warranty on parts & labor.
    Feb 2015
    #12086
    Quote Originally Posted by keithdb View Post
    H4 60/55 .. Osram brand or philips.. Its ur choice.
    Dec 2008
    #12087
    Thanks for the answer bro.
    Oct 2013
    #12088
    Quote Originally Posted by lowrider17 View Post
    share lang mga paps. it is our 2nd tym going to baguio. 1st dala namin ung revo and ngayon ung innova namin. napapansin ko lang ibang iba tlga hatak ng revo sa innova pagdating sa mga steep road. parang under power ung innova compare sa revo... isa pa experience ko sa slex cruising at 150kph bakit parang may amoy na nasusunog sa a/c.tumigil kami sa gas station to check pero wala naman.. everything seems fine. tapos sa nlex sinubukan ko ulit after reaching 160kph ganun na naman ulit pero kpag chineck naman namin ung engine ok naman... may naka experience na ba nito?By the way FC namin satisfied naman ako 800kms=more or less 65liters of diesel
    wala kame na intindihan sa observation mo kase wala naman technical comparison sa specifications ng innova and revo ninyo,
    brandnew ba yan innova mo?
    OT: pero ang naintindihan namin, you violated the law by over speeding and endangered the life and property of others, kahit sabihin mo pa mag isa ka lang sa NLEX/SLEX o kahit ano pa man EX yan, seems like the hefty reckless fine and the whole day wasted claiming your license at LTO main is not a deterent to motorist...
    Tip ko sa iyo: Ignorance of the law excuses no one...
    https://www.tsikot.com/forums/traffic-laws-infrastructure-parking-135/nlex-sctex-over-speeding-speed-radar-[merged-threads]-19755/index140.html
    Jan 2009
    #12089
    Can anyone provide the procedure to remove the wiper cowl?
    May 2009
    #12090
    Here's the procedure given to me by Ginnova a couple of years ago. I hope this helps.
    I covered mine from the inside but you can do it from the outside.
    1. remove the wiper arms
    2. open hood to access the cover. there are 2 push clips at both ends.
    3. remove the rubber moulding
    4. there are clips below that holds the wiper cowl plastic.
    5. after you remove the cover you will see the air inlet going to the cabin. you can cover them with a thick plastic cover ( used in books ) . i believe there is also a hole in the driver side area
    Jan 2009
    #12091
    Quote Originally Posted by matt chua View Post
    Thank you. Much appreciated.
    Feb 2015
    #12092
    San ba makakabili ng innova mudguard na 2 pares lng ndi ung 4pcs.??? Nabangga kasi ng gunggong ng jeep na tinakbuhan na nawala bigla sa paningin ko sa may macapagal banda.. Nakakainit ulo .. Nway kng may idea lng kau kung san makakabili ng mudguard na 2pcs lng.thank
    #12093
    Quote Originally Posted by maze View Post
    try the katay centers in banawe or evangelista.
    or maybe, you buy the complete set of 4. then sell what you don't need, to others who need only 1 or 2 and refuse to buy the set.
    Feb 2015
    #12094
    Tnx dr.d sa reply.. Nagtyaga ako na maghanap sa evagelista ng mudguard dyosko wala tlga.. 4na set talaga.
    May tanong pa ako, nagpalit kasi aq ng stock halogen headlight h4 ng osram nightbreaker na same wattage.. Need pa ba ng relay na tawag nila para hindi masunog ung socket? Kasi ung sa dati ko revo pinalitan ko ung stock light nun ng whitelight nasunog ung socket buti na lng hindi nagstart ng apoy nanotice ko na lng nung nglinis ako ng makina. Safety purpose lng need advise po. Worry lang ako baka mangyari sa innova ko ung nangyari sa revo.tnx po
    Apr 2010
    #12095
    Kung same 60/55W bulbs lang eh no need na magpalagay ng relays. Baka 100/90W yung pinalit mo sa Revo mo dati kaya hindi kinaya ng stock wiring.
    Jan 2014
    #12096
    Go to Banawe and look for the shop Clifford's
    #12097
    relays merely shorten the wires feeding electricity to the lights. this results in decreased resistance and higher voltages, thus brighter lights.
    relays also decrease heat to the switch, because the current to the bulbs bypass it.
    but no, relays do not cause cooler temperatures to the bulbs and sockets. this is a function of bulb wattage.
    have fun, guys.
    #12098
    mga boss magkano po labor ng pagpapalit ng water pump?
    May 2009
    #12099
    Quote Originally Posted by ptk675 View Post
    otw to Baguio last Friday evening, i started hearing a sort of screeching/rattling sound coming from the engine bay when we reached urdaneta. quick inspection under the hood revealed what sounded like the alternator bearing starting to give out. continued on up to Baguio since it was already 9pm.
    good thing may Toyota Baguio pala, had it fixed yesterday morning before we went to la trinidad. there goes my 5k though..
    P5k? Para sa one way clutch ng alternator plus labor? ammahal din pala ano
    17 mm hex allen lang kelangan tska impact wrench. Or fab lang ng hex allen galing sa mga hex bolts.
    Well, fyi lang naman.
    #12100
    Due for change oil na ang old faithful namin.
    According sa manual recommended oils are the following:
    20W-50
    15W-40
    10W-30
    5W-30
    Api grade SL or SM
    Which one is most suitable for an aging engine?
    155K KMs na mileage namin.
    AT VVTI btw.
Toyota Innova Owners & Discussions [continued 3]
