May naka experience na ba dito umilaw na ang SRS Airbag sa Dashboard? 90k odo
Usual kasi namamatay ito pero steady na ngayon.![]()
Di ba kayo mam kristine included sa spiral cable recall ng toyota? sa airbag din connected yung part na yun.
Ano ba procedure ni TMP dun sa spiral cable recall?
tayo ba lalapit sa dealer na binilhan natin?
o susulatan/tatawagan etc tayo ng toyota? wala pa din ako natatanggap any means of communication from them.
unless hindi ako kasama sa recall? IIRC year model nilabas nila for that, i belonged dun sa year na kasama.
Its better for you to contact TMPI. You can call their hotline at their website.
This is the method I used and they were able to replace the airbag cable wire within a short while after some coordination.
Have the vehicle chassis #, engine #, etc on hand when you call so they can trace if you are part of the recall or not.
Hi
Can someone enlighten my problem
When i brought it to the casa.last year the put something on the speedometer that makes it blurry
posted via Toyota
Wala naman alam ang sales sa mga ganyan. All they know is to close the sale and meet their quotas. Once the sale is consummated goodbye narin sila. This is the attitude and behavior that most sales people exhibit.
http://tsikot.com/forums/toyota-cars...l-cable-98195/
As long as your Innova is purchased bet. Nov 2004 and June 2010 provided it comes equipped with a driver's steering wheel airbag then you can call Toyota Phil to verify if its really part of the recall. The chassis # and engine # will help determine that quickly.
Hindi normal na umilaw ang ABS pag switch off na ang ignition. Baka namali ng kabit.. Pwede masira ang control pannel ng sasakyan mo at ECM.
Tsikot Mobile App
Madali talaga masira ang PSquib at DSquib sensor..
Tsikot Mobile App
Hello tsikoters.. tanong lang po..
may nakapag mods na ba dito ng ATF cooler kit? Ano kaya benefits nito?
Kung yung intercooler ay para sa makina yung ATF cooler ay para naman sa transmission..
Curious lang po kse may nakita ako sa internet na nag d diy nito..
salamat
Usually may built in intercooler yan sa radiator. Naka divert ang hydraulic fluid papunta sa ilalim ng radiator.
Pwede siya lagyan ng ganito pero kailangan lagyan ng aux fan. Kasi kapag traffic, walang hangin. Kaya hindi din niya mapapalamig yung ATF. Hindi katulad nung stock config na dumadaan sa radiator, flowing siya palagi. Down side lang ng dumadaan sa radiator sa katagalan, kapag nag corrode na yung divider na nag hihiwalay nung coolant at ATF, maghahalo na sila sa engine cooling system ng makina.
Kung feel mo talaga paps magkabit, mas effective siya kung may aux fan, tapos thermoswitch controlled yung aux fan, gagana lang kapag kailangan.
Pero dahil may ganito na in stock form, mas maganda mag lagay ng additional ATF filter na lang para mas humaba buhay ng AT tranny.
Hello everyone.
Which is a better battery for gasoline Innova G , 2SM or 1SNF? TIA
