Guys pa help naman , I need some info on where to get a conversion panel for a Toyota Innova 2005
My bro sent me an aftermarket 2din head unit, i think its around 7 inches lcd . But when I checked up on this size vs the stock radio in the innova
May awang left and right. I was wondering where to get a conversion panel for an aftermarket double head unit.
thank you in advance
Hi,
Need help, anyone encountered this problem, when I step on the brake the park lights turns on, anyone who has a solution for this na DIY.
Thanks,
Josh
no, i haven't encountered this before. but it seems to be a straightforward case of wrong connection. an auto electrician should be able to right this.
but you can try to do it yourself. the fusebox diagram should be helpful in tracing them leads.
btw... who last played with your auto electricals?
Check chassis grounding points and the brake lamp/tail light ground. That usually happens when the brake lamps aren't grounded properly. 1157 bulbs have two filaments, low wattage (park light) and high wattage (brake light). When the outer sleeve or bayonet of the bulb is not conected to ground, applying the brakes would send power to both low and high wattage filaments.
Were there any work done on your car? Body work? Service?
sa mga nagpalinis na ng EGR valve magkano po nagastos niyo? yun kasi sabi samin bakit umiilaw cel light e, marumi na daw egr. salamat sa sasagot
Hello mga ka innova.. magpapalit na ako bukas ng shocks sa likod. Ano mas maganda oem na gas type o kyb na gas type. Nag tanong ako mas mahal yung kyb kesa oem. Oem 1200 tapos 1500 daw kyb.
thanks.
