Page 410 of 775 FirstFirst ... 310360400406407408409410411412413414420460510 ... LastLast
Results 8,181 to 8,200 of 15487
    Jul 2006
    #8181
    a long time ago, sa jeep namin... maluwag na yung cross joint ng propeller shaft. palit lang, ok na..
    5 months old pa lang sir yung innova namen, pasok ba sa warranty nila ito?
    thanks thanks po
    May 2005
    #8182
    Quote Originally Posted by sirmykel View Post
    thanks thanks po
    3yrs or upto 100,000 kms whichever comes first ang warranty sa Toyota.
    #8183
    thanks thanks po
    it should be. and don't agree with them when they say it's part of the wear and tear and therefore, not warrantied! whoever heard of a cross-joint failure (if that indeed is the problem) after only 5 months? why, many cars die of old age before that joint ever fails...!
    May 2012
    #8184
    *retz
    thanks sir,
    Aug 2012
    #8185
    Hi Guys, just wanted to ask a couple of questions.
    1. What is the best oil for D4D innova 2010 model.
    2. Looking to change all four tires, what is the best value for money tire out there?
    Thanks!
    Dec 2012
    #8186
    Hi Ladies and Gents,
    I have a 2013 Innova E M/T. I was thinking of installing fog light but want to do it myself for hobby reason. Does any of you know a good resources to install fog light on Innova E?
    Thanks
    #8187
    Quote Originally Posted by boogie18 View Post
    Thanks!
    I use Castrol semi synthetic because the auto shop carries Castrol. Replaced just one tire and used the spare for the other side. Bought Yokohama A drive same as the current ones in the car, around P 4,100.
    Oct 2011
    #8188
    Thanks!
    1.) I'd pick Mobil Delvac MX or DGU for mineral oil and Motul CRDi or Mobil Delvac 1 for FS oil.
    2.) You could try GT Radial, it's cheap but of good quality but my personal preference is Bridgestone tyres. HTH.
    Feb 2012
    #8189
    Hi to all my fellow tsikoteers. I need some of your suggestions. My uncle is going abroad ang he wants to sell his red 2013 innova j dsl which he bought last feb2013 with compre ins. Magkanu po kaya nya ito pwede i for sale ngayon, fair market value? any suggestion po? Btw all stock po yung sasakyan and very well maintained. Thanks for the suggestions.
    #8190
    Around 90%of its purchase price bro....
    Oct 2011
    #8191
    Normally car depreciates 10% per year. Should give you a ballpark figure for your innova current selling price.
    Posted via Tsikot Mobile App
    #8192
    first timer here, may nakapagtry na po bang magpaint ng step board na aluminum ng shark? ano po ginamit nyo? nakakavoid po ba yun ng warranty? sa casa po kasi namin nakuha un.
    #8193
    Quote Originally Posted by hunter0213 View Post
    no, i haven't tried to paint an aluminum stepboard. but i have tried to paint aluminum parts. the (ordinary) paint just won't stick. you can practically flake it off using your fingers after it dries.. i don't know what paint to use.. good luck.
    Aug 2013
    #8194
    Quote Originally Posted by chitobarba1972 View Post
    Good Day Innova Gurus...
    Inquiry on mags...
    Ask ko lang if kasya sa Innova natin ang 17 x 7jj Offset 45 with 225/50 R17 tires?
    Kindly advise mga gurus...
    Thanks in advance
    kasya siya paps. yan na maximum offset na para sa innova natin kung 7" lapad. pero minsan kasi, nasa design ng mags mismo kahit na pasok sa range ng offset. mas mainam kung ittest fit mo. problema lang naman ay yung sa likod o during full turn kung masyadong malapad at pasok ang offset, check mo sa likod kung tatama sa lower shocks
    regarding naman sa tire spec of choice, saktong sakto siya, more than 1% larger in circumference lang siya sa stock wheel set ng innova, ibig sabihin, hindi mo na kailangang magpa wheel alignment (toe and camber) para icorrect suspension mo at same pa din reading the speedometer
    currently using 18x8 40 offset, 225/45/18 tires
    happy wheel hunting sir
    Aug 2013
    #8195
    Quote Originally Posted by garfield_08 View Post
    Good day Innova Owners!
    Mga Sirs, question lang po regarding the Positive Crankcase Ventilation (PCV) valve ng innova. Does this valve need the vacuum created by the intake to operate? meaning vacuum-triggered ba siya? Or is it a simple one-way relief valve na gagana at magbubuga ng blow-by gases kahit walang vacuum from the intake side? I'm planning to make changes sa oil catch tank ko, and it will affect the vacuum created by the intake.
    TIA.
    tama ka sa 2nd statement mo sir. one way valve siya. ang tamang connectivity ng oil catch can ay sa pagitan ng PCV to intake manifold.
    kahit walang vacuum from intake manifold marerelease pa din blow-by gases from the engine through the PCV, kaso during part load or acceleration, yung vacuum created by the intake manifold sa PCV, mas nakakatulong na matanggal agad blow-by gases sa makina. kung walang vacuum na tutulong, hihintayin pa ng makina na humigit sa atmospheric pressure yung blow-by bago marelease.
    dalawa kasi daanan ng blow-by gases ng makina; isa na yung PCV to intake manifold (dito nilalagay OCC), pangalawa yung breather (valve cover to intake tube connection)
    May 2005
    #8196
    Just a quick survey for Innova owners:
    How many kms did your original OEM Yokohama Aspec tires last before the thread wear marks showed (and need to be replaced)?
    Dec 2007
    #8197
    Mine at 41K+ still has a few hundred or even thousand km before getting to the tread wear indicator. I just decided it was time to replace because 6 years na.
    Aug 2005
    #8198
    ^^^ 5 years from date of manufacture ng gulong, recommended na palitan na.
    #8199
    gusto ko po sana kasi gawing black. anyone familiar with plasti dip? pwede po ba yun sa step board? naisip ko kasi na since lagi sya tinatapakan, magchichip at masisira yung paint. salamat..
    Jun 2006
    #8200
    My yokohama only lasted 35k because i run it at 28psi pressure. Lesser ksi ang tagtag at that pressure. I do tire rotation every 7500km.
Toyota Innova Owners & Discussions [continued 3]
