Page 701 of 775 FirstFirst ... 601651691697698699700701702703704705711751 ... LastLast
Results 14,001 to 14,020 of 15487
    Sep 2019
    #14001
    hi question lang po, paano po pinapalitan ang manual transmission fluid ng 2015 toyota innova diesel 2.5? at saka power steering fluid?
    Jun 2005
    #14002
    Quote Originally Posted by lenno View Post
    Power steering fluid, just vacuum the reservoir, fill it again, turn wheels lock to lock the vacuum again.
    For transmission oil, may drain plug remove it and fill with gear oil after. Personally mas maganda ipagawa sa gas station.
    Sent from my MI MAX 2 using Tapatalk
    Sep 2019
    #14003
    good day po, anyone response on this. Ask ko lng sana paano i-deactivate yung alarm ng toyota innova 2006 model? kasi madalas magloko ung alarm nya kahit di nman nakakalampag yung auto ko, bigla nalang tutunog yung alarm. Thanks so much po
    May 2015
    #14004
    Quote Originally Posted by jbt_innova06 View Post
    Ano yang alarm na yan sir? Pre installed or pinakabit sa labas? Baka nahuhulog yung controller mo sir?
    Sent from my Redmi Note 5 using Tapatalk
    Sep 2019
    #14005
    Quote Originally Posted by johann123 View Post
    Sir, second hand ko kasi nabili ung innova ko. pero ang alam ko pre installed ito, original key palang eh. Mga 2days palng nagloko after ko ipacarwash(body&vacuum lang). Possible kaya na nagalaw lang settings sa remote nya nung isalpak nila yung key sa ignition? Thanks po
    May 2015
    #14006
    Baka may nagalaw lang jan sir. Try mo sa ilalim ng steering wheel natatanggal po yung cover nyan. Try to inspect po.
    Feb 2019
    #14007
    Hi fellow unit owners. When cleaning the muffler my mechanic suggested to put a nipple in the engine bay right in the muffler pipe to pour in water and flush out carbon deposit. Is this the correct way of cleaning the muffler and has anyone done this? Thank you.
    #14008
    i used to have my exhaust tubes flushed clean by a long garden hose introduced from behind.
    until i found out, my innova passes the emissions test, even without this cleaning.
    but,
    i think there's something wrong with the emissions testing system, if one had to clean his exhaust pipes like this, just so's it can pass the emissions test.
    i mean, it should be testing the emission, and not testing the tube deposits.
    Aug 2009
    #14009
    Sa Isuzu clubs usong uso to tapos yung iba may sabon pang halo.
    Yung iba naman sinasaksak yung hose sa exhaust mismo then rev ng engine
    Feb 2019
    #14010
    Quote Originally Posted by Sleepcare View Post
    Yes I told him if it is okay to put the hose at the rear muffler and he told me it might not reach inside and clean thoroughly the muffler pipe hence he suggested to have this setup. I use my ride mainly for city traffic driving and have to clean the muffler for built up carbon deposit.
    Aug 2009
    #14011
    I guess it's ok to put the hose sa muffler once in a while para lang malinisan. But having said that, the italian tune-up will help a lot to release the carbon deposit.
    Aug 2014
    #14012
    Sa mga 2.0 vvti owners hindi ba underpower? Expected ko na malakas sa gas pero mag 7km/l ok na ko,, Ang mura ng gasoline version 250k-300k. Thinking of buying it. Replacement din sa nabanga na montero ko..
    Sent from my SM-G965U using Tapatalk
    Quote Originally Posted by timming_gear View Post
    drove one to pagudpod.. its got enough grunt naman with the MT. the transmission is short geared hence the power is available naman.
    Aug 2014
    #14014
    Hindi ba Bro underpower sa overtake manual transmission din hahanapin ko, may bitin sa automatic yung 2.7 gas na fortuner namin pinag lalaruan ng 2.5 vnt [emoji846][emoji846]
    #14015
    brother has one.
    ok naman daw, sabi niya.
    "just don't you go racing around in the family carrier."
    he slexes daily.
    May 2015
    #14016
    The 248NM of torque is available at 3.8k rpm. The vnt forty can access the 358NM of torque between 1600-2800rpm. Ok i have enough reading the brochures [emoji23] hehehehe
    Oct 2018
    #14017
    For the Gen 2 (AN140) Innova owners, any of you experienced moisture buildup on the right-left quarter panel where the rear AC is located? Yung panel mismo sa labas may moisture when the rear AC is used for an extended period of time on a rainy day. Does this happen to you or is it because I have an air leak on the AC ducting behind the panel?
    Jun 2005
    #14018
    Quote Originally Posted by Mr. Goodshot View Post
    Normal
    Oct 2018
    #14019
    I think diesel is just better on every scenario. Better fuel efficiency whilst the fuel being the cheapest, and power on demand since the torque is located on the RPM where we usually drive. You might not reimburse the premium you pay over the gasoline variant though as you'll have to use the vehicle for a very long time to be able to do that while disregarding maintenance costs, but for the convenience of having usable power and having great longetivity of the engine if it's being maintained well, diesel is the best choice.
    Yes, you will not be racing the car but trust me there will come a time when you'll be annoyed at how slow the vehicle accelerates off from a stop when fully laden. Get the best. Get diesel.
    Jul 2011
    #14020
    Hello, is it true na same lang almost all Innova's basta kabilang sya sa same generation nya? Nakausap kasi ng mom ko yung SA and sinabi na ang Innova 2019 and 2020 will be at the same price lang din dahil wala din differences. As in wala ba, or very minor na hindi masyado significant? And if so, since nasa 2nd gen tayo ng Innova, lahat sila nearly identical lang since 2015/2016?
Toyota Innova Owners & Discussions [continued 3]
