Page 415 of 775 FirstFirst ... 315365405411412413414415416417418419425465515 ... LastLast
Results 8,281 to 8,300 of 15487
    #8281
    Quote Originally Posted by kristine123 View Post
    as in no clicking sound Sir? i have volt meter inside my Innova, 12.something Volts. it won't go down to 12volts even headlights and fog lamps are open. i will try another battery tomorrow. Thanks
    if you are manual trans, push-start it. once it starts, you can drive over to a decent battery store, where you can have your battery checked.
    or, you can canvas by phone first. bring your car to the better priced battery store..
    good luck.
    if everything checks out ok, baka nga relay o solenoid ang problema.
    #8282
    good luck.
    Problem solved sir, Car Electrician tested my battery OK, Starting Relay OK... Starter ang problema... pinokpok nya starter AYUN nag start na tapos Pinalitan nya ng Carbon B. sa loob ng Starter... Ok na sya ngayn...
    #8283
    Good to know that Sis... Stuck up starter... Oh well...
    Apr 2006
    #8284
    Hindi yata na inform yung isa na may bagong facelift model na lalabas
    #8285
    hindi stuck up ang starter Sir CVT. budpud na po ang carbon brush nya. 4 pcs carbon brush pinalitan.
    Pokpok lang po need para mag move ang carbon brush para mag operate ulit ang motor starter.
    to give you an idea ganito po ang loob ng starter.
    Jan 2011
    #8286
    Mga ka-innova sa mga nagpa change fluids outside casa.
    Ano gamit niyong
    Brake fluid
    ATF
    OEM pa din ba? Or you tried other brands?
    Fluid Capacities Toyota Innova VVTI
    3L Rear Diff Gear Oil, 2.4L Type IV ATF, 5.6L ENGINE OIL.
    #8287
    At what point do we change our differential oil?
    Im lost.
    Mine is A/T.
    May differential oil ba yun?
    Oct 2013
    #8288
    Lahat naman may differential oil, at 40k, magpapalit ka.
    Aug 2012
    #8289
    Im lost.
    Mine is A/T.
    refer to your owner's manual so you won't be lost. here's what stated, replace differential oil every 40,000 km or 48 months (whichever comes first).
    #8290
    Im lost.
    Mine is A/T.
    Yes may differential oil po tayo Sir Cast... A/T Innova
    nasa loob nilto ang OIL sir cast.
    I've seen Isuzu hindi nya pinalitan differential oil nya for many years.. Ayun putik na ang nasa loob. hindi nya daw kasi alam na may oil pala doon sa loob.
    #8291
    ^thanks thanks!
    Yung 40k, 80k, 120k KM PMS ko sa casa naman ginawa.
    Im sure pinalitan nila yun, since palit fluids yun diba?
    Papalitan ko na lang next 160k km.
    Dec 2007
    #8292
    ^thanks thanks!
    Tingnan mo yung mga service invoices mo to be sure. Kung mayroon nakalagay na TGDG GL-5, 85W-90, mga 3 liters, then yan yung differential gear oil.
    Jul 2006
    #8293
    paunang i quiry ko mga sirs bago ko dalin sa casa, kasi meron ako naririnig na squeeking sound sa likod ko kapag nagprereno ako at kasabay nya yung pagtapak ko sa brake pedal.
    tinry ko galawin suspension ko yung ugoy ugoy lang left and right , up and down wala naman,
    naririnig ko sya when the car is moving, anu kaya yun?
    thanks team
    Aug 2012
    #8294
    Hi guys need your advise sana... my innova is about to reach 60k na and first time out of casa ang pms...
    what should be done pag 60k pms?
    Where can i have the aircon cleaned? Parang never pa ata nalinis yun kahot by the casa
    thanks a lot!!!
    Sep 2011
    #8295
    maganda naman parehas, pero imho mas pipiliin ko pa itong lumang version ,
    Oct 2013
    #8296
    ano FC ng 2009 Innova AT Gas?
    #8297
    Quote Originally Posted by misterioman View Post
    Light city traffic around 8 km/li, highway almost 10kpl. Personal experience, full tank method.
    #8298
    Thanks Sis.
    Quote Originally Posted by loverlionus View Post
    That is what I am getting, too, approximately.
    22.9K:toma:
    #8299
    Quote Originally Posted by sirmykel View Post
    thanks team
    Baka for replacement na break pads mo? Or madumi lang yan pa-check mo.
    Feb 2014
    #8300
    mga bossing ano po ba ang murang brand ng gulong ngayon para sa ating innova?
Toyota Innova Owners & Discussions [continued 3]
