Page 614 of 775 FirstFirst ... 514564604610611612613614615616617618624664714 ... LastLast
Results 12,261 to 12,280 of 15487
    #12261
    Quote Originally Posted by Salamander13 View Post
    Busted rear driver side shock absorber * 23k ODO Time for a warranty claim!
    they might not honor warranty on a busted shock absorber with 23K km on the odometer. wear and tear item, yata.
    but i hope you get it, po. sayang din. anyway, relatively cheap lang naman yan, kung bibilhin.
    Apr 2010
    #12262
    Somebody may be DIY-ing how to replace the fuel filter, may nahanap akong step-by-step with pictures. Baka ako na lang din magpalit nung sakin:
    How to: Change the Fuel Filter in a Toyota Hilux (2005, up)
    May nakasubok na ba ng Baldwin B2 or B2-HPG over the recommended BT223 oil filter? Mas mahaba kasi yung B2 and yun lang naman concern ko. Papalipasin ko lang 1 year sa casa then off I go to my suking gasolinahan na lang for PMS
    May 2009
    #12263
    Quote Originally Posted by ParticleX View Post
    si powerfuluklt ng youtube mayron din nyan kung gusto nyo makita via video...pati timing belt replacement and other repair videos sa mga toyota
    Apr 2010
    #12264
    Hi mga sir, to those who experienced issue with bad smell from aircon (maasim amoy during start-up), what did you do to correct the issue? I had my aircon system cleaned at 25tkm with filter changed. Now it's at 40tkm.
    Thanks.
    Apr 2010
    #12265
    Run the AC on fan mode only - turn off the compressor. Dunno kung may Off position ba yung manual models, climate control kasi yung dito. Wag ka muna mag AC for 1 or 2 days hanggat di nawawala yung smell by this method. Then afterwards ok na yan
    #12266
    meron naman. fan only. no cool. i do it all the time, a few minutes before reaching home.
    #12267
    good day guys.
    I have may stock swift tires (185/65/15) gathering dust in the garage.
    Can i use them on the stock mags of our innova E? I mean is it safe? the stock tire size of the innova is 205/65/15
    Apr 2010
    #12268
    Quote Originally Posted by mrshooli View Post
    good day guys.
    Check the tires for their loading capacity and manufacturing date. Also within 3% lang dapat ang difference ng tire size within stock, lets hear the input of the others. Pero kung ako iyan I would not risk it
    Aug 2009
    #12269
    good day guys.
    Hindi na papasok sa rim mismo yung goma kapag 185. Maliit lang din ata load rating ng 185.
    Jan 2009
    #12270
    good day guys.
    I wouldn't.
    Aside from the resulting width and height difference, they may also have different loading characteristics.
    Aug 2009
    #12271
    I wouldn't.
    I remembered once that I've transferred a 215/65/15 in the Innova with 3 205/65/15 tires. There was a lot of wear in the shocks after buying a proper tire for the Innova. Also, the ride was very different. Would not do it again.
    Jul 2016
    #12272
    question po, kasya ba ang 3sm battery sa innova natin? may babaguhin ba o salpak lang? salamat mga sir.
    Apr 2010
    #12273
    similar ang width and height ng 2SM and 3SM, sa length lang nakakaiba. kaya siguro tabasan ng battery dealer yung tray para magkasya.
    balak ko din yan to get a replacement 3SM battery pag kailangan na, pero naghahanap pa ako ng battery tray pero mukhang walang nagbebenta locally.
    Jul 2016
    #12274
    Pwede yata alisin yung tray sir patong na lang battery. Try ko actual kabit hiram ako 3sm hehe tnx
    Sent from my SM-J500G using Tsikot Forums mobile app
    Apr 2010
    #12275
    pwede mo nga i-omit yung battery tray pero ang purpose nuon is to handle acid spills of the battery (if any) from contacting the body
    #12276
    patungan nyo ng plywood o ibang thick material, ang battery tray, para hindi na gumambala ang labi ng tray. para rin puedeng galawin ang baterya na pa-lapit sa engine at hindi tumama sa fenderside. tingnan nyo rin po, kung kayang ma-adjust ang battery clamp height, dahil tumaas nang kaunti ang battery height. gamitan ng thick washers or longer bolt sa harap, kung kailangan.
    good luck.
    observe ko, nungca na kami na-spill over, ever since we used low maintenance or maintenance-free battery. hindi na rin nag-corrode ang battery terminals/clamps.
    question lang po. bakit upgrade to 3sm? why do you feel that 2sm factory spec is not up to snuff?
    Apr 2009
    #12277
    Primarily for units with a significant increase in electrical load other than normal (e.g. upgraded sound system, horns, alarm, HIDs, DRLs etc.) to prevent battery drain in case the alternator fails / failing. Ironically though, I upgraded my sound system with an amplifier and a 12-inch sub but still using a 2SM. The battery never failed under its warranty period, even extending 5-6 months after the warranty expires.
    Jan 2013
    #12278
    Pag nag palit ba ng atf kelangan din palitan yung filter? Tsaka ilang liters ba kelangan pag normal atf change lang?
    Wala kseng sinasabi sa manual tapos nag tanong ako sa mekaniko sa gas station sabi 4L daw tapos sabi ng iba dito sa tsiko 2.4L lang. Alin kaya totoo? Naka schedule na ako sa monday for atf change.
    need your expert feedback.
    thanks.
    #12279
    Quote Originally Posted by homhomnova View Post
    thanks.
    Toyota casa would quote for about 3L...
    Dialysis we did a few months ago, I used 9L.
    #12280
    good luck.
    Agree bro. No need to "upgrade to 3sm"
    Both will die at approx the same time...
    One just offers higher A-Hr capacity, which you will not need under normal circumstances... Unless there's unusual drain on your electricals...
Toyota Innova Owners & Discussions [continued 3]
