Page 411 of 775 FirstFirst ... 311361401407408409410411412413414415421461511 ... LastLast
Results 8,201 to 8,220 of 15487
    Jan 2011
    #8201
    Quote Originally Posted by timo07 View Post
    Mine at 41K+ still has a few hundred or even thousand km before getting to the tread wear indicator. I just decided it was time to replace because 6 years na.
    33K 3+ years, Rotation every around 10K.
    Feb 2010
    #8202
    Quote Originally Posted by innova2013 View Post
    kasya siya paps. yan na maximum offset na para sa innova natin kung 7" lapad. pero minsan kasi, nasa design ng mags mismo kahit na pasok sa range ng offset. mas mainam kung ittest fit mo. problema lang naman ay yung sa likod o during full turn kung masyadong malapad at pasok ang offset, check mo sa likod kung tatama sa lower shocks
    regarding naman sa tire spec of choice, saktong sakto siya, more than 1% larger in circumference lang siya sa stock wheel set ng innova, ibig sabihin, hindi mo na kailangang magpa wheel alignment (toe and camber) para icorrect suspension mo at same pa din reading the speedometer
    currently using 18x8 40 offset, 225/45/18 tires
    happy wheel hunting sir
    many thanks papsy!!!
    Apr 2009
    #8203
    tama ka sa 2nd statement mo sir. one way valve siya. ang tamang connectivity ng oil catch can ay sa pagitan ng PCV to intake manifold.
    kahit walang vacuum from intake manifold marerelease pa din blow-by gases from the engine through the PCV, kaso during part load or acceleration, yung vacuum created by the intake manifold sa PCV, mas nakakatulong na matanggal agad blow-by gases sa makina. kung walang vacuum na tutulong, hihintayin pa ng makina na humigit sa atmospheric pressure yung blow-by bago marelease.
    dalawa kasi daanan ng blow-by gases ng makina; isa na yung PCV to intake manifold (dito nilalagay OCC), pangalawa yung breather (valve cover to intake tube connection)
    Thanks sir for the info. kaso medyo nalito yata ako sa connection set-up ko. Saan mismo yung location ng PCV at ng breather? observation ko kasi isa lang outlet ng blow-by gases, and I'm assuming its the already the PCV valve (rear part ng valve cover with rubber tube connecting to intake tube before the turbo). Dito naka-connect yung OCC ko. Wala ako napansin na breather inlet. If meron, san location nya? My ride is a 2006 D4-D.
    TIA.
    Aug 2013
    #8204
    Quote Originally Posted by garfield_08 View Post
    TIA.
    senior moment ako bigla D4D pala akala ko VVTi.
    tama connection ng OCC mo paps.
    Apr 2009
    #8205
    Ok sir. Many thanks.
    May 2011
    #8206
    hi po,
    ask ko lang po kung ano ang mga ginagawa sa 80K PMS? Kasi po ang mahal ng estmate 16K.
    thanks po
    Jul 2013
    #8207
    Quote Originally Posted by 1845ers View Post
    hi po,
    thanks po
    Checkmo owner's manual. Madami na siguro for replacement kaya mahal na.
    Sent from my GT-N5100 using Tapatalk 2
    Oct 2011
    #8208
    Haven't reach at that level yet but basically change all fluids and check-up of your car suspension.
    Aug 2006
    #8209
    hi po,
    thanks po
    what ever is done in 40K PMS, change all fluids and filters
    if your car is nearing the end of warranty, better have it done sa gas station, it would cost less than 8K.
    Aug 2013
    #8210
    question mga Sir,
    How many kilometers does Toyota Service Center recommends to change D4D fuel filter? I read the manual and it is stated just to inspect every 10,000 Kms? No indicated mileage or time when to replace.
    Thanks.
    Oct 2011
    #8211
    Due to dirty fuel and fuel issues surrounding D4D engine before, I make it a habit to replace fuel filter element every 10k.
    Question: how true that innova diesel a/t has more torque compared to m/t?
    Hows the fuel consumption for a/t and m/t?
    For a/t is it 5 gear or 4 gear only?
    Tia!
    Posted via Tsikot Mobile App
    May 2011
    #8213
    Quote Originally Posted by Mile2 View Post
    Thanks po.
    Until April 15, 2014 n lang yung warranty. We already replaced 2 front shocks covered by warranty.
    I will bring the car na lang to the trusted gas station.
    Manny thanks.
    #8214
    Ano po nangyari sa front shocks nyo in the two year life span? Tumigas po at nagging super bumpy ang ride? Ilang Km na po?
    Parang ang bilis po kasi. Buti nasira sila during sa warranty period nyo.
    Thanks po.
    Manny thanks.
    #8215
    Guys, Any idea bakit hindi pantay ang pag lock sa 2nd row seat (single). dapat Sobrang bagsak pa saka nalolock then tabingi sya konti. May adjustment po ba ito para pumantay?
    #8216
    Quote Originally Posted by kristine123 View Post
    hinala ko, may nag-pilit at na-mis-align tuloy.
    madali naman yang siyasatin.. eyeball-in mo nang up close ang lock. i-baba at i-taas mo nang slowly...
    tingnan mo rin ang partner niya.. baka may naka-tukod doon, kaya hindi lapat..
    kapag nakita mo na ang mis-alignment, pukpukin mo hanggang dumiretso ulit.
    Jul 2011
    #8217
    Yung BIL ko naka '10 Red Innova E 2.0 AT magpapalit ng Fort kaya gusto nya ibenta.
    Nasa 65,xxx kms lang ata odometer.
    PM na lang if interested.
    Aug 2013
    #8218
    Quote Originally Posted by happymeal View Post
    kadalasan bouncy ride paps, kapag nadaan sa uneven road surface, parang hindi stable yung sasakyan lalo na kung medyo matulin, at ang tagal tumigil ng pag bounce kapag dumadaan sa humps. ganito feeling kapag sirang sira na siya.
    visually check mo sir yung shocks, kung may oil leak, pasira na siya. dun tinitignan sa may shaft, oil seal kasi yun, kapag busted na, significant yung dami ng oil sa shaft o tumutulo na sa body ng shocks mismo.
    Oct 2013
    #8219
    Quote Originally Posted by greatauror28 View Post
    Parang mataas sir ang mileage for a 2010 model.
    #8220
    Ang partner nya kasi sir yung gitna naka taas pa, tapos ang isa naka touch na sa bakal. kaya pag ma lock ang isa ang isa ay naka angat pa. Dapat dinidiin pa talaga gitna para ma lock tapos sobrang sikip ng lock. hindi na basta basta ma unlock.
Toyota Innova Owners & Discussions [continued 3]
