Kapag dinrain ba ang radiator ng innova, saan irefill ng coolant? Dun lang ba sa reservoir? Parang ang liit masyado ng hose papuntang radiator eh
Sent from my MI MAX 2 using Tapatalk
Rust in the coolant could simply mean that somebody used ordinary tap water, contaminated liquid, or the wrong coolant type to refill it at some point. Even if you don't change the factory coolant, for as long as you keep it topped up with the correct coolant type, it should technically last the life of the engine. But of course, this is not ideal and at some point, it is still recommended to replace it as per the manual. Chemicals in the coolant that inhibits corrosion gets used up eventually (similar to how oil additives gets used up).
Anyway, rust in the cooling system would indicate that something is being corroded from within. It could simply be surface rust from an iron block or it could be from the water pump impeller. I've seen water pumps have their impellers disintegrate due to corrosion, causing the coolant to stop circulating and the engine to overheat.
Something like this....
New vs Old
see link ng installation guide na nakita ko with matching Video. Nakabili ako sa Lazada yuong may kasama ng wires papunta sa ECU, hindi ko pa nga lang na check kung compatible yuong wires.
DIY: Paddle Shifts and Cruise Control installation in the Toyota Innova Crysta - Team-BHP
After 11 years, kahapon lang na drain lahat ng old coolant ko from my Innova 2008 and since I erroneously mixed the coolant (originally Toyota pink color) with green ones from different brands during top ups, I really thought na magkakalawang aya. However, I've watched the whole process and saw that the old coolant was still clean and pink. So no rust pala....
Hello po mga ka innova, ayaw na kasi umilaw nung high mount stop lamp/third brake light nung innova ko, ano po kaya possible na problem nun, most likely siguro pundido na yung bulb nya no? Ano po kaya yung bulb nito sa CASA lang nakakabili and kung sakali saan po pwedeng magpakabit nito, baka may maisuggest po kayong electrical shop.
Image for reference:![]()
My 2008 Innova instrument panel light bulb (behind the thermostat knob) got busted. It is just a small light bulb and have inquired in some banawe shop but they don't have a similar one. Any shops that you know of that has this kind of light bulb? It is more like a very small led pinlight. Thank you.
if yours is like mine,
it's a tiny incandescent-type peanut glass bulb, mounted on a plastic (bakelite?) base. i already walked half of banawe and many other auto supply stores for such. wala.
but it is easily available from the casa, where they sell it for an obnoxious amount of 350 or 700 bucks apeace, i forget which. i bought several.
for some reason, over the years, my innova already busted three of them.
my replacement bulb is in the ashtray beside it. but tinatamad na akong mag-kabit, ulit. baka mapundi ulit, eh. heh heh.
if you do not know how, yet (but i suspect, you already know how),
the how-to instructions are in youtube. the most difficult part, is twisting the old one out, and twisting the new bulb, in. it's a bayonet mount. it's not difficult, if you don't have the hulk's hands.
good luck.
Take a picture. From there we can guess if it is the T4.2 bulb which is the common bulb, easily replaced with a T5 bulb. Or the T3 bulb that is mlre difficult to source.
If it is the T3 bulb, shopee is your friend. I bought a pack from shopee since i canf buy just 1 pc.
The 1st gen Innova 3rd brake light is a T15 or W16W peanut bulb (12, 16W).
better to have a ruler in the picture.
there are at least two near-identical models, differing only in size. i made the mistake of buying what i already suspected as the other size. "mura lang". 100 kesos. i thought i could switch/replace bases. but i was mistaken.
best is to have the busted bulb on hand, for comparison.
i eventually surrendered to the casa, whereupon i purchased $everal piece$.
I attached the photos of the bulb it is approximately 1.3cm in length.
