Page 659 of 775 FirstFirst ... 559609649655656657658659660661662663669709759 ... LastLast
Results 13,161 to 13,180 of 15487
    #13161
    Quote Originally Posted by fektus View Post
    paktay ka diha. advise ng mekaniko kasi medyo mabagal na ang ikot and there is a constant hissing sound kasi pag AC on.
    after doing that, nawala na ang hissing sound pero yun nga, ang RPM naman eh nag-iba.
    that's exactly what they told me, when they recommended i have my fan's silicone re-filled. i declined, "next time na lang, bossing. wala sa budget, e".
    fast forward several years, and my innova is still the same.
    no overheat of any kind. aircon works fine. factory rpm.
    should TS worry?
    i don't know.
    but i will observe the charging system and the engine cooling.
    Jul 2015
    #13162
    should TS worry?
    i don't know.
    thanks doc! Things you do when its hot
    ang initial issue lang is the AC.... passenger side lang ang malamig kahit naka todo both fan and thermostat.
    No leak both evap pero may putik sa drain part ng rear evap. Was caught in the middle if the rear evap should be replaced or not...ended up replacing the rear evap then re-filled the silicone.
    AC is now cold on all angles kahit naka low lang/half thermostat settings.
    i'll update with my observation since bicol bound kami this weekend.
    I'll probably schedule na rin for a home service with my super trusted mechanic...hopefully walang maging ganap
    Aug 2008
    #13163
    i have an experience in adding silicon fluid in my fan clutch, first symptoms i notice was weak aircon so pinacheck ko sa shop and nakita na mahina na ang blow ng air sa engine bay causing the aircon to high pressure, what they did is binuksan nila yung fan clutch and true enough wala ng silicon oil, they refilled it with 4 vials. so ok na malakas na yung binubuga na air ng fan clutch but i notice problem while driving my innova may naririnig ako na malakas na humming sound kapag recta na takbo ko may drag and the source was the fan clutch was always engaged, 4 vials was too much, we removed the excess oil equivalent to 2 vials. My innova now runs fine with my fan clutch only engage on normal temp.
    Jul 2015
    #13164
    Quote Originally Posted by Terrence View Post
    i'll go back dun sa nag re-fill. so lumalabas na ang required vials is 2 lang?
    update ako, sana walang masyadong tao dun later.
    Aug 2008
    #13165
    how old sir is your innova? mine is 10 years old na when i had my fan clutch silicon oil refilled. first i opted buying the original silicon oil from casa kaso hindi daw for sale, dapat sa kanila mo ipagawa which is very costly. yes po 2 vials is enough.
    Jul 2015
    #13166
    3 years pa lang paps.
    OK na sa labas, reasonable naman ang price.
    Feb 2006
    #13167
    mga sir sa mga nagpa install po ng stepboard meron po ba need na iweld sa chassis and meron po ba dito nakapag install din ng roof rail pag po ba no drill ano po possible na pwede pandikit, kelangan din po ba butasan yun rubber na taklob po
    Aug 2008
    #13168
    ask lang po if meron na sa inyo nagpapalit na ng engine support kasi I'm experiencing rough vibration sa loob ng sasakyan. pinacheck ko sa casa ang sabi palitin na engine support ko both sides. ask ko lang din kung pwede ba ito marepair?. tnx po
    ilang taon na? diesel?
    FOCUS
    Apr 2011
    #13170
    hello sa lahat:-)
    .ung innova diesel 2005 matik ko.pag galing ako ng long trip.off n on ko ung engine after a while.hard starting na siya.pinacheck ko na ang starter.new fuel filter na rin......may time na nagparamdam ung mga pulley nag ingay minsan.d ko alam kung alternator kasi nagparamdam lang gang sa nawala maski start ko sa umaga okay naman.wala ng ingay.walang mga warning light sa may dashboard.salamuch po..cheers!!!
    Aug 2008
    #13171
    FOCUS
    sir, more than ten years na po. everytime na idepress ko gas pedal at umabot ng 1,100rpm very prominent yung vibration. nag inquire ako sa banawe may inooffer sila na replacement na engine mount made in thailand RBI ang brand ok din po ba ito, kasi ang mahal ng original P2,650.00.
    Aug 2008
    #13172
    yes po, diesel po.
    Apr 2011
    #13173
    [QUOTE=greg2;2969881]hello sa lahat:-)
    toyota innova 2005 d4d engine.pag start sa umaga normal lang po.pero pag galing long drive at cool off for few mins pag start ko hard starting na at may konting nginig.change fuel filter at malinis pa ang air filter kahit old na.nacheck na rin ung starter salamuch po sa mga inputs cheers!!
    Apr 2011
    #13174
    #13175
    it's probably oem quality.
    the innova was originally manufactured in thailand.
    errr... how much does casa sell them? banawe?
    Jan 2014
    #13176
    Head cover gasket?
    Sent from my SM-A700FD using Tapatalk
    Aug 2008
    #13177
    Quote Originally Posted by crosswind View Post
    Head cover gasket?
    No sir, Its similar to engine support.
    Jan 2014
    #13178
    What I meant is baka need din yun palitan. Ang rough ng takbo ng Innova ko before siya napalitan
    Aug 2013
    #13179
    [QUOTE=greg2;2970237]
    Quote Originally Posted by greg2 View Post
    hello sa lahat:-)
    ipa diagnostic scan mo sir.
    laking tulong para makita kung may errors.
    Aug 2008
    #13180
    Sa akin po kasi during idle at tapakan ang gas pedal mavibrate sa loob ng car. Pero pacheck ko din yung cover gasket. Yung sa iyo ba may parang naglalangis na sa paligid ng engine?
Toyota Innova Owners & Discussions [continued 3]
